Go Back   Team-BHP > Around the Corner > Shifting gears
Old 27th March 2009, 18:50   #31
Sideways's Avatar
Thanked: 18 Times
Originally Posted by Sam Kapasi View Post
Exactly my question: will a couple of bad shifts and a joyride make the clutch from being PERFECT to being finished?
So a couple of drag launches will finish a perfectly working clutch then?
I'm just trying to understand.
No, even a couple of drag launches will not fry the clutch. Clearly a manufacturing defect.
Sideways is offline   Reply With Quote
Old 27th March 2009, 19:00   #32
yzfrj's Avatar
Thanked: 118 Times
You're probably looking at dealer-performed repairs on that door, subsequent to damage during transport/testing in dealer's hands. Insist on a fresh paint job till you are satisfied.
I don't think it is something the dealer did. The sales rep was a very nice guy, he gave my dad a call as soon as the car arrived, so my dad saw the car as soon it was unloaded from the truck with all the dirt properly in place. So it rules out the possibility it was done in transit and the car was ready the next day so don't think they scratched it and repaired it.
Anyways, dad is a peace lover and he would rather keep quiet than shout on the dealer. I told him we can take it up. Dad said, its just a small thing so just leave it like that. Also the paint job most dealers/body shops does sends shivers down my spine. The thought of re-pain Vs ripples, ripples wins hands down.
Sorry all for being OT.
yzfrj is offline   Reply With Quote
Old 27th March 2009, 19:03   #33
SS-Traveller's Avatar
Thanked: 11,043 Times
Could have also happened at the dispatch end - transporter may have done a quick repair job., let's drop this discussion.
Old 27th March 2009, 19:39   #34
Thanked: 252 Times
Originally Posted by coolmob View Post
now the car is in such a condition that its almost impossible to chnage the gears.
That is not just a WORN clutch plate. Something else is amiss if gears are hard to change!
With a worn clutch plate gear changing remains normal.
Old 27th March 2009, 19:44   #35
Thanked: 658 Times
c'mon man.! clutch of any given vehcile lasts for 60k kms easily. unless its used for drifting.
I guess its a case of 'chidiya ka baitna hua aur dali toot gai'
also to add to that. 8k is ridiculous.
Problem can be the settings of clutch. or gear linkage
Old 27th March 2009, 19:45   #36
Very true - I missed that point. If the gears are sticking, the clutch is not disengaging when the pedal's pressed. A burnt clutch will not move the car but then the gears will not stick.
Broken clutch plates/springs, yes
as I mentioned earlier? Only a visual inspection after disassembly will bring out the truth...
Old 27th March 2009, 19:53   #37
condor's Avatar
Thanked: 4,432 Times
@Coolmob : did you get the smell of something burnt when you got the car back ?
That should have set you off even before you started from the hotel.
Old 27th March 2009, 19:58   #38
Thanked: 9 Times
Highly, highly unlikely. The valet has to keep working at his job, and he can't drive more than a few metres within the hotel compound with the handbrake engaged. That can't destroy a "perfect" clutch. If he went out of the hotel compound with the car to intentionally burn out the clutch, he'd have been out looking for another job. And his exit/entry from the hotel compound would have been recorded on the surveillance cameras and the gatekeepers' record books. Check this info from the hotel to confirm that the car never left the compound.
7000 km of extended misuse/abuse can lead to clutch burnout, not 50 metres of doing whatever at all. Broken clutch plates/springs, yes, but burnt out plate, absolutely NO.
@ coolmob: Will you say it on oath that your friend NEVER ripped his car?
yes i am willing to say on oath that the car was never ripped. for drifts or drags or anything of that sort. even i am completely amazed at what happened and how! i mean if u would have driven the car before and after the incident it felt as if it was a different car..
moreover my friend was not alone, he was with three more guys and it all happened in front of their eyes, even they were shocked at that time as to what had happened.
the car has been through highways, crowded areas and normal driving and everything else in between.
i can say it all coz he is a very dear friend of mine and its like we are almost brothers.
coolmob is offline   Reply With Quote
Old 27th March 2009, 20:03   #39
Thanked: 252 Times
True. A badly smoked/burnt clutch would smell for at least 3 or 4 hours.
