Go Back   Team-BHP > Under the Hood > In-Car Entertainment > Sound Off and Show Off
Sound Off and Show Off Discuss and show your ICE here
Thread Tools
Old 13th November 2007, 15:25   #181 (permalink)
clipto333's Avatar
hi,
congrats gill saab. im jealous. lol. keep it up.
you are clear enough gill saab. i was just asking :-) its good to hear when one knows the importance of the sub. some people think its just show off.
what are your plans now? what amp and sub are you planning to get? an idq12 with the new audison srx class-d huh? i think you should first try the sub on your 75.4. im sure you won't be disappointed.
one thing you can do is to get a 4ohm dvc and power it using the 4 channels bridged so that you have 284x2. get a good 4ch amp for your speakers. i think that will be good. you will have around 500w for the sub.
cheers
clip
clipto333 is offline   Reply With Quote
Old 13th November 2007, 16:07   #182 (permalink)
Gill's Avatar
Default AMP for SUB?
The sub is rated at 100w-600w RMS,Which amp should i opt for a dedicated mono or 2 channel bridged?I look for options between 12k-15k for amp.The amp has to selected so that i can take a call for 2 ohm dvc or 4 ohm dvc.
How about alpine MRD 1005 amp i am getting one used.
Cheers!
__________________
Experience is the worst teacher; it gives the test before presenting the lesson.
Gill is online now   Reply With Quote
Old 13th November 2007, 21:03   #183 (permalink)
clipto333's Avatar
Cheers!
gill,
you have 284+284w to drive a 4ohm dvc. it is more than enough IMHO. why do you want to buy a sub amp when you have a very good amp? there is nothing wrong in using that amp(jbl gto 75.4) just make sure that the gains are matched perfectly and that is not that difficult at all. some amps have a switch(like in my case - a pio 944) to run in 2 ch or 4 ch mode. i don't know if your amp has this.
the components needs better amps IMO. better as in sq wise as amp distortion or clipping is more pronounced in that frequency range.
you need a good and powerful amp for the comps as well. 75x4 will be good and 100x4 will be excellent. why dont you get the kenwood 8401. it will be quite cheap and according to gunman, it has good sq and i would not doubt gunbir for that.
if you need a more powerful amp, go the audison way. dont waste your money on the amplification for the rear fills if you don't listen to them. this way you can save alot and get the best amp possible in your budget.
if you still want to upgrade, get the lrx 5 channel class ABD amp.
and gill, you are doing a great job of upgrading. install the HU right away so that you know the difference it makes in sq. its better to upgrade in phases. that way you know what difference a component makes.
and please let me know if you are willing to sell your HU. i will buy it definitely and don't you dare sell it to anyone other than me.
cheers
clip
Old 13th November 2007, 21:51   #184 (permalink)
Gill's Avatar
Originally Posted by clipto333 View Post
gill,
cheers
clip
Clip,
What i have in mind is to go for a dedicated AMP to drive IDQ15" in sealed box,and then shall save for next upgrade a good 4 channel amp for the speakers,and will sell 75.4.
I am aprehensive about 75.4 doing sub duty,as in current setup driving the front compos and sub it gets quite hot.Running on full blast in bridged mode for IDQ 15" will drain the amp.What's your view.
May be Gunbir might be able to throw somelight on this.
In Low freq range 20hrz-200hrz how much importance does AMP's efficency plays!!!!i.e. amp working on 4 ohm load and same amp working on 2 ohms load!
As far as sub section goes there won't be any upgrade or change in future,considering this plz advice about the DVC and amp!
Cheers!
__________________
Old 22nd November 2007, 18:11   #185 (permalink)
Gill's Avatar
[/IMG]
Saw this in one of the installs,what's the reason for the use of such a thick cable for the SUB if i am not wrong it's 8gu wire.
What's the pro's or con's of using it.
Cheers!
