Go Back   Team-BHP > Under the Hood > In-Car Entertainment > Sound Off and Show Off
Sound Off and Show Off Discuss and show your ICE here
Closed Thread
Thread Tools
Old 25th May 2006, 22:45   #16 (permalink)
rsjaurr's Avatar
Alpine 9853 has two options to choose from:3-way & F/R sub-W and i have chosen later,2-way one.
As my system is like 3-way,should i choose 3-way system switch[there is a switch on bottom of HU where this can be done] for x-over setting.
Dear JB & Gunbir,u remeber when i told u about this setting?
Crutchfield hands on research says ........
6-Position Digital Crossover with Adjustable Slope: The digital crossover allows you to choose from the following modes:
  • 2-way Mode: A continuously variable 20-200Hz low-pass filter is available for the subwoofer outputs, and a continuously variable 20-200Hz high-pass filter is available for the front and rear preamp outputs. The slope for each filter can be set to 6, 12, 18, or 24dB/octave, or Flat. The level for each filter can be adjusted from 0 to -12dB.
  • 3-way Mode: A continuously variable 20-200Hz low-pass filter is available for the subwoofer outputs, and a continuously variable 1-20kHz high-pass filter is available for the high-range speakers. The midrange speakers have a continuously variable 20Hz-20kHz low-pass filter and a continuously variable 20-200Hz high-pass filter. The slope for each filter can be set to 6, 12, 18, or 24dB/octave, or Flat. The level for each filter can be adjusted from 0 to -12dB.
And acc to its manual......... http://akamaipix.crutchfield.com/Man...500CDA9853.PDF
--The xover switch position for a 2-way system [freq range is divided between highs for front/rear and pows for subw]
--The xover switch postion for a 3-way system whose frq range is divided among the highs[front],mids[rear], and lows[subw].
Sam/JB/Gunbir i need ur help and plz go through pages 17-18 & 45-47 as page 47 is very confusing for me.
rsjaurr is offline
Old 26th May 2006, 03:59   #17 (permalink)
gunbir's Avatar
RSJ... Your system is running in F+R+Sub config right now. This is not a 3way setup!!! To explain further:
A. 3way passive system - You would have a two channel amplifier powering the 3way passive crossover which in turn divides freqs into low (woofer), mid (midrange) and high (tweeter).
B. 3way Active - If you switch your HU into 3way mode, your preouts become High, Mid and Low (instead of Front, Rear and Sub). You will need 1 ch of amplification per driver (separate ch for left tweeter, another for left midrange, another for left woofer or mono sub... and same for right side). So a total of 6ch of amplification will be needed. So in this case, since the crossover is done in the HU, BEFORE the amp, you will not use your passive crossovers. This is a proper active 3way setup.
C. 3way mixed mode - Remove the rear fill and this is sort of what you have now. Your front comps have a passive crossover so they are in passive mode. Your subwoofer crossover is being used from the HU so since it is before the amplifier it is in active mode. So its a combination of active XO and passive XO, together dividing lows, mids and highs. You only need 3ch of amplification for this setup. Of course you have added rear fill also so you are using two more channls of amplification for them.
D. 4way Active - What Im running now. HU has 8 preouts (4 pairs). High, Mid, Low, Sub. so basically 3way front stage + sub, using 8ch of amplification. I am using Hertz HT-20R Ribbon Supertweeters (High), Image Dynamics CD2Comp Neo Compression Horn mid-tweeter (Mid), Hertz HV-165 6.5" woofer (Low) and Image Dynamics iDQ12" Subwoofer (Sub).
Did all of that make any sense?
Anyway, you dont need to run your system active. It is fine as it is.
__________________
This used to be a Funhouse, but now its full of Evil Clowns
gunbir is offline
Old 26th May 2006, 13:38   #18 (permalink)
Originally Posted by gunbir
also have a look at the 'Focal Be' set. Fanatically expensive, but very nice.
Man I have searched for the prices of the componet set they are very well priced. but I am not searching for this type of expensive equipment I dont want to spend $3500 (DOLLARS) on a 3 way componet set
http://www.alpine-usa.com/en/product...model=SPX-Z18T
http://www.utopia-be.com/Products/Number7.htm
For the above speakers I would be needing ur calrion HU and the trutech class A amp for the same. and u know the price of the same.
http://www.bladeice.com/truampaclass.htm
The thing I want is close to ur range of Hertz speaker like I posted earlier
http://www.hertzaudiovideo.com/sched...at=2&numprod=2
Like the above it is in a good price range. If U can suggest in this price range then it is ok other wise I also know how expensive this stuff costs. I am talking about practical thing which I can install.
