Go Back   Team-BHP > Under the Hood > In-Car Entertainment > Sound Off and Show Off
Sound Off and Show Off Discuss and show your ICE here
Thread Tools
Old 18th March 2009, 23:43   #1 (permalink)
stefanm's Avatar
Default Pure High Energy Super Natural Sound tightly on Safari
Just about finished my install for my Tata Safari, still need to fit some sound deadening and possibly go for an active front end as and when I get my Genesis profile 4 repaired.
Current specs, sounding quite respectable to my ears:
Subs-2no Hertz High Energy Hx250d Subs, wired to 1ohm
Front End-Rockford Fosgate P162s Components with the (stupid & Harsh,imo, although nicely tamed now) twin drive tweeters mounted near the stock locations
Rear Fill-Same as the front, but mounted currently coaxally
Head Unit-Alpine 9887 (USA version)
Front End Amplifier-Genesis Profile 2 (75wrms per channel, Pure Energy)
Rear Fill Amp-Head unit for the time being
Sub Amplifier-DLS A6 (Class A-1200wrms minimum@1ohm, Super Natural Sound)
I intalled all these components back in December, the fronts and rears in the stock locations mounted in the door card plastic, for the subs i built a custom double sealed box to fit in the dickie of the Safari whilst allowing the jump seats to be usable(very tight fit). One amp under each of the passenger seats.
The sound lacked mid bass and the tweeters were harsh, i was extremely dissapointed with the sound, i spent a good two days tuning the head unit and tweaking the gains to no avail, in the mean time i had made some speaker rings from 18mm mdf and glued 4 together, with the intent of mounting them to the steel of the door card, but was very sceptical about chopping the door cards up to install the speakers to the door. Afterapprox 2 months of dissapointment I decided enough is enough, started measuring the speaker pods and distances from the metalwork, then i cut the speaker rings at an angle to suit the Safari's door card for minimum cutting, then pre drilled the baffles, coated the baffless with silicone and then screwed self tapping screws into the metalwork, next i had to cut the speaker pods, trying to get a perfect flush fit was difficult, so i have some gaps between the door card and the speaker, this i will tackle when i get around to damping the front doors. I also moved the front component crossovers next to the Genesis, to allow me to go active if i choose to take that route.
The result was a major transformation in the sq, the mid bass came alive the tweeters sounded slightly less harsh, but still not to my liking, so I started fiddling with the parametric eq on the 9887, at this point i didn't realize that you can change the frequency on at least bands 1,4 and 5, after 20mins of tuning i discovered this by chance, the outcome of this was that the tweeters were very harsh at 4khz, amazed at my discovery, double checked my time alignment and crossovers etc and had the whole thing singing like a bird after 20mins. now i'm quite impressed with my set up, the sound is clear, balanced and most importantly the tweeters no longer give me ear/head ache
Next damping is required, i have rattles from the newly discovered mid bass, if i get my P4 up and running, will do the same mod for the rear doors and mount the tweeters low down, just above the woofers, as the rear door card has a nice flat area just above the speaker pod.
At this point i am very happy with my system, the bass hits hard and fast, the tweets are lively and sounding smooth, not biting anymore, not quite laid back, but balanced, the mid bass has a good kick and the front end has good stereo separation and the bass is sounding forward rather than coming from the rear, all seats, except the jump seats enjoy a rounded sound coming from the front.
Will post a few pics soon, if anyone requires specific picture requests please ask as i don't want to remove the door cards again unless i really have to.....
Stefan
stefanm is offline   Reply With Quote
Old 19th March 2009, 02:48   #2 (permalink)
abhinav.gupta88's Avatar
Congrats on the Setup.
Waiting to see some pics of the complete WIP and after work install.
Click all pics including damping, wiring , compos , spacers if any, stripped door, enclosure , sub , amp placement , etc.
__________________
vRs(q)® | ECLIPSE CD7200 MKII | Illusion Carbon ND-6 | Harman/Kardon CA470 | Harman/Kardon CA1500M | Stereo Integrity MAG D2 V4
abhinav.gupta88 is online now   Reply With Quote
Old 19th March 2009, 10:44   #3 (permalink)
shreyasma's Avatar
congrats mate...there is 20 sqft of damping sheets available in the classiifelds.
__________________
Cheers!
Shreyas
"Two Wrongs don't make a Right, but three Rights make a Left!"
shreyasma is offline   Reply With Quote
Old 19th March 2009, 10:56   #4 (permalink)
chipfoose's Avatar
congrats stefan.
