Go Back   Team-BHP > Around the Corner > Shifting gears
Old 23rd April 2007, 20:33   #16
Thanked: 49 Times
Viper, just use one of the numerous extensions available for Firefox on mozilla.org. (Link in earlier post). You should be fine, or refer to Tsk's post for specific one.
RX135 is offline   Reply With Quote
Old 23rd April 2007, 22:04   #17
sharathjeppu's Avatar
I use the Google Browser Sync. It synchronizes my bookmarks, cookies, saved passwords, History and Tabs. Don't need to create a seperate account. You can login using your google account.
sharathjeppu is offline   Reply With Quote
Old 23rd April 2007, 22:32   #18
Lightbulb
Originally Posted by viper View Post
Hi Guys,
Need some help. How do I transfer the favourites/bookmarks in Mozilla Firefox from my home pc to my office pc.
Viper
Viper,
PS: I use Firefox 2.x, but the procedure should be *very* similar to 1.5.
PS: I assume you use Windows 2000 or any version of Win XP
I. Assuming you want to move from Home PC to Office PC (and you don't need what you have in Office PC)
On your home PC:
1.1. Click Start -> Run and then type %AppData%
1.2. #1 will open up a folder view, Double click Mozilla
1.3. Double click Firefox folder
1.4. Double click Profiles
1.5. Double click *.default directory
1.6. Copy bookmarks.html file from the folder opened in #1.5 to your USB/Flash drive/Floppy(If you still use floppy)
On your Office PC:
2.1. Follow steps #1.1 through #1.5 in the above list
2.2. Close Firefox if it is running in Office PC
2.3. Copy bookmarks.html (from USB/Flashdrive/floppy) into the folder opened in #1.5 above
2.4. Restart Firefox
II. Assuming you want to "import" from Home PC to Office PC:
3.1 Follow steps 1.1. through 1.6
3.2 Open Firefox, Click Bookmarks -> Organize Bookmarks
3.3 Click File->Import->From File->Next->
Select bookmarks.html from your USB/Flashdrive/floppy
Hope that helps!!
pmbabu is offline   Reply With Quote
Old 3rd August 2007, 18:35   #19
normally_crazy's Avatar
Thanked: 389 Times
Anyways to import Firefox bookmarks into Opera ?
normally_crazy is offline   Reply With Quote
Old 3rd August 2007, 18:44   #20
adya33's Avatar
Thanked: 91 Times
Export your bookmarks as html file and then import 'em into Opera
adya33 is offline   Reply With Quote
Old 3rd August 2007, 19:20   #21
sreenivass's Avatar
Default the best option
Bookmarks >Organize Bookmarks >Export > Save it and copy to your other machine and follow the same way but "Import"
You do not need to go under the sheets trying import profile and all that. Clear user interface is provided as mentioned by jkdas, please use that.
After importing you want to make sure the ones you want to see on toolbar are copied to Bookmarks toolbar folder in the window that opens upon bookmarks -> organize bookmarks after import. There may be a minor issue, it may not show the copied/ imported bookmarks immediately, you could close the organize bookmarks window and open to confirm every thing is imported. This process works in 2.x.x.x, I think it used to be the same in 1.5.x.x as well.
sreenivass is offline   Reply With Quote
Old 3rd August 2007, 19:51   #22
Thanked: 389 Times
how ?? instructions please !
Old 3rd August 2007, 20:07   #23
unknown's Avatar
Thanked: 13 Times
Go to your -
C:\Documents and Settings\User\Application Data\Mozilla\Firefox\Profiles\\bookmarkbackups
unknown is offline   Reply With Quote
Old 3rd August 2007, 22:45   #24
sreenivass's Avatar
Default export/ import happens through files
When you select export, you will be prompted to enter a file name (like saving any other file) to save it. For import you will be prompted to select a file, chose the file saved in previous step.
Please refer to one of the posts for details of import export.
Mozilla OS for Smartphones - Competition to heat up? sa_kiran Gadgets, Computers & Software 9 2nd October 2012 07:01
Help Firefox Set a World Record sushanthr77 Gadgets, Computers & Software 37 14th July 2008 18:15
Mozilla Thunderbird - Problem ! normally_crazy Gadgets, Computers & Software 4 28th January 2006 17:43
Mozilla Firefox Help viper Shifting gears 2 22nd January 2006 21:06
Firefox going to hell in a hand basket imandeep Shifting gears 21 12th January 2006 00:15