Sam where are u man I need suggestions.....
Keep them comming..
low_bass_makker is online now
Old 26th May 2006, 14:23   #19 (permalink)
Sam Kapasi's Avatar
Well, then I would suggest buying the Hertz 3 way component system then... Why look for something close to it? I don't understand. You know it sounds good and it's what you want and in your budget right?
I haven't heard them, but if JB and Gunbir say it's good, it's good.
__________________
“I am matter and you are matter, but it doesn’t matter.” – Captain Beefheart
Sam Kapasi is offline
Old 26th May 2006, 14:28   #20 (permalink)
The one u are using how much is it for and any other models u can suggest me price in not a issue here can go above that one also. The kappa u r using is it avalable in india.... and info about it .....
Old 26th May 2006, 15:12   #21 (permalink)
Sam Kapasi's Avatar
The picture i posted.. that is the Kappa 1.7CS, this is for 17,990/- with BW
There is also the Kappa 1.5CS this has a 6X9" woofer along with 4" midrange and tweeters. This is also for 17,990/-
__________________
Old 26th May 2006, 15:30   #22 (permalink)
are u using them and how do u feel them playing , any place from where do i get them in delhi. Last but not the least I u have installed them in ur car can I see the pics of the same...........
Old 26th May 2006, 16:17   #23 (permalink)
Sam Kapasi's Avatar
No I am using similar components, but 2 way, in my car.
__________________
Old 26th May 2006, 20:32   #24 (permalink)
I am also interested in 3 way any one here can give some info.
MEISTERSTUCK is offline
Old 27th May 2006, 03:17   #25 (permalink)
gunbir's Avatar
The Kappa 2way we heard in RSJ's getz was quite nice. I'm sure the Kappa 3way is an excellent product as well. LBM, I suggest you audition them. Sam can tell you where.
__________________
gunbir is offline
Old 27th May 2006, 03:45   #26 (permalink)
gunbir's Avatar
The thing I want is close to ur range of Hertz speaker like I posted earlier Like the above it is in a good price range. If U can suggest in this price range then it is ok other wise I also know how expensive this stuff costs. I am talking about practical thing which I can install.
LBM apart from Infinity Kappa and Hertz I cant really recommend much out there. We have heard the Canton 3way available, not too impressed. There was a Blaupunkt 3way set (copper coloured cones) we used some way back in 2002. I think they are still around. They sound nice and balanced but dont have much power handling. They will not be able to keep up with your sub section.
As for our 3way sets. The HSK163 is not the only one. At this time we have 4 sets available in India ranging from 11k to 29k. We have higher models as well ranging upto 1.30 lakh but as you can imagine, these are only on special order.
You can download more information here. And you are welcome to audition any of these at a dealer.
__________________
gunbir is offline
Old 27th May 2006, 11:39   #27 (permalink)
Sam the Man from where do can I listen to this kappa. Plz give any phone or address u have man..............
Old 27th May 2006, 13:50   #28 (permalink)
One more thing placement of the mid range in swift................
This is bugging me the most..............
Old 27th May 2006, 16:40   #29 (permalink)
Bass&Trouble's Avatar
LBM
Thats a nice choice. This set will work well for you. Those are scanspeak drivers and used in some of the best speaker systems made. also have a look at the 'Focal Be' set. Fanatically expensive, but very nice.
The 545 is a wimpy amplifier for this application. Get a good 2 channel amp with atleast 200w cont into 4 ohms per side.
Alipne F1 series, full orgasm speakers. Only, the crossovers are sooooo damn bigggg!
Yeah, the 545 is not a good mate for the F1 3-way. You need a nice clean 2-ch amplifier with loads of juice to power up that set. In fact, for any good 3-way component, use either a powerful 2-ch amp or a 4-ch in stereo bridged mode.
__________________
Losers Commute. We Ride.
Bass&Trouble is offline
Old 27th May 2006, 19:15   #30 (permalink)
gunbir's Avatar
LBM your best option would be on the A pillar. I know the interiors of the Indian Swift are different but the A pillar should be the same. With some modifications you could fit a dome midrange there.
__________________
gunbir is offline
Closed Thread
Thread Tools
the saga - Camry AT rajtheindian Test-Drives & Initial Ownership Reports 13 5th November 2009 01:32
The Getz Saga sunil.nv Test-Drives & Initial Ownership Reports 22 10th August 2009 13:11
My Used Cars Saga ramzsys Long-Term Ownership Reviews 27 31st July 2009 19:15
Saga Of Palio 1.6 Breakdown eclectix 1st Long-Term Ownership Reviews 151 27th May 2008 12:36
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