Old 27th March 2009, 20:22   #40
simply_sunny001's Avatar
Thanked: 15 Times
Even if the clutch is slipped few times,it starts smelling and the guy hasnt mentioned that clutch smell was there when the valet driver brought the car.
And i dont buy the opinion that Valet drivers do this intentionally,never
why would they unless untill they hate you personally.Though i understand completely that nobody will drive our cars the way we do.its human tendency nothing much.
And if someone is so very possessive of a car they should never give it to Valet and park themselves rather than creating a ruckus at the hotel and more
simply_sunny001 is offline   Reply With Quote
Old 27th March 2009, 20:26   #41
Maybe the jockey revved the engine to 5k rpm and dropped the clutch on it, and something broke inside - the clutch may not have been smoked. A 'post mortem' at the workshop will tell the truth.
@ coolmob: OK - since you want to help your friend, do the following:
A. Ask to check the hotel gate records and surveillance tapes of that day and time - confirm that the car was not taken out of the compound. Go up to GM level if need be to get access to these records. A lot of noise in the lobby over this issue usually helps get a quick hearing.
B. Also check surveillance tapes from parking areas to see if you can identify your friend's car being misused by the valet jockey.
c. Keep the hotel in the loop about the high repair costs that are being estimated.
D. If the hotel refuses to cooperate, write a letter to the local police station and send it by registered post.
E. Based on this police report, talk to your insurer about an insurance claim for the repairs, since according to the owner this is not routine wear-and-tear but malicious damage.
Old 27th March 2009, 20:27   #42
Thanked: 252 Times
I'd go with that!
Never ever have I given my car to a valet. Often it has meant cancelling or going elsewhere!
Ditto Service Centre's pick up and drop facility.
Old 27th March 2009, 20:39   #43
gd1418's Avatar
Thanked: 656 Times
Now let me try to understand your explanation.
Originally Posted by Bass&Trouble View Post
Very possible.
Here are a few easy steps to achieve it.
1. Go to JW Mariott in a slightly old and confusing car. Something like a Sierra will work best.
You've given an explanation of what happened to you and the fact that you owned a Sierra that must be quite old though well maintained. Here it is a SX4 that is fairly new with 7K on the odo.
2. Drive up to the upper lobby entrance and give the car to a valet.
3. Sign the tag that relieves the hotel of all responsibility with respect to parking/ driving your car.
4. After a few minutes, ask for the car.
5. Observe, as the valet driver comes up the ramp with smoke fuming out the bonnet.
The Taj Palace ramp here in Delhi is not as steep as that of the JWM in Mumbai.
There, you now have a car with a fried clutch. And an even more fried owner who's both angry and embarassed at the spectacle but can't do anything about it.
This, btw, has happened to me. With the Sierra. The bloke started the car and drove it up in 3rd gear.
Old 27th March 2009, 20:45   #44
Thanked: 9 Times
for one thing its not a question of being possessive. lets say u go to a supposedly world class place to have a good time, pay through your nose, and when u come back what to u find..... some of their inexperienced staff messed up with your car. that is not possessiveness, its gross negligence on their part.
moreover i never said that he hated my friend or his car or was hell bent on destroying it or using it for roaming around the area, the main point is someone failed do his job properly in return causing problem to a person without any reason.
Old 27th March 2009, 20:53   #45
Thanked: 252 Times
LOL. gd, does it make sense now?
Never did never will!
Enough people have said the same on this thread.
Big Discounts, Cheap finance schemes : Do they destroy Brand Value? aniketi The Indian Car Scene 26 30th April 2013 09:44
Is this a clutch plate Problem???? The Stig Technical Stuff 15 2nd April 2012 09:29
USB head units destroy pen drives (due to heat?) akash_m In-Car Entertainment 69 30th July 2008 10:24
five by five seismic Introduce yourself 2 10th May 2006 20:31
which is the best 5 star hotel in Mumbai ? adityapd Shifting gears 15 21st February 2006 11:51
