Go Back   Team-BHP > Around the Corner > Shifting gears
Shifting gears Off-topic discussions.
Thread Tools
Old 10th December 2006, 20:31   #1 (permalink)
ECM
ECM's Avatar
Default CPU usage for Windows explore,check this
Sometimes some Virus-spywares drag your CPU and make your system slowdown like a hell,here is a simple solution to find what is attached with your browser when you start you p.c and fire your browser.
First go to this site SpywareInfo > Browser Helper Objects (BHOs)
and download BHO Demon, run it and it will give u a list of files linked to explorer, there are normally 2 safe ones that are connected to Adobe and Symantec(maybe more if u have different progs installed rather than Acrobat and Noron a.v,in my case Acrobat is there but not using Norton/Symantec coz I hate it).
Mostly culprits may be like below as per some users reported in some forums,
*D4GL.DLL which can located in the windows folder
*ee20.dll
etc...etc...
Good luck and I hope this may help members to find if their CPU is acting like a cow milked out completely!
ECM is offline   Reply With Quote
Old 10th December 2006, 21:59   #2 (permalink)
devarshi84's Avatar
Also to add, under normal usage current cpu's should run at 400-800mhz with downclocking. the chart should show around 5-10% usage unless you are gaming or using some cpu intensive applications.
__________________
boyracer.blogspot.com
devarshi84 is offline   Reply With Quote
Old 10th December 2006, 22:17   #3 (permalink)
rsjaurr's Avatar
Good piece of information ECM.
My cpu had 4 files linked to it acrobat,googletoolbar,norton,spybot-search & destroy.I disabled nortan one coz i had uninstalled it almost 2 yr back.
rsjaurr is offline   Reply With Quote
Old 11th December 2006, 05:39   #4 (permalink)
goldsun's Avatar
Post
You may also use the Process Explorer provided by SYS-INTERNALS (and now acquired by microsoft and hence from Microsoft) to check what processes are running, and the related handles and dlls loaded as part of the process. It is very good tool to diagnose / debug the OS. Check out this link Microsoft TechNet: Windows Sysinternals. There are lots other tools / utilities which are free downloads.
__________________
Have a pleasant and safe driving
goldsun is offline   Reply With Quote
Old 11th December 2006, 12:20   #5 (permalink)
jkdas's Avatar
thanks for passing the info
__________________
"She may not look like much, but she's got it where it counts, kid."
Thread Tools
CPU Config suggestions 2fast4u Gadgets, Computers & Software 17 3rd August 2007 09:10
Battery Effect due to ICE Usage mobike008 Ask the Gurus 63 19th January 2007 17:58
Diesel Usage shivag Technical Stuff 11 20th September 2006 22:11
EDGE usage VMG Gadgets, Computers & Software 5 20th February 2006 09:07
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429
