Go Back   Team-BHP > Around the Corner > Shifting gears
Old 16th March 2007, 21:08   #1
Vid6639's Avatar
Thanked: 19,590 Times
Default Schematic for digital fuel level indicator
hey guys, my cousin is doing an engg project on a digital fuel gauge. Basically the circuit will be interfaced to a microcontroller 8952 and the LED display will display bars based on fuel.
I needed some basic schematic for the mechanical fuel level part. Once I get a voltage out of it I can use that for designing a circuit for interfacing bit.
Basically how do you convert the fuel level to an electric signal.
Something like the civic fuel display bars type.
hope I can get some ideas. thanks guys in advance.
Old 16th March 2007, 21:21   #2
DRC
DRC's Avatar
Thanked: 42 Times
Hi vid,
Just buy any fuel level sender unit, the one that goes into the fuel tank. Buy the one used in the bikes, they will be cheaper, car ones are expensive as they also house the fuel pump.
It is just a potentio meter with some mechanical arrangement. Usually, higher the fuel level, lower the resistance. You will find only 2 wires make life easier.
Need more details, PM me or call me I have nearly complete details off hand.
BTW, do you need to use the Microcontroller? If the idea is to display with bar graph, there are easier way without microcontroller.
DRC is offline   Reply With Quote
Old 16th March 2007, 21:28   #3
Vid6639's Avatar
The thing is I dont want to make life easier. It's a project so should be a bit of a challenge.
bike idea sounds good. Karizma has digital fuel indicator?
will PM you DRC. thanks a bunch.
Old 16th March 2007, 21:35   #4
jkdas's Avatar
Thanked: 1,424 Times
so does the new Pulsar bros
Old 19th March 2007, 21:58   #5
theMAG's Avatar
Thanked: 1,492 Times
vid,
Just ask your cuz to pick up a digital fuel indicator from some gujri shop. It'll look beaten up to have been done by a student and none the wiser. The high marks that he'll pass out on can be attributed to me with a royalty cut on his monthly paychecks.
Old 19th March 2007, 23:00   #6
Rehaan's Avatar
Thanked: 23,085 Times
Hey Vid,
About a month ago i was reading about fuel level sensors (cant remember why or where!) and about the DOT? standards the have to adhere to so as not to cause a spark / heat in the fuel tank..... even though it might be hard to ignite uncompressed petrol with just a spark (?), do keep that in mind!
cya
R
DIY : 2T Oil Level Indicator for the Yamaha RX Mr.Boss Motorbikes 11 19th October 2016 13:46
Ford Figo Fuel Indicator Needle Stuck at 3/4 Level and A/C Hissing sound Ananthang Technical Stuff 10 19th July 2012 12:22
HELP! Anybody has Amby schematic drawing? Rudra Sen The Indian Car Scene 23 26th April 2009 13:59
Fuel indicator in spark whether a correct measure of amount of fuel bkm Technical Stuff 2 3rd April 2008 14:24
Fuel reserve indicator by light or voice in Scorpio santhoshbkartha The Indian Car Scene 0 21st August 2006 14:02