__________________
Old 22nd November 2007, 18:18   #186 (permalink)
rocksterraghu's Avatar
Originally Posted by ScarySkulls View Post
Upgrade already decided guys.
I always knew you couldn't keep a Jatt and a grand daddy 15" IDQ too far away for too long. hehehhe........
Quest for new Sub Amp and better HU remains now!
Another one bitten by ICE bug. So, when are we getting to see the pictures?
Great choice Scary! Congrats!
__________________
Everything should be made as simple as possible, but not simpler
Old 22nd November 2007, 18:25   #187 (permalink)
gunbir's Avatar
Saw this in one of the installs,what's the reason for the use of such a thick cable for the SUB if i am not wrong it's 8gu wire. What's the pro's or con's of using it.
Well as explained in the original thread, the 8ga was used here just for aesthetic reasons: It looks cool!
No cons I can think of except unnecessary cost added only to make it look better. But since installs of that kind don't have a limit on cost, its not an issue.
__________________
Playing in my CD player: Beats International - Let Them Eat Bingo
gunbir is online now   Reply With Quote
Old 22nd November 2007, 19:53   #188 (permalink)
vebmetal's Avatar
Must be a nice feeling......
__________________
People who talk in metaphors ought to shampoo my crotch.
-Jack Nicholson
As Good as It Gets (1997)
vebmetal is offline   Reply With Quote
Old 22nd November 2007, 20:03   #189 (permalink)
Blessings lad! You'll get there one day!
Old 30th November 2007, 12:10   #190 (permalink)
Gill's Avatar
Need your inputs for this:-
DO i need to reset the gains for the amp,as i am replacing the HU to Alpine and it has got 4v preout where as kenwood had 2v.
Cheers!
__________________
Old 30th November 2007, 12:35   #191 (permalink)
@Gill - I think you need to reduce your gains before switching on the new HU.
__________________
The most exciting phrase in science is not "Eureka" (I found it) but probably "That's funny...."!
nura is online now   Reply With Quote
Old 30th November 2007, 13:32   #192 (permalink)
Gill's Avatar
Went to local shop,for installing new HU,it's kind of best out here,that guy didn't have any idea of installing this HU.He tried it.His tiral was more of experiment then a demonstration,so i came back.
Anyone who has idea about installation of this HU plz guide.I will do it on my own!I am using the manual of 9887.Help will be appreciated ,otherwise it will wait for CLIP to come n help me out!
Cheers!
__________________
Old 30th November 2007, 14:56   #193 (permalink)
NIP
NIP's Avatar
gill...are you selling your older kenwood 4036 HU ? i'd be interested
__________________
Jeeping - Rock, not Rice!
NIP is offline   Reply With Quote
Old 30th November 2007, 20:17   #194 (permalink)
clipto333's Avatar
Cheers!
gill,
i suggest you wait. don't get it installed by a person who doesn't know how to. i can come to chdg and we will find a good place to install the HU. ill get your enclosure as well.
That HU is in my car dude. :-) already bought it. But i don't know the price still. lol
Old 30th November 2007, 23:47   #195 (permalink)
Gill's Avatar
gill,
Ok clip, will wait for you.Your are bringing the enclosure,that's great ,.From where???.
@NIP,Now Clip(Rishaab) has the hu.But if you are on budget plz buy it,I will Vouch for this HU.Great Value for the price.Sound reproduction is good when compared to price it commands!
Cheers!
__________________
Thread Tools
My First ICE DIY Install in my swift. rider60 DIY - Do it yourself 17 9th July 2008 01:07
Projector setup on Swift & Some DIY also.... low_bass_makker Modifications & Accessories 26 14th May 2008 11:04
DIY Swift Audio Setup.with the help of some friends. navpreet318 Sound Off and Show Off 76 13th January 2008 15:38
DIY amp install query! dr.abhijeet Ask the Gurus 3 13th September 2007 13:01
DIY Install in My Fiat Palio. moralfibre DIY - Do it yourself 115 15th August 2007 18:57
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
