Go Back   Team-BHP > Around the Corner > Shifting gears
Old 17th July 2009, 00:07   #1
whatcanthisbe's Avatar
Default Wierd network Issue - Help Please
I have a DSL connection at home with a Wifi Router, I need to extend the range of this router. the easiest way I could think of was to run a long network cable from the DSL router to another room and plonk in another wireless roter there. Well this should work, since both the routers have been given different names, different SSID's and Channels to work on .
this is how the setup is
DSL Router Port 1 --> Wifi Router A Room 1--> Wired PC & Wifi Laptops
DSL Router Port 2 --> Wifi Router B Room 2 --> PC & Wifi Laptops
Now the Router B does not get an IP (DHCP) from the DSL router. I have swapper out the Wifi Router A & B and the new Setup would be
Scenario 2
DSL Router Port 1 --> Wifi Router B Room 1 --> Wired PC & Wifi Laptops
DSL Router Port 2 --> Wifi Router A Room 2--> PC & Wifi Laptops
Scenario 3
DSL Router Port 2 --> Wifi Router B Room 1 --> Wired PC & Wifi Laptops
DSL Router Port 1 --> Wifi Router A Room 2--> PC & Wifi Laptops
In both cases the Router A does not work.
to eleminate the Cable and the port I hooked up the laptop to the wire in Room 2 and that worked flawlessly,
Scenario 4
DSL Router Port 1 --> Wired Laptop 1n room 2
Scenario 5
DSL Router Port 2 --> Wired Laptop 1n room 2
Can someone please help
whatcanthisbe is offline   Reply With Quote
Old 17th July 2009, 00:47   #2
tsk1979's Avatar
Thanked: 15,683 Times
Do this. First check in the settings whether DSL router, router1 and router2 are all three set to DHCP. If thats the case there could be some issue with DSL router itself, so you have to use Plan B listed below
Select DSL router to connect to internet(I presume its already so), so when DSL router connects, its connected to internet.
Set it to DHCP in settings
Now Connect router1(WIFI) to DSL router.
Connect Router2 to router1 instead of the DSL router.
Old 17th July 2009, 00:58   #3
ph03n!x's Avatar
Thanked: 118 Times
1. Disable DHCP server in both the "extended" routers
2. Change the LAN IP address of both the "extended" routers in the same range as the router connected to the modem (ex. If the router connected to the modem has an IP of 192.168.1.1/255.255.255.0, then change the remaining two routers to have 192.168.1.200 and 192.168.1.250, with 255.255.255.0 as subnet Mask)
3. Connect the Ethernet cables to one of the LAN ports of the router that is connected to the modem
4. Connect the other end of the Ethernet cable to the LAN port of the "extended" routers
What you are doing here is giving the job of assigning IP addresses to computers, and taking them online to the router connected to the modem, while the remaining two are being Access Points- configure wireless SSID/ Channel/ Security as you wish.
Let us know if this works.
ph03n!x is offline   Reply With Quote
Old 17th July 2009, 19:20   #4
Does not work :(
I'll try this out later today and let you know. Thanks. but what could be the root cause ?
Old 17th July 2009, 20:40   #5
Thanked: 245 Times
Another variant to ph03n!x solution:
- Connect DSL Modem - to Router A via Ethernet
- Connect Router A - Router B via Wifi as an AP (Accesspoint)
- Connect your laptop to Router B via Wifi or Ethernet cable
You need to keep the IP address in the same range as explained earlier.
Old 17th July 2009, 21:24   #6
Thanked: 158 Times
For this both the routers should support the bridging option between them and would suggest both the routers are of same model which supports bridging.
gowda79 is offline   Reply With Quote
Old 17th July 2009, 22:21   #7
ph03n!x's Avatar
Thanked: 118 Times
I would suspect IP range. Though the "router" we are talking about are nothing but NAT devices, they cannot route if the WAN and LAN IP addresses are of the same range & class - that is if the WAN IP of a "remote" router is 192.168.1.5, and the router's LAN IP is 192.168.1.1, then it would not work.
I am only guessing, to tell you what is actually wrong in your setup, I would need a hands-on . That said, if you configure it properly the way I have described, it will work.
