Go Back   Team-BHP > Around the Corner > Shifting gears
Old 4th October 2010, 23:07   #1
AbhiJ's Avatar
Thanked: 465 Times
Default Technical query : How to find out the rating of a 3 Phase AC motor??
Hello
I have a work related query and google could not help me find an answer, so I thought I take the help of fellow TBhpians..
We have an old 3 phase A.C. Motor at work which does not have any model no./information plate on it. We dont know what is the rating of the motor!!
Our electricians best guess is that it is between 60 hp(45 kw) to 90 hp(67.5 kw). Due to the age of the motor (15 yrs+), he is unable to help us. The motor is in working condition.
Is there any way we can find out what is the rating of the motor in kw/hp?
AbhiJ is offline   Reply With Quote
Old 4th October 2010, 23:42   #2
aargee's Avatar
Thanked: 2,125 Times
ABhi - I'm no expert here, but I can suggest a simple method, but again don't ask me how to extend further.
Switch off all the appliances & run only the motor; note down the time & allow it to run such that it consumes exactly one unit. One unit is nothing but a 60W bulb glowing for 60 minutes. Do the math here or wait for some gurus to throw some more light on this.
This is the best suggestion I can provide you with my limited knowledge, sorry.
Old 4th October 2010, 23:46   #3
Thanked: 143 Times
If the motor is connected to some equipment, check the power requirements / specifications of that (driven) equipment!!!!
There would be methods which require using only this motor as a load through a powe meter (electricity meter) and making calculations based on power consumed. But that would be extremely inaccurate.
Old 5th October 2010, 16:10   #4
AbhiJ's Avatar
Thanked: 465 Times
There is no info on the equipment / motor which I can use...
Can I ascertain the motor rating from idling load? (if motor is disconnected from the machine)
Old 5th October 2010, 17:05   #5
im_srini's Avatar
Thanked: 369 Times
Question
Originally Posted by AbhiJ View Post
There is no info on the equipment / motor which I can use... Can I ascertain the motor rating from idling load? (if motor is disconnected from the machine)
Hi AbhiJ... No, you can't use idling load to determine its fully-rated power. At idle there would be very little "slip" & the motor would settle down at its "no-load speed" - even if you measure it, the current draw would be very small.
You could, however, measure its full-load current-draw & figure out its rated power (not max). Is this motor a squirrel-cage motor ? Maybe you could post a pic, chances are that somebody would recognize it & post the specs.
im_srini is offline   Reply With Quote
Old 6th October 2010, 00:27   #6
AbhiJ's Avatar
Thanked: 465 Times
It is a squirrel cage motor...
Will be posting pictures tomorrow...
Ford to phase out Fusion. EDIT: Now Phased out sukiwa The Indian Car Scene 80 28th September 2010 18:55
News : Ford to phase out Fusion. sanjubaba The Indian Car Scene 1 13th November 2008 10:08
Amplifier rating Vs Speaker rating CaAT In-Car Entertainment 28 31st October 2008 19:32
Delhi HC asks govt to phase out Diesel Cars !! Eddy The Indian Car Scene 128 16th February 2008 20:30
Santro Phase Out ??? sbala Hatchbacks 38 19th December 2007 13:09
