Go Back   Team-BHP > Around the Corner > Shifting gears
Old 15th July 2010, 09:45   #1
Thanked: 3,849 Times
Default My voice broke! I canít sing anymore. Will it ever come back?
While browsing through the sky kid blog, I was amazed by this amazing article which I wanted to share it here, it makes for a compelling read.
What they probably forgot to tell you or werenít sure how to tell you.
This is very important. Your voice plate has thickened because your body is now producing massive amounts of testosterone. Youíre becoming a young man. Because testosterone thickens the voice plate, it also changes the shape and the audio dynamics of it. Just like taking a guitar and adding another 2 inches to the neck length would change all the dynamics of the guitar, so does changing the thickness of the vocal plate. You would have to learn to play the modified guitar all over again.
Your voice plate is no different. The reason a boy squeaks when he speaks or tries to sing is his minds say to the body, ďOn my cue, tighten these muscles to shape the throat and position the larynx thus, lungs Ė push this amount of air out, mouth make this shape and tongue just get the hell out of the way.Ē The problem is that the mind is playing the old guitar. It needs to reprogram the body for each note.
If you go too fast it canít keep up. (At least until the mind reprograms.) Once the new program is in place you can scream, rap or do just about anything. For now though until your mind is solid on its new commands, you need to sing very slow songs. And sing them softly. You can add volume later. That will make the programming more precise. Learn sloppy and you will sing sloppy. Take the time to learn properly and it will pay off.
My sensei once told me, ďIt is better to practice one time correctly, than a thousand times wrong.Ē( Sensei Katsutaka Tanaka, Alaska , a long time ago.)
Learning is learning. Karate or Singing or anything else worthwhile in life. Learn correctly. Donít try to sing in the voice you had before. That time is over and now you need to focus on the new you; your new sound. Keep in mind that as beautiful as your treble voice was, so too will be your new voice. Whether it is alto, tenor baritone or bass, it is yours. It is still uniquely yours and you need to devote time to making it yours and making it right. Start where it is comfortable. If they all squeak then youíre probably still trying to sing too high.
Just like a child learning to speak. As he focuses the words will get better. You however have a more difficult time because your mind has already been trained one way, so you have to unlearn.
Think about each note and slowly deliver it and you will find a whole voice lacking nothing. And before long, you will have retrained your mind and body. All that you have learned will come into play, so none of it was wasted. It will all add to who your are today. You may be the youngest of men, but today you are man training a manís voice. Just like when you were a treble, it will take time to get that richness and depth in your new voice. Be patient, I know itís tough, but you were a treble. That was tough and you made it then too. You can do this also.
Sing a lot, it gives you something else to do in the shower and the moisture is good for the throat. But remember that rushing it is what confuses the voice plate. The mind and the body must synchronize for harmony to be restored once again. If it remains confused because you rushed it, you may never relearn properly.
So for a while, work on retraining. Do the scales and start at a comfortable level. When you get one you squeak on, take a breath relax the throat and focus on the note. Donít be discouraged if it doesnít come right away or if your mind canít identify or co-ordinate all the muscles perfectly right now. Move on to the next note. As your mind learns adjacent notes which are easier to oscillate, it will learn to step in the same fashion as your previous voice. Remember that it is still growing too so sing slowly and your mind will compensate. Soon it will find the missing note simply by taking the shape of the previous note and stepping the same way it has learned previously, going not to note.
If you had a beautiful voice before, you will probably have one again; different but beautiful nonetheless. Work at it and you will be pleased with what you end up with.
I hope this make sense. Iíve tried to lay it out in a way that is easier to understand. Itís all so ambiguous when the say your voice broke and they are always willing to tell you what happened but few are able to explain the ďwhysĒ and more importantly the ďwhat do I do nows?Ē And itís frustrating because you not only had control but if was special and put you in the limelight. Remember that your hormones make you crazy during this time and your mind and body are also learning new things. Moving is even different because your muscle mass is different. Overnight you stretch out.
The bottom line for you is to do what you can do and be patient. Some guys need to give it some time for the body to quit changing things overnight, before they start to retrain. So go play some sports, exercise helps the body normalize and helps the muscles stretch and fit your new frame. Now is when you will build your new muscle mass. If you want to have that six pack, now is the time to start building it. Remember, youíll want to look good up on that stage when you get up there to sing next.
It would also be a great time to take up a form of martial arts. It may help you to have, ďA sound mind, in a sound body.Ē
sidindica is offline   Reply With Quote
Old 17th July 2010, 03:06   #2
jsrakkar's Avatar
Thanked: 12 Times
Simply Brilliant!
I can't thank you enough for putting this information onboard.
Thanks a ton!
Jaspreet Singh
jsrakkar is offline   Reply With Quote
Lancer in 2L? Makes sense anymore? aalaap Sedans 65 8th March 2015 21:50
Have you ever played full volume of your ICE? Ever?? xingamazon In-Car Entertainment 27 5th January 2011 02:41
Twing-o-twing, I want all my world to sing, I got tupi tupi twing. Honda Jazz sidindica Test-Drives & Initial Ownership Reports 144 12th March 2010 21:57
Will this concept ever come to India? (Trackdays with your choice of Exotics for $$) anilkalvani The International Automotive Scene 11 17th June 2009 22:37