Do post the pics. Damping will surely reduce the rattles. Where did you fix the amps?
chipfoose is offline   Reply With Quote
Old 19th March 2009, 11:08   #5 (permalink)
greenhorn's Avatar
apart from damping the doors using conventional damping, use foam/felt to damp your doorpads as shown below
this is a problem with tata vehicles alone, since their speakers are mounted on the plastic door panels as opposed to the metal frame of the door itself
EDIT: hey, wait , you've used wooden rings and mounted them on the frame itself? then its not so needed
__________________
'07 Indica DLG - Almost a DLX
greenhorn is online now   Reply With Quote
Old 19th March 2009, 13:29   #6 (permalink)
stefanm's Avatar
That's all you want to see?
I didn't take any WIP pictures, as i only had a few hours here and there to do the work, i wanted 2 clear days, but the family wanted the car in mornings/evenings etc.
Will take some pics asap and have to remove one door card anyway so will take pictures then. The idea of the install was to be as stealthy as possible, there is few more mods i want to do, to keep it looking as stock as possible.
Old 19th March 2009, 14:34   #7 (permalink)
abhibh's Avatar
Stefan nice equipment and writeup. Waiting for the pics and prices.
BTW from where did ya purchase Hertz Subs ?
__________________
Tyres will screech & Engines will roar - WOM
Old 19th March 2009, 21:32   #8 (permalink)
live2drive's Avatar
Congrats stefanm for your setup.
Did not understand this. Can you please elaborate?
live2drive is online now   Reply With Quote
Old 19th March 2009, 21:47   #9 (permalink)
Abhinav , i think he meant that he is just powering the mid bass from the set of components directly from the HU without going through cross overs etc.
__________________
Old 19th March 2009, 22:09   #10 (permalink)
abhibh's Avatar
The component set he is using is very well know for its capabilities for mounting tweeter on the midbass. Just like any 6x9 speakers.
__________________
Old 20th March 2009, 22:21   #11 (permalink)
stefanm's Avatar
Abhibh is correct, it's just a mounting option with the component set, the crossovers are still there, i'm thinking of removing the tweeters from the rear doors anyway and just leave the mids in place, as the highs are not really required for rear fill, they come from the front perfectly, funny enough the mid row in the Safari appears to be the prime listening position, have to play more with the t/a settings as i'm usually in the drivers seat.
Will be taking a few snaps tomorrow afternoon and will post by the evening.
Old 21st March 2009, 14:15   #12 (permalink)
Oh. My Bad. Thanks for the info Abhibh
Can we have more pics of the equipment please!
__________________
Old 21st March 2009, 22:37   #13 (permalink)
stefanm's Avatar
Here are some photo's to start with, first is the all important head unit, Alpine 9887, second pic is the tweeters mounted near the stock location on the door, the rest are of the DLS A6 mounted on spacers and shoe horned beneath the passenger seat, extremely tight fitting. Please excuse the dust in the pictures, I tend to drive with my windows down as I don't really like AC very much!
Old 21st March 2009, 22:49   #14 (permalink)
karankapoor's Avatar
good man atlast you had posted some pics of your install.pretty neat install post some pics genesis p2 amp and sub.
what is the benefit of 2 tweeters per side?
__________________
P80RSII l ID Chameleon's l Genesis Dual Mono l ID Max l Genesis Dual Mono EXtreme l Kicker l Connection Audison l Dynamat
karankapoor is offline   Reply With Quote
Old 21st March 2009, 22:52   #15 (permalink)
stefanm's Avatar
Some more pics for now, First up is the Genesis Profile 2 and the crossovers for the front speakers, then we have the front speakers mounted and angled spacers directly to the door, this was difficult to centre excactly, will fabricate something to tidy it up, although you don't really notice when the stock grills are in place. Then another shot of the A6, just love this amp, so much juice and excellent SQ, then the rear compos, tweeters are mounted on the woofer and crossovers are in the door card for the time being. Then we have shots of the twin sealed wedge shaped sub box, as per the Hertz manual I have built the box with enough space to go ported if I choose, but I am enjoying it sealed for now.
Enjoy
Thread Tools
High Level Peak Scratchy Sound. Please Help!!! dpkanj Ask the Gurus 5 20th June 2009 22:03
Exotics, super cars and high-end imports in Mumbai hanmust Super-Cars & Imports in India 12 27th February 2009 10:15
Tata Safari DICOR High Smoke Emission directinjection Technical Stuff 38 11th January 2007 14:44
why sound is harsh at high volume overdose14 Ask the Gurus 21 26th July 2006 00:36
Natural music for sleep??? furioussphinx Shifting gears 7 11th May 2006 04:18
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
