Go Back   Team-BHP > Around the Corner > Shifting gears
Old 6th July 2011, 10:19   #46
ghodlur's Avatar
Thanked: 2,257 Times
Angry Re: SBI Home Loan : How long it took ?
Although my SBI loan process went off pretty smooth 2 yrs ago but lately the service of SBI is gone down drastically. Earlier they used to be communicative regarding the change of tenure due to ROI hike/fall but for the past 5 months when the ROI was on a roll there was absolutely no communications.
Long back SBI had goofed up with my Home Insurance and did not give me the policy for about a year or so. When I enquired at the RACPCC they said they lost the cheque, had to issue a new one and be after their backs to get the policy document.
ghodlur is offline   Reply With Quote
Old 10th August 2011, 14:20   #47
markmytravel's Avatar
Thanked: 11 Times
Default Re: SBI Home Loan : How long it took ?
Can anyone tell how many days it takes to get a sms from RACPC when file is sent. Branch manager told me he has send the file to RACPC already but haven't received any sms/call confirming from RACPC. Not sure whom to contact now either?
markmytravel is offline   Reply With Quote
Old 10th August 2011, 15:16   #48
speedsatya's Avatar
Thanked: 706 Times
I have a home loan with Axis Bank ...as of now they looked the best in terms of flexibility and conditions. Also the ROI was similar to SBI .Moreover,processing and other formalities were a breeze with Axis Bank
speedsatya is offline   Reply With Quote
Old 24th January 2012, 19:18   #49
Fortuner71's Avatar
Thanked: 265 Times
Default SBI Home Loan : top up
Any idea how the top up loan works ? what is the interest rate ? what is the maximum amount given ? tenure etc . Appreciate the help .
Fortuner71 is online now   Reply With Quote
Old 9th April 2012, 18:48   #50
Thanked: 66 Times
penpavan, yours is an old post however, this particular line from your post caught my attention,
Originally Posted by penpavan View Post
Max-Gain account is the one you should go for, for the benefits you cannot imagine.
can you give us some first hand hand experience about the benefits? I am also in the process of applying for a loan.
fordday is online now   Reply With Quote
Old 9th April 2012, 19:50   #51
penpavan's Avatar
Thanked: 133 Times
Well it takes some patience to explain it. And I might not be at my best memory now. But what I will say in simple terms is that:
Every month your interest part of the EMI is calculated on the outstanding loan amount. And this outstanding loan amount is = your loan amt - any extra money you have deposited in the loan account. This extra money you have deposited will be available for you to withdraw. If not withdrawn, this will reduce your total outstanding, and thus reduce your interest, and therefore reduce your term.
I have summarized it to the best extend, but don't claim the same if you ask me if it is clear. Try googling. There are a plenty of explanations.
I have benefited from it a lot. I mean it.
penpavan is online now   Reply With Quote
Old 10th April 2012, 07:32   #52
ghodlur's Avatar
Smile Re: SBI Home Loan : How long it took ?
Thats the perfect explanation. I had a MAx gain home loan account from SBI and definitely benefitted from that. Its kind of a current account where the extra money is parked and the interest component is calculated as per the balance in the account. The parked amount is available for withdrawal any time.
Even Stanchart and a few other banks have this type of loan. Even my second home loan will be again from SBI and that too Maxgain only.
Old 10th April 2012, 07:52   #53
bejoy's Avatar
Thanked: 420 Times
How often you could withdraw the amount? I have a MaxGain account and I am not given the operating privileges through net banking. I was told that I can only deposit money to the account and for withdrawing I need to contact the bank. When I login to the SBI net banking portal, I get to see only the loan account. Is it so? What about the 'current' account?
bejoy is online now   Reply With Quote
Old 10th April 2012, 07:56   #54
ghodlur's Avatar
For withdrawing the amount you need to do a net transfer from Maxgain account to your savings account similar to what you do when you transfer funds to Max gain account. Should be possible. Contact your bank branch if its access issues.
The OD account acts like a current account where the interest is calculated on monthly basis on the amount available in the account.
Old 10th April 2012, 09:58   #55
penpavan's Avatar
Thanked: 133 Times
You shall get a debit card and a cheque book on request only after your property is registered and bank completes the mortgages formalities. Not until then.
Old 10th April 2012, 10:53   #56
ghodlur's Avatar
As per my infomation, no cheque book or debit card is issues for the Maxgain account. The Maxgain account is opened/visible only after the loan in sanctioned.
Old 10th April 2012, 11:25   #57
Thanked: 66 Times
Thanks penpavan and ghodlur. I have attached an excel file found in the internet that claim to show the maxgain benefits. Does it actually work like that?
Old 10th April 2012, 11:41   #58
ghodlur's Avatar
Yes it does work that way. For test purposes try inputing an amount every month or an lumpsum amount and see the difference in the Interest calculations and principal repayment.
Old 10th April 2012, 11:44   #59
Thanked: 162 Times
This is not true. I have a check book of Maxgain account. Also, debit card could be issued on request but the Manager was of the opinion that people put large amounts of money into Maxgain hence if the debit card were to fall into wrong hands, it could be used to withdraw large amount of money. He suggested me to open one separate savings account and get a debit card for that account. Transferring money from Maxgain to the SBI savings account is instantaneous (online).
shipnil is offline   Reply With Quote
Old 10th April 2012, 15:36   #60
penpavan's Avatar
Thanked: 133 Times
Not true. There will be a chequebook and a debit card for you. As I said, you can get it only after you register your property and bank gains your sale deed.
I agree. But that's a case with any bank account which will have lot of money. Moreover there is no benefit if you cannot have a debit card on your Maxgain acc. How you will withdraw that extra money you have put?
In my opinion you should take the debit card and cheque book and use it to your advantage. And yes it works exactly like that excel sheet.
The Cheap Loan or the Smart Loan - SBI Advantage Car Loan keyur Indian Car Loans & Insurance 210 3rd January 2018 09:23
SBI Car Loan - My Experience classicselva Indian Car Loans & Insurance 143 21st November 2017 14:54
Car loan SBI or Kotak ? SX4_2007 Indian Car Loans & Insurance 29 28th December 2009 14:26
SBI cuts home, car and retail loan rates dadu Indian Car Loans & Insurance 18 29th October 2007 18:02
