Go Back   Team-BHP > Under the Hood > In-Car Entertainment > Sound Off and Show Off
Sound Off and Show Off Discuss and show your ICE here
Thread Tools
Old 18th August 2007, 11:22   #16 (permalink)
low_bass_makker's Avatar
Originally Posted by panky12345 View Post
Sorry for going OT: is there is a bass control for JBL 301.1? I'd love to have it in front cauz lot many times I just want to hear a song with little to no bass.
Panky ji there is a direct button on the 7950 for the Sub woofer setting...you can adjust it from there..
__________________
156.6 db, naa....time is coming to cross it......
Old 18th August 2007, 12:58   #17 (permalink)
rocksterraghu's Avatar
Even I had a query regarding this.
There is an optional RLC - Bass control that can be used with GTO series monoblocks and GTO755.6.
It looks like this:
Sam bhai, can I buy this and use it with my CS300.1?
As per my understanding, it is just RCA input from HU and RCA output to the amp and can be easily installed. But I was wondering why it is not recommended?
__________________
Everything should be made as simple as possible, but not simpler
Old 18th August 2007, 13:09   #18 (permalink)
panky12345's Avatar
LBM bhai, aap mere ko 7950 kharidwaa ke hi dum loge!
How about settings? First I tune AMP (which would remain static by and large), then HU (variable)??
__________________
SINGH IS KINNNNNNNG..
Old 18th August 2007, 13:13   #19 (permalink)
panky12345's Avatar
It looks like this:
Is it universal? I have one from audiobahn that came with my audiobahn (crap) amplifier. Will it fit?
__________________
Old 18th August 2007, 13:27   #20 (permalink)
Is it universal?
That was my precise question to Sam bhai. See this link:
http://caraudiosecurity.com/shop/pro...ts_id/333.html
I was wondering why only the GTO amplifiers were mentioned, while all it does is connect through RCAs on both ends
Anyway, I'll leave this to Sam bhai. I am waiting with my card ready to be swiped if he says there will be no issues in using it with CS300.1.
By the way, I think we're hijacking this thread. Sorry mods, please move this to the 'Product Discussions' section if you wish to, thanks.
__________________
Old 18th August 2007, 16:58   #21 (permalink)
Sam Kapasi's Avatar
E
It looks like this:
Because baba, it is connected to the amplifier, not the HU. There is a specific jack used between the RLC and the amp (not RCA but a registered jack RJ14, similar in size to RJ11 )
This RLC (remote level controller) can only be used with these monoblocks
  • GTO301.1
  • GTO601.1
  • GTO1201.1
  • BPX2200.1
    and
  • The six channel amp GTO755.6
It cannot be connected to the CS300.1.
Moreover, though these are sold seperately, till stocks last, these are given FREE with the above monoblocks. (755.6 is not sold in India officially)
__________________
Live the YetiLife®
MA-DONNA! MA-DONNA! MA-DONNA!
Old 18th August 2007, 17:41   #22 (permalink)
vikram18's Avatar
Looks real nice...when do Puneites get a demo?
vikram18 is offline   Reply With Quote
Old 18th August 2007, 17:46   #23 (permalink)
Thanks for the clarification Sam, I think I misconstrued this statement:
"Connects in-line between stereo and amplifier using standard RCA cables"
given here: http://caraudiosecurity.com/shop/pro...ts_id/333.html
The site may have mentioned that by mistake.
__________________
Old 18th August 2007, 18:53   #24 (permalink)
panky12345's Avatar
SAM, given your above reply.... Can I use my audiobahn wala control in my JBL 301.1 if I connect it to the amp replacing the jack?
__________________
Old 18th August 2007, 22:38   #25 (permalink)
NO (20 character)
__________________
Old 19th August 2007, 08:58   #26 (permalink)
panky12345's Avatar
NO (20 character)
WHY? dont you think rest everything is same, only jack is different?
__________________
Old 19th August 2007, 10:20   #27 (permalink)
Team-BHP Moderator
navin's Avatar
No! if it does it is a pure accident.
__________________
Scixelsyd Etinu
Old 19th August 2007, 14:18   #28 (permalink)
the internal wires wiring could be different...
__________________
Old 19th August 2007, 14:49   #29 (permalink)
panky12345's Avatar
Then how could i find without installing Dr. LBM?
__________________
Old 19th August 2007, 16:57   #30 (permalink)
Team-BHP Moderator
DerAlte's Avatar
@Panky-bhai may just be right - that the difference could be only that of connector. Wouldn't one expect a simple poti inside that box? That is, only a simple variable resistor in series at some point in the amplification chain (wiper connected to one end, 2 pins effectively), or a traditional volume tap-off on the signal (3-pin connection). Passive component, no power; also perhaps there are no L or C components inside this box.
If it is the first one, then no luck, @panky-bhai, even replacing the connector will not make a difference . Unless, that is, the poti is wired like the second case internally, in which case the RJ connector is to prevent misuse / confusion and simplify wiring for the JBL mono-blocks.
If it is the second case - then it is only a matter of using the right connector for signal-in and signal-out. You could check how the connectors are wired in the Audiobahn one with a multimeter - resistance measurement.
1. There would be continuity between Input ground and Output ground (i.e. resistance < 1ohm), but variable resistance between the Input and Output signal pins
2. The resistance between the ground and the Input signal pin will NOT vary when you move the knob
3. The resistance between ground and Output signal pin will vary as you move the knob, from almost zero (Min position) to same resistance on the Input side (Max position).
If the above is true, then the Sub-out signal from HU could be wired to the Input of the Audiobahn poti, and the Output to the amplifier. I might be completely wrong, par try karne mein kya harz hai, hai na sir?
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Thread Tools
ICE setup for civic sanchits Ask the Gurus 41 13th January 2008 10:23
ICE Setup in my Baleno shadyrulez Sound Off and Show Off 14 31st December 2007 06:42
ICE Setup for Safari drifter Ask the Gurus 64 3rd December 2007 11:36
need a good ICE for my elantra super_700a Ask the Gurus 8 20th June 2006 08:50
XETA's ICE Setup. wolfinstein Ask the Gurus 46 5th June 2006 09:19
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
