Go Back   Team-BHP > Around the Corner > Shifting gears
Old 17th May 2010, 16:05   #1
Rahulkool's Avatar
Thanked: 591 Times
Default Urgent: mumbai members please help with some info
I have driven down to mumbai yesterday from chennai, while going to bangalore the car temp meter was little high from above normal(just 1-2mm, which never used to happen). later in bangalore i found out that a platic bag has gone in the radiator fan, around the hub of the fan. i tried to remove it and taken out whatever i could but still its there.
On the drive to mumbai coudn't find any place(being sunday most of the repairing shops were closed) and temp was mostly normal, only 1-2mm above normal while driving slow.
Can anyone suggest me some good place in mumbai, where i can get it done fast. don't want to go to ASC because they will take too much time. I am staying here next to the HSBC bank on pedder road. planning to take the car tomorrow.
EDIT: forgot to add its a palio 1.6
Rahulkool is offline   Reply With Quote
Old 17th May 2010, 16:20   #2
Thanked: 36 Times
Even if you go to ASC they will take the same time, maybe even sooner.
zaks is offline   Reply With Quote
Old 17th May 2010, 16:21   #3
Wolfheart's Avatar
Thanked: 22 Times
Since it's not a vey complex problem, any mechanic would be able to sort it out. Why don't you call the helpline on (022)28888888 and ask for the nearest auto repair shop. They will give you atleast 4-5 locations based on which area you're calling from.
Wolfheart is offline   Reply With Quote
Old 17th May 2010, 20:54   #4
Rahulkool's Avatar
Thanked: 591 Times
will do that if i am not able to find any good mechanics around. Anyone can tell me which is the nearest ASC here ?
Thats right mate but its fiat, and i have to do 1400kms again few days later so i wanted to know some trustworthy place. don't want to stuck up on GQ because the mechanic forgot to put a screw.
the joys of owning a fiat you know
Woooooooowwwww!! We just crossed 10000 members...EDIT : 30,000 members!!! Samurai Shifting gears 104 9th July 2012 15:01
Urgent help needed. please help-Santro Xing not starting iron.head Technical Stuff 3 12th May 2012 08:27
Pune Members. Urgent help needed Nikhilb2008 Shifting gears 0 7th May 2008 10:33
** Urgent - members in Mumbai please help ** Ashok Shifting gears 2 28th May 2007 10:11
