Go Back   Team-BHP > Around the Corner > Shifting gears
Old 5th March 2010, 18:32   #1
zenx's Avatar
Thanked: 74 Times
Default Low Voltage Woes in Coorg
We're doing a small place in Coorg and thought I'd pick the diverse brains at TBhp to sort out problems we've been having there with the voltage. The area has power cuts every now and then, but the bigger issue is when there is electricity! The voltage is usually 150-180.
Its a naturally beautiful place, so its not really very bright lights for any specific need thats required, but the change in voltage and bulbs dimming (incandescent) or switching off/on (CFLs) can get to one.
We do have solar backup. Was wondering if its possible to somehow use this, or added capacity, to boost the voltage when there's electricity as well ? What other options exist for solving this ?
zenx is offline   Reply With Quote
Old 5th March 2010, 23:25   #2
phamilyman's Avatar
Thanked: 3,454 Times
Saab,
Sorry I can't help on my own. Speak to contacts in Kashmir if you can. I was there recently, and its an endemic problem in the winters (low ice melt and hence low generation). They can advise how they work. There's sunnykashmir paaji on indiamike otherwise!!
Old 6th March 2010, 02:46   #3
greenhorn's Avatar
Thanked: 1,464 Times
I suffer the same problem.
Solution #1. Buy a step up voltage stabilizer. This thing is usually a metal box the size of a UPS. can be used to run induvidual appliances or a few fans/lights (~500VA). The voltage adjustment is manual, like an old fan's regulator knob . Cost = 1K for a 500VA unit
Solution #2. Buy a Servo stabilizer. Same thing, except that the switching is continuous, and done automatically. Pricier & better suited to higher loads. Cost = 10k for a 2KVA unit ( runs my whole house except the fridge & washing machine)
These are trivandrum prices. I suppose you should find them in bangalore (SP road?)
And do specify the input voltage range. Standard is 120~250V, I got mine made for 80~220 ( cost a bit more)
Old 11th March 2010, 17:49   #4
zenx's Avatar
Thanked: 74 Times
@greenhorn Thanks a ton! I'll explore those options. Meanwhile, the 5W CFLs seem to be doing better - less bright but decent, given the conditions.
Meanwhile, a couple of lanterns add to the duties, and inadvertently have added old world charm to the place
Old 18th March 2010, 13:12   #5
Chipz's Avatar
I did not quite get what u meant by this. CFLs have no problem switching at low voltages.
I think servo stabilizers would be good. but they are used mostly for voltage fluctuations to stabilize the voltage.
if you have a low voltage that is constant, a step up would be fine. manual is better than automatic in my opinion. Just tell the manufacturer to make a wide voltage range. you can get a 1 kv for about 5000 rs.
Edit: You will get a 1 KV step up for about 3500 rs or so
Last edited by Jaggu : 18th March 2010 at 14:27. Reason: Back to back posts, please wait for moderator approval to edit the original post.
Chipz is offline   Reply With Quote
Old 31st March 2010, 12:31   #6
zenx's Avatar
Thanked: 74 Times
Thanks! The CFLs - thats from observed behaviour. Dunno if its logical, but the higher wattage ones do not always switch on, but the 5-8W ones do.
Will ask locals about the efficacy of step-up stabilizers and pursue that.
Pune to Coorg (My Eden); Coorg to Pune in a Gypsy - Travelogue Twinn Travelogues 19 2nd December 2017 02:40
Low Voltage Problem in Chennai aravind84 Shifting gears 78 15th November 2015 23:13
Picked up my New Honda City! Update: Low GC & Headlight woes addressed vikash49 Test-Drives & Initial Ownership Reports 90 8th November 2014 18:44
PS3 from US - do i need a voltage transformer?? jassi Gadgets, Computers & Software 85 15th January 2013 01:46
Tata Indica alternator voltage query tsk1979 Technical Stuff 5 9th December 2006 12:45
