Go Back   Team-BHP > Around the Corner > Shifting gears
Old 22nd September 2005, 11:11   #1
sandeepmdas's Avatar
Thanked: 617 Times
Default Wireless LAN protocol
I might need to setup a 50-workstation wireless LAN in a very short notice.
Does anybody know anything about 802.11 (wireless LAN protocol) usability? How fast and practical is it? What brands of adapters and base stations would you recommend? I am told that D-Link is the most preferred brand.
Thanks in advance
Sandeep
sandeepmdas is offline   Reply With Quote
Old 22nd September 2005, 11:30   #2
airfoil's Avatar
Thanked: 66 Times
Get 802.11G equipment, this will support a 54 MBPS transfer rate. My preferred brands are Netgear, Linksys and DLink. There is equiment that supports higher transfer speeds of up to 110 MBPS, which will need compatible adapters and add to the overall equipment cost.
Keep in mind that the transfer speeds with 50 clients on a single wireless network will mean abysmal speeds in a LAN environment, since gigabit networking speeds are available on tap with the use of cables and Gigabit NICs.
airfoil is offline   Reply With Quote
Old 22nd September 2005, 12:13   #3
Thanked: 617 Times
@airfoil, THANKS a lot buddy...
Originally Posted by airfoil
Keep in mind that the transfer speeds with 50 clients on a single wireless network will mean abysmal speeds in a LAN environment...
Will it make any better if I route traffic via multiple (say 5) base stations (in "infrastructure" mode)? I need to route approx 500MB traffic in 8 hours, a conservative estimate...
Old 22nd September 2005, 12:15   #4
Thanked: 1,503 Times
Thanks in advance
Sandeep
Contact Dell - they will provide advice on setting up a Wireless Network for small offices. If you dont want to buy their equipment, you can always use their advice.
Simplest way (fastest and easiest, not the most effective) to set a WLAN would be to get a bunch of Apple Airport Express wireless routers (costs about $ 100 each) and farm it out in the area you want to cover - the one connected to your wired network will be the primary router and all the others will work as repeaters.
Mind you, I know **** all about networks - this is just something I've done.
Steeroid is offline   Reply With Quote
Setting up a Home Wireless Lan ajmat Gadgets, Computers & Software 299 12th October 2014 12:35
OBD Database (Port, Protocol, Cable, Software and Protocol Details) keyur Technical Stuff 11 24th July 2013 12:45
"MOST" Protocol For car AV aks_karthik In-Car Entertainment 2 2nd November 2011 19:08
LAN card to LAN card sharing abhibh Gadgets, Computers & Software 15 21st December 2008 01:55
lan transfers dadudeonfire Shifting gears 25 5th February 2006 05:50
