Go Back   Team-BHP > Around the Corner > Shifting gears
Old 11th September 2005, 15:18   #1
v1p3r's Avatar
Thanked: 27 Times
Default Help: DVD rip to hard disk
Hey
Can someone point me out to a single piece of software that lets me rip DVDs to my HDD?
Viper
ps. FREEware
Old 11th September 2005, 18:25   #2
Mad Monkey's Avatar
Thanked: 308 Times
http://www.dvddecrypter.com/
Mad Monkey is offline   Reply With Quote
Old 12th September 2005, 02:05   #3
v1p3r's Avatar
Thanked: 27 Times
Ok, this site doesn't work. Can someone please help me out here?! I NEED some wares, and I just can't seem to find a free one that works well.
Old 12th September 2005, 03:01   #4
Ford Rocam's Avatar
Thanked: 16 Times
Hi V1p3r ,
i have utility DVD Decrypter u can rip any dvd to hard drive its size is 366kb only ,very useful i haved ripped many dvd's the best part is that it can detect main movie files so that we can save some space on disk, not necessary to rip entire dvd cause other files has info about subtitles ,5.1 audio,making of movie etc etc, but we can select entire dvd also but that will take space on your hard drive ,
pm me ur email id and i will mail u the utility
Rocam
Ford Rocam is offline   Reply With Quote
Old 12th September 2005, 03:03   #5
revtech's Avatar
Thanked: 35 Times
hey V1p3r
try http://www.dvdecrypter.com/ and not http://www.dvddecrypter.com
notice the double 'd '.i guess it was a typo.
rev
revtech is offline   Reply With Quote
Old 12th September 2005, 07:09   #6
Default dvd shrink
Try using this -> http://dvdshrink.org/what.html and its a freeware
nithi is offline   Reply With Quote
Old 12th September 2005, 17:37   #7
v1p3r's Avatar
Thanked: 27 Times
Ok, thanks guys. The wares worked. Now, though I hate to sound choosy, can someone tell me how to compress the files? Can I use DivX?
Old 12th September 2005, 17:50   #8
cnu
cnu's Avatar
Thanked: 30 Times
To what format does these software rip ?
cnu is offline   Reply With Quote
Old 16th September 2005, 17:24   #9
Thanked: 18 Times
The rippers (dvdshrink, dvddecrypter, et all) would rip the DVD to the HDD. Thats about it. No format conversion. Remove the CSS encryption, break many of the everchanging copy protection schemes that hollywood keeps adding and put the DVD on your hard disk.
To make backup disks, in case you have a DVD writer, you do not need to change formats. at the most split the DVD into two - most of the commercial movie DVDs are double layered while the economical and readily available recordable DVDs come in the single layer format.
In case you want to backup to CD, Divx/xVid would be a good choice.
You would need software like Gordian Knot (freeware) along with Divx codecs to encode the DVD to Divx format.
You can get a lot of info as well as guides on ripping and transcoding at www.doom9.org.
You can always PM me for any specific info in this regard.
manu is offline   Reply With Quote
Old 25th September 2005, 13:09   #10
ScarySkulls's Avatar
Thanked: 19 Times
How to rip dvd's so that it can be burnt on VCDs that run on normal car vcd players...???
ScarySkulls is offline   Reply With Quote
Old 25th September 2005, 18:56   #11
SLK
SLK's Avatar
Thanked: 185 Times
how about alcohol 120%... emulators are less messy!
SLK is offline   Reply With Quote
Old 10th January 2006, 23:09   #12
revtech's Avatar
Thanked: 35 Times
i have a tv serial on dvd..actually on 7 DVDs and want to rip them to my comp.i have a DVD rom but not a DVD writer.please help me.how do i go about it.
Rev
Old 10th January 2006, 23:36   #13
cnu
cnu's Avatar
Thanked: 30 Times
Rev, check out this
http://www.dvd-ripper.com/faq.htm
http://www.dvd-ripper.com/download.htm
Old 11th January 2006, 00:46   #14
Thanked: 21 Times
Rev
Get a copy of DVDDecrypter. The site mentioned above does not work anymore as the author of DVDDecrypter was threatened by Macrovision as they were scared he would crack their new DVD security system.
Anyway if you know where to look it is still available. Try http://www.mrbass.org/ click on DVD ripping. It has a full guide on there. If you want 1:1 copies of the discs just use ISO read mode to copy them as images to your HD. You can then get Daemon tools and mount the image when you want to view it http://www.daemon-tools.cc.
When you open the discs in DVDDecrypter it will tell you how many gig the disc is. If it is single layer then just rip them as they are.
If they are 7/8 odd gig dual layer and you are concerned about them using all your HD space then get DVD Shrink again go to www.mrbass.org and click on the DVD Shrink Guide link and reduce the size of each disc so they fit on a single layer disc (4.4gig). You can download the software from there as well.
bigman is offline   Reply With Quote
Old 11th January 2006, 01:01   #15
revtech's Avatar
Thanked: 35 Times
hey guys
thanx a lot for the help.but i already used DVD decrypter and now i have it on my HD.i dont have a problem with space as i have over 60 GB free space.
the problem is how do i play it.these files are in BUP, VOB and IFO formats.so what do i use to play them ??
Rev
Crashed Hard Disk - Data Recovery? muni Gadgets, Computers & Software 260 6th November 2017 10:59
USB Hard Disk to Home Theater autoenthusiast Gadgets, Computers & Software 0 20th August 2008 21:36
Help to fix my hard disk in my car raajsree In-Car Entertainment 2 30th June 2008 00:37
Need Urgent "HELP" on Hard-Disk ramie2400 Gadgets, Computers & Software 21 31st May 2008 17:34
How to ADD a Hard Disk partition in Vista kb100 Gadgets, Computers & Software 21 14th May 2008 21:13
