Go Back   Team-BHP > Around the Corner > Shifting gears
Old 1st February 2008, 08:21   #1
Fillmore's Avatar
Thanked: 141 Times
Default Help on Power Drill
I am looking out to purchase an electric drill for home usage.
My requirements are as follows.
- As compact as it can be (as usage will be minimum)
- Should be capable of drilling into concrete walls
- Max I may use it to fix screws of 20mm depth
Any suggestions of Make/Model and the estimated price would be welcome.
(I am based at Bangalore)
Also is it true that the drilling machine is not so important but the quality of the drill bits used is what matters?
Any other key feature that I need to look out for ? Since I am a novice in this area.
A search on eBaySearch: Find Items shows up drills with unbelievably low prices, so I doubt the quality of these drilling machines.
-Fillmore
Fillmore is offline   Reply With Quote
Old 1st February 2008, 12:00   #2
Autophile's Avatar
Go for Bosch 14.4V model. Available at Bosch power tools dealer.
Autophile is offline   Reply With Quote
Old 1st February 2008, 12:29   #3
sqwall's Avatar
Originally Posted by Fillmore View Post
Not sure you have posted in the right section but i would recommend getting a cordless drill with a high voltage rating.
sqwall is offline   Reply With Quote
Old 1st February 2008, 12:33   #4
black12rr's Avatar
Thanked: 274 Times
I Got a bosh drill for home use, it costed like 2.2k + ~400 rs for the bits from bosh itself . The bit kit contains for wood ,concrete and metal of various sizes .
Go to SP road and keep waiting straight, on the main road itself , ride side you see a big showroom of BOSH itself ,buy it from there .The quality is very good ,should last for minimum 10 years .
Its a one time investment ,get a good one . I initially got a local 300rs drill like on the ebay,its dint last after 3-4 times use.
black12rr is offline   Reply With Quote
Old 1st February 2008, 12:56   #5
Thanked: 294 Times
Pics or model number will really help.
Old 1st February 2008, 14:43   #6
sqwall's Avatar
Check this out
Bosch - Cordless Tools
Get the one with atleast 14v rating else you would curse the drill for loosing juice quickly.
Old 1st February 2008, 15:03   #7
Fillmore's Avatar
Thanked: 141 Times
Thanks for the leads, will check them out.
Regarding the section I posted it. Your right its not the accurate section but could not find a better section so posted it under the 'Do it Yourself' Forum
Old 1st February 2008, 16:51   #8
DerAlte's Avatar
Thanked: 2,879 Times
The quality is very good ,should last for minimum 10 years... Its a one time investment ,get a good one .
I have a Bosch drill still going strong after 21 years - not even the brushes needed changing!
Do we get cordless drill-drivers in India?
Old 1st February 2008, 17:23   #9
clipto333's Avatar
Whats a cordless drill "driver" janaab, ustad deralte chand yamla jatt? :-)
A cordless drill will be too expensive especially Bosch. For home use, a normal drill would suffice.
But there are cheap ones which can do the job. I have a Black & Decker cordless drill. It is powered by a 9.6v battery. I have used it to drill in the wall, wood, steel. It was for around 5k iirc.
cheers
clip.
clipto333 is offline   Reply With Quote
Old 3rd February 2008, 13:14   #10
black12rr's Avatar
Thanked: 274 Times
here is the the pic, took it for you on my K790 i
Old 3rd February 2008, 14:27   #11
Thanked: 294 Times
Tha is one nice photo we have got there. Can one tighten screw with it ?
Old 3rd February 2008, 19:19   #12
black12rr's Avatar
Thanked: 274 Times
yes you can but you need to be ultra careful ,if you over press the button you are screwed .
It can turn as slow as 1 or 2 or 3 rev/sec to full speed . But you need to press the button as gently as possible .
I recommend not to use it as screw tightener .
I have destroyed the screws or broken them while using this .
Old 3rd February 2008, 20:38   #13
Thanked: 294 Times
For it you need to have a steady hand.
Old 4th February 2008, 01:24   #14
Autophile's Avatar
No point you will keep ruining the bits and snapping screw heads. Instead get the cordless drill with variable torque clutch.
Old 4th February 2008, 01:31   #15
agree, i ruined the screw heads. Bosch also has some cordless screwdrivers, they work really well.
saintsinner is offline   Reply With Quote
Convert Power Drill to Polisher / Buffing Machine? pvgeorge Modifications & Accessories 6 3rd April 2015 02:03
Matching HU amp power with Speaker power? hitra In-Car Entertainment 21 25th March 2015 16:18
Review : Black & Decker CD70 12mm Hammer Drill searchingheaven Shifting gears 1 20th January 2013 20:02
Difference between Power Screwdriver and Drill? sbasak Gadgets, Computers & Software 6 16th December 2005 22:37