Old 18th July 2009, 11:50   #8
Thanked: 245 Times
Yes, they will, they do, I connected 2 office networks in adjacent buildings using some very cheap ones, 6-7 years back.
Old 18th July 2009, 12:41   #9
tsk1979's Avatar
Its the IP range conflict I think.
Set the IP of DSL modem/router to
192.168.0.1
Set the IP of the routers in the 192.168.1.XXX series.
So its this way
DSL 192.168.0.1
Router on DHCP(both)
In the router settings where computer connection to router is configured.
router 192.168.1.1, and router 2 is 192.168.2.1
Enable DHCP. computers on DHCP will get IP on their own
Old 25th October 2009, 23:10   #10
bj96's Avatar
Thanked: 129 Times
Unhappy www.team-bhp.com difficulty in access
Facing a huge latency and packet drop in accessing t-bhp website. Other sites looks ok. I am on DataOne @Pune. Anyone else facing this since evening today?
C:\Documents and Settings\xxxx>ping www . team-bhp . com
Pinging team-bhp.com [96.30.20.23] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Reply from 96.30.20.23: bytes=32 time=359ms TTL=50
Ping statistics for 96.30.20.23:
Packets: Sent = 4, Received = 1, Lost = 3 (75% loss),
Approximate round trip times in milli-seconds:
Minimum = 359ms, Maximum = 359ms, Average = 359ms
C:\Documents and Settings\xxxx>ping www. team-bhp . com
Request timed out.
Reply from 96.30.20.23: bytes=32 time=360ms TTL=50
Reply from 96.30.20.23: bytes=32 time=335ms TTL=50
Reply from 96.30.20.23: bytes=32 time=334ms TTL=50
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Minimum = 334ms, Maximum = 360ms, Average = 343ms
C:\Documents and Settings\xxxxx>tracert www. team-bhp . com
Tracing route to team-bhp.com [96.30.20.23]
over a maximum of 30 hops:
1 42 ms 41 ms 41 ms 117.195.32.1
2 43 ms 42 ms 42 ms 218.248.164.38
3 55 ms 54 ms 54 ms 218.248.255.2
4 84 ms 84 ms 84 ms 125.16.156.105
5 85 ms 85 ms * 203.101.100.214
6 354 ms * * so-4-3-0.r21.lsanca03.us.bb.gin.ntt.net [204.1.253.145]
7 * * * Request timed out.
8 338 ms 338 ms 341 ms as-2.r20.dllstx09.us.bb.gin.ntt.net [129.250.2.169]
9 344 ms 342 ms 342 ms ae-0.r21.dllstx09.us.bb.gin.ntt.net [129.250.2.59]
10 364 ms 376 ms 364 ms as-0.r21.chcgil09.us.bb.gin.ntt.net [129.250.3.16]
11 337 ms 339 ms 339 ms po-3.r00.chcgil09.us.bb.gin.ntt.net [129.250.3.9]
12 * * * Request timed out.
13 * * 361 ms 208.79.234.18
14 332 ms 359 ms 337 ms host.team-bhp.com [96.30.20.23]
Trace complete.
C:\Documents and Settings\xxxxx>ping www . google .co .in
Pinging Google [74.125.127.106] with 32 bytes of data:
Reply from 74.125.127.106: bytes=32 time=336ms TTL=51
Reply from 74.125.127.106: bytes=32 time=360ms TTL=51
Reply from 74.125.127.106: bytes=32 time=337ms TTL=51
Reply from 74.125.127.106: bytes=32 time=341ms TTL=51
Ping statistics for 74.125.127.106:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Minimum = 336ms, Maximum = 360ms, Average = 343ms
@Mods: did not want to start a new thread. Merge/Move as appropriate.
Last edited by bj96 : 25th October 2009 at 23:15. Reason: t-bhp website address is expanded into website name
bj96 is offline   Reply With Quote
HELP !!! Wierd issue with home network whatcanthisbe Gadgets, Computers & Software 12 15th December 2011 23:47
Wierd issue with car's speed & engine sounds! lordofgondor Technical Stuff 5 1st December 2010 16:28
Yet another Sony Ericson issue. Its the network this time!!! Shan2nu Gadgets, Computers & Software 8 11th March 2010 12:12
Need Help with Motorcycle Service network AntarAtma Motorbikes 6 26th March 2007 19:50
