Go Back   Team-BHP > Around the Corner > Shifting gears
Old 7th June 2009, 13:42   #16
normally_crazy's Avatar
Thanked: 389 Times
Why don't you check the router settings, write it somewhere and then reset the router and enter the settings ?
normally_crazy is offline   Reply With Quote
Old 7th June 2009, 13:58   #17
Samurai's Avatar
Thanked: 14,538 Times
Ah, now I remember one more reason it used to happen. I used to keep the Wifi AP on the Airtel router. The heat was causing the speed to drop considerably. Once I kept it separate, the problem went away.
So check whether the router is getting heated.
Old 7th June 2009, 14:03   #18
Takumi-san's Avatar
Samurai is right about the heat. Also keep the router like it is supposed to (sometimes standing on its side for ventilation).
I dont think its a problem with your computer. Its something outside. Any airtel users nearby? check with them. If you / a friend has another laptop , try using your connection with that and see.
Takumi-san is offline   Reply With Quote
Old 7th June 2009, 15:10   #19
Rudra Sen's Avatar
Thanked: 4,150 Times
Router is cold as cucumber and it sits on the table next to my monitor.
Old 7th June 2009, 15:38   #20
Thanked: 83 Times
Rudra, can you post the ADSL Log for your modem? The SNR and Line Attenuation numbers are vital with a DSL connection.
SumitB is online now   Reply With Quote
Old 7th June 2009, 18:01   #21
ph03n!x's Avatar
Thanked: 118 Times
Off the top of my head - I honestly didn't read the whole thread. Am also assuming that nothing else has changed, and this prob just cropped up one fine day...
Is the comp wired or wireless? Pls have it wired to the router, and have the router away from all electronics as possible (incl the monitor). Maybe have the router off for 15 min or so, and then turn it back on.
The modem's log will be off by default (I guess), please have logging enabled. Also, see what it shows on the modem status screen for the link's upload / download speeds...
ph03n!x is offline   Reply With Quote
Old 8th June 2009, 00:43   #22
Thanked: 21 Times
Most probably it is a problem with the upload speed setting at the Airtel NOC side. Also check the SNR settings as suggested by SumitB in your airtel router. There might have been newer firmware's for your router. Check Indiabroadbandforum.in and you will find discussions around newer firmware
LastActionHero is offline   Reply With Quote
Old 8th June 2009, 21:26   #23
Rudra Sen's Avatar
Thanks everybody.
Looks like the problem is sorted out. Airtel didn't call me. Got back home and uploaded a zipped file of 18 mb. Took 3 minutes. Yeah!! I'm feeling good again.
Old 8th June 2009, 21:34   #24
pranava999's Avatar
Thanked: 19 Times
HA ha ha sorted on its own? congrats!!
pranava999 is offline   Reply With Quote
Old 8th June 2009, 22:22   #25
theMAG's Avatar
Thanked: 1,492 Times
It is most likely a problem at their NOC. Nothing to do with your side of the connection. Bandwidth settings are almost mainly software-controlled these days.
OT- Rudra: was that pic taken with a point-and-shoot ?!
Old 8th June 2009, 22:31   #26
Nikhilb2008's Avatar
Thanked: 5,102 Times
I dont think it got sorted on it's own. I think after he logged the complaint, the airtel guys did some checking at their end and fixed it.
Nikhilb2008 is online now   Reply With Quote
Old 9th June 2009, 00:17   #27
nitrous's Avatar
Thanked: 283 Times
I see you're still having those "glass" speakers.
Old 9th June 2009, 06:26   #28
Rudra Sen's Avatar
May be. May be not.
Hold and shoot to be precise. From iPhone.
Surely that's the case.
My old soundsticks still sound better than my Altec Lansing in office.
Arya Honda denies me a TD of New Accord V6 !! EDIT : Now Resolved FlyingSpur Indian Car Dealerships 84 30th July 2010 17:18
Esteem AC Issues (Now Resolved) Edit: New posts added esteem_lover Technical Stuff 79 31st March 2010 13:08
Airtel IPTV, most pathetic service!(Now resolved) tsk1979 Gadgets, Computers & Software 29 4th January 2010 01:38
JBL GTO 1004 Amplifier Woes!!! EDIT - Now resolved rider60 In-Car Entertainment 10 27th July 2009 23:36
Those 10 minutes of my insult in Porsche New Delhi (Now Resolved) sidindica Indian Car Dealerships 77 18th March 2009 16:44
