Go Back   Team-BHP > Around the Corner > Shifting gears
Old 11th January 2007, 13:26   #1
manavdotcom's Avatar
Smile Run out of fuel ?
If a Boeing 767 runs out of fuel at 41,000 feet what do you have? Answer: A 132 ton glider with a sink rate of over 2000 feet-per-minute and marginally enough hydraulic pressure to control the ailerons, elevator, and rudder.
Read the complete story at
Gimli Track Info
I'm sure such things must have happened with most of us while driving with no Fuel pump in sight and tank getting empty.
manavdotcom is online now   Reply With Quote
Old 11th January 2007, 15:28   #2
n_aditya's Avatar
Thanked: 2,748 Times
Awesome article... hats off to the pilots for safely landing the plane with absolutely zero injuries...
a really good article.... thanx a ton mate...
Old 11th January 2007, 15:48   #3
Akshay1234's Avatar
Thanked: 6,746 Times
really good. that pilot sure has some skill.
Old 11th January 2007, 15:49   #4
ajitkommini's Avatar
Thanked: 109 Times
"...After approximately $1M in repairs, consisting primarily of nose gear replacement, skin repairs and replacement of a wiring harness..."
Did they get a Skoda dealer to fix it?
ajitkommini is offline   Reply With Quote
Old 11th January 2007, 16:09   #5
sreenivass's Avatar
Default Brilliant effort
Gimli Track Info
It was a brilliant and astounding effort from Pearson and Quaintal. I hope they were presented with some honorary awards. Even they saved quite a few millions for Air Canada.
Good find manav
sreenivass is offline   Reply With Quote
Old 11th January 2007, 16:11   #6
jkdas's Avatar
Thanked: 1,427 Times
it happened 11years ago!
Old 11th January 2007, 16:22   #7
sreenivass's Avatar
Default does not matter
True, the writeup does not mention if their valiant efforts were recognized. Their efforts had saved many lives and quite a few millions for Air Canada.
Old 11th January 2007, 16:34   #8
Thanked: 109 Times
The incident is also a tribute to the designers at Boeing. For something as complex as a jet airplane to be pushed so far beyond its normal operating limits and emerge relatively undamaged speaks volumes about the engineering that goes into it.
Old 11th January 2007, 16:49   #9
akroy's Avatar
Thanked: 29 Times
I saw this incident in natGeo Investigates...
Abhi
akroy is offline   Reply With Quote
Old 11th January 2007, 17:37   #10
BWN
Yaa.... I too could remember this incident shown on natgeo.... the program was "last minutes" if i am right....
Great effort by the pilots.... But I wonder how Boeing has not mentioned about Engine failure in QRH... Airbus has it right from its inception.Hmm... now dont ask me how i know it..... i have the luxury of reading QRH's anyways
BWN is offline   Reply With Quote
Old 11th January 2007, 18:32   #11
ghostrider4385's Avatar
Thanked: 7 Times
Phew! This thing could go as a script for some action movie! The narration was fabulous, let me at the edge of the seat till the end. Reminded me of one of them Tom Clancy type novels, a wee bit shorter though! :P
Of course, the engineers' van running out of gas at the end was the icing on the cake!
ghostrider4385 is offline   Reply With Quote
Old 11th January 2007, 22:04   #12
Here is another picture of the plane.
JetPhotos.Net Photo C-GAUN (CN: 22520) Air Canada Boeing 767-233 by Carlos Fuentespina
Old 12th January 2007, 14:10   #13
Red Bull's Avatar
thanks manav for sharing this,
Brilliant article
Red Bull is offline   Reply With Quote
Old 12th January 2007, 15:11   #14
jat
I remember reading this news long before. The investigation report showed that the aircraft crew did not know how to do calculations in metric system, while they were always flying planes which were calibrated in metric system (seemed that those guys did not know multiplication table of 10). The end result is in the article. As per the report, the sad part was that the tanks were "dipped" number of times and then the fuel suppliers and the pilots did the calculations number of times and in spite of getting the error, they did not try to cross check with anybody else and took the risk.
jat is offline   Reply With Quote
GQ Run II (Golden Quadrilateral Run II) arindamray Travelogues 327 6th August 2013 00:00
premium vs normal fuel during run-in period of the car rajshenoy Technical Stuff 54 10th September 2010 14:39
Proposal of fuel levy to help hit-and-run victims amitoj The Indian Car Scene 24 13th January 2010 18:02
Does the fuel pump run even when engine is off, but key in ON position ? supremeBaleno Technical Stuff 29 22nd January 2008 20:17
Bosch BSM Fuel efficiency run himanshugoswami The Indian Car Scene 6 9th February 2007 14:51
