Go Back   Team-BHP > Around the Corner > Shifting gears
Old 7th June 2009, 10:17   #1
Rudra Sen's Avatar
Thanked: 4,150 Times
Default Internet gurus! HELP!! (Now Resolved)
My home internet connection is behaving in a horrible manner. In fact Iíve been facing this for few weeks now. Download speed is somehow ok but uploading is just not there.
Yesterday I tried uploading some pictures on TBHP but it just wouldnít go. Next came the big surprise. A zipped folder of 33mb took more than 4 hour to upload. Normally it takes around 3-4 minutes to upload a file of that size. Bigger file like 80/90mb takes around 10 minutes and with my other machine (laptop) downloading files at the same time. My connection speed is 2mbps.
I call Airtel. Toll free number 121 from Airtel land line.
Airtelís standard tune..
Your call is important us, please be online..
Our customer support will attend your call soon
After five minutes, customer support comes on line.
Good evening from Airtel. How can I help you?
My land line number is XXXXXXXX and my account number is XXXXXXXX. My internet connection is awfully slow. I think itís behaving worse than a 56kbps connection. May I know why is that?
One moment sir, please be online. (rapid key tapping sound on the background). Am I talking to Mr Rudra Sen?
Yes you are. But what is the problem?
One moment sir, please be online. (rapid key tapping sound on the background). Sir weíll rectify this online. Please go to start.
Which start?
Sir, start on your computer.
You mean I should switch off my machine and start again?
No sir, no sir. That start button on the bottom left on your window.
I donít have any such facility. It is an Apple machine.
Apple computer? Sir we donít support Apple machine.
Is it? Then how Iím using your connection for last 2 years?
Oh, then sir Iím giving you your complaint number. Please write it down sir XXXXXX
So what happens after getting this number? When it will get rectified?
Sir tomorrow is Sunday and engineers are not there. We will send somebody by Monday. Will you be at home around 11 in the morning?
I wonít be at home and I donít think it has anything to do with my computer. I want Airtel to check at their end and probably the junction box outside our building. If thereís a problem with my router then thatís a different issue.
Sir which router are you using?
It is a Beetel 440TXI ADSL2 + Modem.
Who gave you this router sir?
Airtel.
You rented it from Airtel?
No, I bought it from Airtel.
Oh, ok sir. Let me see what I can do for you. Is there anything else sir?
No.
Thank you for calling Airtel. Have a nice evening sir.
Surprisingly I get a call from Airtel in next five minutes. One engineer is on his way.
He comes and says what kind of machine is this? Whereís the mouse?
I give the mouse. He starts keying in. Welcome to Airtel DSL > DSL gateway > System command > System info. And he finds my connection is SLOW indeed. Download speed is 2mbps but upload is 50kbps. He starts making calls. After 15 minutes he tells me that they need to check this issue properly and it could well be some fault somewhere outside.
This morning I check speed again on speedtest.net. It is download Ė 1.44mb/s and upload Ė 0.01mb/s
What do you guys think is the problem?
Old 7th June 2009, 10:48   #2
sudev's Avatar
Thanked: 2,431 Times
If it is not a line problem then most likely some wrong settings in the NOC. Technically all connections are same but the settings at the network end control things like speed / limits etc. If internet is a must always then would suggest but alternate connection hot-plug from reliance/indicom and use whenever such situation arises.
I would suspect the former.
sudev is offline   Reply With Quote
Old 7th June 2009, 10:49   #3
pranava999's Avatar
Thanked: 19 Times
Normally when I have issues with my airtel broadband their service engineers are pretty prompt and competent. So best is to wait for them to arrive and check it out. May require n upgrade of some drivers, etc.
pranava999 is offline   Reply With Quote
Old 7th June 2009, 10:55   #4
Rudra Sen's Avatar
Sir, I'm one those very few who don't understand this technical things. What is NOC here?
Driver? Where? If I remember correct they didn't load any driver on my machine. I'm talking about the time when I got the connection.
Old 7th June 2009, 11:00   #5
sudev's Avatar
No I do not think there would be any issue with driver if the connection is being made albeit slow.
NOC Network Operation Centre. Or exchange for simplicity. (see wikipedia here) This is where they would see if any setting has been (in)advertantly chnaged. Although I am surprised that the engineer did not do ADSL test like noise ratio etc. from your computer to check out if it is a line issue.
