Go Back   Team-BHP > Under the Hood > In-Car Entertainment > Sound Off and Show Off
Sound Off and Show Off Discuss and show your ICE here
Thread Tools
Old 10th April 2008, 14:26   #76 (permalink)
Team-BHP Moderator
navin's Avatar
Originally Posted by BHAGWAN View Post
You [Navin] should be the best Judge !!
a] You are the 'M' [hence knowing all] !!!
b] You have heard both.
1. Agreed I am the best judge, just like each one of us is the best judge of what we want.
2. I not not M, I know I am a moderator but if you ask Sam and co they will tell you that I really came to TBHP to learn. "They" promised me riches, heaven and 72 virgins if I became a mod, liars! ;-) LOL. Just Kidding. in any case I really think I have a lot to learn from the Gurus and Pros here. Many here are more passionate and knowledgeable than me. Let me be the first to admit that. Hence I dont think I can be compared to 'M'.
3. I have heard both. I think the clam shell is an excellent design, better than my exisitng sub for sure. I wish the bass was tighter still, but like you said (when we heard the sub) the program material must also be good to expolit the sub.
The problem is I have heard OB and TL (Bud Fried) and good horns (Belle Klipsch / La Scala) and my ears long for the slam of horns, with the colourlessness of OB and the delicate definition of TL. I want it ALL and cheap too! For the past 20+ years I have been chasing this holy grail.
I tried mating K33 (drivers used in the La Scala) to Maggie SMGas, 2245s at home/TL's in my car, "Linkwitz Transformed" sealed boxes, Vifa/Scan Speak, Focal, Morel, Dyn; everything but IB (I dont think my neighbours would be too pleased if I tried IB) but so far no dice.
You wont believe how mad I got; I had given up, got myself ipods, Beyer 880/AKG 701 and Air heads and figured the holy grail was just a dream. Now thanks to TBHP and guys like you, I am begining to believe again.
__________________
Scixelsyd Etinu
Old 10th April 2008, 14:42   #77 (permalink)
BHAGWAN's Avatar
Infractions: 0/1 (4)
One must always believe in ones self & remain 'passionate' about things that one loves to do !!
'M' = Moderator
__________________
'bhagwan'
'B'
Mumbai - India
BHAGWAN is offline   Reply With Quote
Old 10th April 2008, 14:56   #78 (permalink)
Team-BHP Moderator
DerAlte's Avatar
...'M' = Moderator
Oh shoot! When you had written "a] You are the 'M' [hence knowing all] !!!", I had myopically speed-read it as "a] You have the 'M' [hence knowing all] !!!" and sagely nodded "Yeah, Navin has a LOT of M to have done what he has done".
My bad, muy bad, muy muy malo!
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 10th April 2008, 15:03   #79 (permalink)
Bass&Trouble's Avatar
'B' thinks is of zero importance.
Team Bhp does not permit profanities whether said openly or closedly or something like that. Just to bring to your notice befoe you start calling people 'C' or 'G'.
__________________
Operator! Give me the number for 911!
Bass&Trouble is online now   Reply With Quote
Old 10th April 2008, 16:19   #80 (permalink)
Team-BHP Moderator
DerAlte's Avatar
You have mastered the art of innuendo!
__________________
Old 10th April 2008, 16:53   #81 (permalink)
clipto333's Avatar
I really still don't get the connection between a birth sheet and the amp being over or underrated.
If you buy an amp rated at 100 x 2 and you get a birth sheet saying, 125 x 2, I suppose you mean to say that you would be excited to buy an "underrated" amp. Within certain parameters, I would perhaps refuse to accept the amp or write off the birth sheet as a gimmick.
Because of common sense.
why does a manufacturer underrate its amps? i would like to know that.
clipto333 is offline   Reply With Quote
Old 10th April 2008, 17:19   #82 (permalink)
Originally Posted by low_bass_makker View Post
I think you need to be very carefull with the Stegs they are quite underrated for what they can produce.
Manufacturer provides precise wattage under a given set of circumstances. If you change the circumstances, or the circumstances of normal operation are different from those during measurement, then the output power may be lower or higher than rated by a reasonable extent. In which case, the amplifier can be termed as overrated or underrated respectively, right?
