Go Back   Team-BHP > Under the Hood > In-Car Entertainment > Sound Off and Show Off
Sound Off and Show Off Discuss and show your ICE here
Thread Tools
Old 11th September 2006, 13:05   #211 (permalink)
gunbir's Avatar
Infractions: 0/1 (5)
Originally Posted by jkdas
Yeah JK. The santro has ample space there. No spacer needed, as is evident from the pics.
__________________
In My CD Player: Poor Righteous Teachers - Righteous Grooves
gunbir is online now   Reply With Quote
Old 11th September 2006, 17:45   #212 (permalink)
kutlee's Avatar
Thanks Gunbir,
I am planning to install compos in the front on my old Santro. But the shop fellas(i met two shops till now) don't do the cutting. they will do only stock location+MDF plank installs. also will the dimensions of JBL be the same? Why i am asking this is most of the door installs on Santro has a spacer in it. This is the first one without a spacer.
@JK,
I have read the threads you have PMed me(thanks for the same). It took whole my afternoon for reading those. Please PM me on your installation plans. Insane Devil has kindly offered to help me to find someone to do the installation for me.
kutlee is online now   Reply With Quote
Old 12th September 2006, 11:22   #213 (permalink)
sk456's Avatar
JK ..keep some budget for a bit of damping as Santro doors are relatively thinner as compared to other cars...
__________________
Car : Kenwood - Tru - Rainbow - ID
Home : Dynaudio - Krell
In the audio world, adding to the music is the biggest sin.
sk456 is online now   Reply With Quote
Old 12th September 2006, 12:00   #214 (permalink)
jkdas's Avatar
atleast santro is well damped unlike the marutis. I will be damping the doors and boot when I got 3 way in teh future.
__________________
"She may not look like much, but she's got it where it counts, kid."
Old 12th September 2006, 12:21   #215 (permalink)
gunbir's Avatar
JK you're right. Unlike the Swift, the Santro needs only a little bit of damping. SKs install used only 2x sheets of FonoMat ie. Rs440 worth of damping. Of course, sound will further improve if you go the whole hog.
__________________
Old 12th September 2006, 12:27   #216 (permalink)
jkdas's Avatar
and at how much $ are we looking at if we go for avg damping and wher all do one need to in a Santro
__________________
Old 11th October 2006, 01:42   #217 (permalink)
low_bass_makker's Avatar
just did some damping in the front two doors of the car...the midbass a sounding better and the over all sound is much better....
used foam before so that the door panel does not rattle...this option is a cheap alternative....
the foam removed....
the inside done...
the outside done...
the door panel are left right now will be done as soon as possible...
__________________
Looks Can Be Deceiving
low_bass_makker is online now   Reply With Quote
Old 11th October 2006, 01:58   #218 (permalink)
LBM,
Is It DIY Project ??
I Also Have Used Same Wurth Damping Sheet.
How Much Sheets You Have Used ?
Cheers,
Mugen_Power.
Mugen_Power is offline   Reply With Quote
Old 11th October 2006, 02:09   #219 (permalink)
Yes sir It was a complete DIY project did it all myself.....
I have used nearly the complete box which had 3 feet x 1.5 feet four pcs...total of 18 sqft and the door panel are still left out....
__________________
Old 11th October 2006, 08:06   #220 (permalink)
hydrashok's Avatar
LBM, by door panel, do you mean the back of the plastic panel that goes over the door frame? That is uhhh, the plastic panel on which you've fixed the midrange driver?
Really neat job, by the way. Thanks for sharing the snaps. I admire the way you do this stuff yourself. How much did you blow on the Wurth mats?
__________________
Seven are my colours
Many are my lovers
What was three will soon be two
The music will again sound pure and
true
Old 11th October 2006, 11:55   #221 (permalink)
Team-BHP Moderator
navin's Avatar
Nice job LBM .
__________________
Scixelsyd Etinu
Old 11th October 2006, 16:56   #222 (permalink)
rsjaurr's Avatar
I just want to share something which i noticed but i never discussed it here while installing dynamat extreme in my car's door panels.
While my installer was installing door speakers,i was busy with dynamat and putting it on doors.I asked JB[on phone] that should i put dynamat over the panel and also cover the all the wires which r there on door panels.He told me that i need the damp the door and not wires.these r exactly same words which i still remember.
LBM,if i am not wrong u seem to have done which JB advised me not to do.
Other more important thing which i want experts to comment upon is about removing that platic sheet [used for water proffing the door panels]which we remove from door panels to install speakers or damping stuff.[In LBM's pictures no.3,4 and 5 we can see black adhsive material which was left there after removing that plastic sheet]
I did same thing for two doors but i while doing 3rd and 4rth door i removed the sheets 1st without removing that black adhesive material and put dynamat there and re-put the plastic sheet back on its original place.That way atleast my car's 2 doors were more protected from water entering in door panels and damaging speaker.
Below 1st pic is when i damaged the plastic sheet and installed dynamat and 2nd pic is when i put the sheet back after installing dynamat.I hope u can see dynamat through that plastic sheet though i am sorry for poor quality pics.[taken with my old Moto E365 cam phone]
rsjaurr is online now   Reply With Quote
Old 11th October 2006, 18:37   #223 (permalink)
@ Rsj, I Think If You Will keep That Plastic It Will Rattle At Loud Volume.
Old 11th October 2006, 19:43   #224 (permalink)
rsjaurr's Avatar
In my case,there is no such problem,probably dynamat extreme is taking care of that.And i cant see why it should rattle and that too at low volume.
I am not covering speakers with this moisture sheet though..
Old 11th October 2006, 20:17   #225 (permalink)
hydrashok's Avatar
About not covering the wires, I think RSJ and JB have a point. The service guys would rip off the damping sheets without a thought if they need to get to the wires at time.
Or is there some other reason why the wires shouldn't be covered while damping? So, should we disconnect the wires before damping, and then reconnect them over the damping sheets after the sheets are fixed?
__________________
Many are my lovers
true
Thread Tools
Swift Diesel, Saga continues. The DIESEL experience! Part II Jaggu Long-Term Ownership Reviews 217 3rd July 2008 20:25
My DIY Beetle Restoration Saga 71Convertible Vintage Cars & Classics in India 76 20th May 2008 22:45
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425