Old 7th June 2009, 11:16   #6
Sam Kapasi's Avatar
Thanked: 1,454 Times
Rudra,
Dont let them touch your Mac. If they insist it has ANYTHING to do with your machine, tell them to send an engineer with a windows laptop to show you that it works properly.
Old 7th June 2009, 11:18   #7
Thanked: 135 Times
A normal connection just does not go kaput one fine morning. I would have suspected virus / *ware if it was MS, but with Apple that can be initially ruled out!
What my guess is that they (Airtel) have done some changes at their end, especially since you are having connectivity, but just a slower rate of transfer.
Get them to check the box and settings at their end; modifying anything on your mac should be the last thing to do, only if they are mighty sure that there is absolutely nothing wrong in their side.
HappyWheels is online now   Reply With Quote
Old 7th June 2009, 11:19   #8
Rudra Sen's Avatar
Yes Sam, I thought about this part because it's not technical.
Let's see what they have to say.
Old 7th June 2009, 11:19   #9
condor's Avatar
Thanked: 4,412 Times
Rudra Sen : Bigger file like 80/90mb takes around 10 minutes and with my other machine (laptop) downloading files at the same time.
@Rudra : little confused here. What is the comparison between download speeds on the laptop & the Mac ?
Basic troubleshooting tips I am only re-stating here .. If download is bad only on the Mac, then it would point to either config or hardware issues on the Mac. If it is seen on both, then the connection is the culprit. Either at modem end or the line, or your connection at Airtel's end.
Old 7th June 2009, 11:23   #10
Rudra Sen's Avatar
Condor, both my machine are Apple. There's no real download speed difference between them. Again problem is not much with download as I stated before. It's the upload. It's practically zero.
Old 7th June 2009, 11:27   #11
condor's Avatar
Suggest look at the logs of the modem. If it helps the 'engineers at Airtel, test the connection on a Windows laptop. (or ask them to bring one & test with their machine - if they cant understand your machines).
Also, if you have an unlimited plan, then it is possibly because they have (recently) downgraded the download speed on these unlimited plans. 2 Mbps download speed is available on the regular connections only. (Same with BSNL)
Old 7th June 2009, 11:29   #12
Dear Sir,
I will suggest, wait for a couple of testings more on the line. It is something post your router for sure. If the issue is not resolved, escalate the matters. They should be addressed as soon as possible post escalation, if needed at all. These are silly tech stuff which only someone from that field could explain completely, but completely rectifiable.
@ Condor, the issue is not MAC here. Let's not divert the talk in that direction. It has something to do with the cabling or on the exchange side and has got nothing to do with the connection type or O/S or router.
given2fly is offline   Reply With Quote
Old 7th June 2009, 11:30   #13
Rudra Sen's Avatar
I'll do that. But this is happening after two years of trouble free use. I suspect the problem is somewhere outside my machine.
Old 7th June 2009, 11:30   #14
pranava999's Avatar
Thanked: 19 Times
Oh ok.
I recently had an issue with my connection and low speeds. They reinstalled the whole setup, updated the router,and also security settings and it was back to normal.In any case do update us on what the engineers do and like someone said please be cautious if they are tinkering with a mac especially if they are unfamiliar.
Old 7th June 2009, 11:58   #15
Samurai's Avatar
Thanked: 14,524 Times
Ahem, I have been using Airtel ADSL for 4 years and I have seen this problem before. In fact, they call it to be some problem with the copper. The connection between the router and the POP sometimes get weak/disrupted due to rain. They have standard tools to check this.
Arya Honda denies me a TD of New Accord V6 !! EDIT : Now Resolved FlyingSpur Indian Car Dealerships 84 30th July 2010 17:18
Esteem AC Issues (Now Resolved) Edit: New posts added esteem_lover Technical Stuff 79 31st March 2010 13:08
Airtel IPTV, most pathetic service!(Now resolved) tsk1979 Gadgets, Computers & Software 29 4th January 2010 01:38
JBL GTO 1004 Amplifier Woes!!! EDIT - Now resolved rider60 In-Car Entertainment 10 27th July 2009 23:36
Those 10 minutes of my insult in Porsche New Delhi (Now Resolved) sidindica Indian Car Dealerships 77 18th March 2009 16:44