Please note LBM's statement above which says "they are underrated for what they can produce". This is a caution to the user. The user may not use the amp in the same circumstances as that when the amp was measured and rated. Hence he may end up sending more than the rated power. Confusion solved?
__________________
Old 10th April 2008, 17:42   #83 (permalink)
clipto333's Avatar
Ok. The steg has a regulated power supply and the manufacturer says it maintains the same output regardless of the voltage conditions. In that case, can it produce more output than rated?
Old 10th April 2008, 20:25   #84 (permalink)
clipto333's Avatar
Ajay Bhai now I am used to it as I am the most inexperienced one here
Clipto I had a Alpine 545 4 channel amp it had a birth certificate with it. It was rated 125 x 4 but at the certificate it was written 169 rms watts.
Maybe it was true but I found that Steg which is rated at 80 watts was more louder and cleaner when compared to Alpine hence the statement .
Lbm,
i asked this because of my inexperience with high end or any end equipment. i have had chance to listen to very few good setups and that too for a short period. Its becuase you have good equipment and the amp you are talking about, i asked the question.
if ever i doubt you or anyone, i would say it directly.
Let not discuss it here anymore. Its Bhagwan's thread so lets just discuss his Ice.
cheers
clip
Old 10th April 2008, 21:28   #85 (permalink)
BHAGWAN's Avatar
Unhappy forget talk - listen to it !
p
Sir,
Thanks !
Forget discussing;
First listen, then comment !
__________________
'bhagwan'
'B'
Mumbai - India
Old 10th April 2008, 21:37   #86 (permalink)
In that case, can it produce lesser power than rated? Yes it can. Reduce the input signal level.
Power output is not just a function of the supply voltage.
EDIT:
Forget discussing;
I have listened. Hence I shall comment.
__________________
Old 10th April 2008, 21:45   #87 (permalink)
BHAGWAN's Avatar
That is correct, only B & T has 'heard' the RS so far.
The work is to happen, we need to complete the damping on the front right door & the tweeter position has to be finalised along with the polarity !!
I wish more would listen;
__________________
'bhagwan'
'B'
Mumbai - India
Old 10th April 2008, 22:14   #88 (permalink)
Eddy's Avatar
Will this car come to Delhi anytime by any chance? I would love to listen
__________________
Daily Ride: Swift VDI (ABS) - Silky Silver - Sep07 - 21,000 kms.
Family Ride: Ford Ikon Flair - Black - Sep04 - 47,000 kms.
Eddy is offline   Reply With Quote
Old 11th April 2008, 10:28   #89 (permalink)
Team-BHP Moderator
navin's Avatar
Originally Posted by DerAlte View Post
...and sagely nodded "Yeah, Navin has a LOT of M to have done what he has done". ...
1. being a Moderator does not make one a Guru. Gurus know. Moderators are just here to keep the peace.
2. I wish I had M. I really do. When I got into DIY it was to save M.
I will, when it is done. I dont want to listen to a Work In Progress as it si not fair to the installer.
__________________
Scixelsyd Etinu
Old 11th April 2008, 12:16   #90 (permalink)
BHAGWAN's Avatar
Thumbs down Nice Try !!
Nice one sir;
This RS gives me an average of 4 that too on 97 Octane.
Who would drive Mumbai to ND when I could fly there @ the cost of 1/2 tank of fuel !!!
__________________
'bhagwan'
'B'
Mumbai - India
Thread Tools
Skoda Superb ICE: Steg/ Illusion Audio/ Alpine Bass&Trouble Sound Off and Show Off 55 19th April 2008 14:03
ICE install in SKODA RS cartouch_56 Sound Off and Show Off 20 11th April 2008 22:11
Optima Battery Installation for Skoda RS in Calcutta blueraven316 Modifications & Accessories 10 12th February 2007 16:22
My Optima Yellow Top died! low_bass_makker Technical Stuff 22 25th June 2006 21:18
ICE upgrade for Skoda karthik247 Ask the Gurus 34 22nd March 2006 22:31
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425
