| Sound Off and Show Off Discuss and show your ICE here |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian Join Date: Sep 2005 Location: New Delhi
| Hi All As promised here are my inputs on installing in the Getz. The Good... Nice car to install in. Door panels are well built and require little or no damping. You can install fairly deep speakers (with an mdf ring of course) without fouling with the windows. Problems... HU Install - Most installers will cut the "blank DIN plate" with a blade and the force the HU through the hole they have cut. While quick, this is wrong.. Your HU will protude out, and is prone to theft as the entire thing can be yanked out easily. Heres how the wrong way looks. The right way... You know the carbon finished center console, you have to remove the whole thing. Now you will see that the "blank DIN plate" doest need to be cut, it is held there by 2 screws on both sides. Remove this plate. Now you need a DIN Sleeve which you can see in this pic. ![]() and this ![]() As you can see above, you can now secure your HU with the 4 screws you removed. Put the console cover back on when you're done. It should llook like this. ![]() Next, your installer will most likely cut through the existing power, ground cables, make joints and tape them up. This is one of the worst things you can do. Avoid all joints and tape-ups. They dont last very long. Heres what you can do. ![]() Take 2 generic 4 pole connectors (your installer should have a few lying around), cut the cables you dont need, connect them and secure with cable ties. Alternatively, you can use 3M splice cable connects which are very good, if you can find them. ![]() Next problem, getting your speaker cables through the front doors. There is a harness near the door hinge, which may or may not have a pair of spare cables. You will have to screw around with the connections in the harness to find that out. But since we dont like cutting through cables, making joints, we take an alternate route. ![]() There is a rubber plug in the door (just under the hinge). Cover the cable with a rubber / PVC sheath and run it through this plus and into the rubber cover for the harness above. Make a small cut in the harness rubber cover. You can seal the cut once your cable is through with rubber sealant / glue). So there... Also, if you plan to install any good component speakers, you need to fabricate mdf rings for them. Install them like this... remember to cover the ring with carpet on all sides. ![]() Also, since we were discussing spare wheel well sub enclosures, heres a pic of the area. We will be working on this soon and have more pics for you. ![]()
__________________ Playing in my CD player: Rod Stewart - The Story So Far |
| | #2 (permalink) |
| BHPian Join Date: Jun 2005 Location: Bangalore
| That was a lot of info Gunbir. Could you suggest a better way to mount my JBL 426 front speakers apart from the custom 4 inch space provided in the Alto's dash?
__________________ Thank God for DIY audio. |
| | #4 (permalink) |
| BHPian Join Date: Mar 2005 Location: Navi Mumbai
| Thanx GUNBIR. That was fast and very good. Specially the centre console info. One more question although not related. What is the HU in the first pic( pioneer ok but model number. ) it nicely matches with the carbon black finish
__________________ It is never too late.- get your safety options right |
| | #7 (permalink) |
| Dear Gunbir. Why the MDF ring. To isolate /reduce vibrations from the door ?? Cant I use dorr deadning material ( matt something) around the speakers instead of the ring.
| | #8 (permalink) |
| BANNED Join Date: Sep 2005 Location: New Delhi
| Pranil, The MDF ring has various advantages : 1. Gives solid mounting base for midbass driver 2. Avoid vibrations and isolate the driver from the metal body. 3. Prevents the drivers magnet from the touching the window glass when rolled down. 4. Brings the driver close to the door pad grille helps it firing through the grille rather than the sound waves going in the door pad which results in vibrating the door pad and muffling the sound. For better results put a foam ring around the midbass so that there is no leakage in the doorpad and sound is directed in the cabin. Damp the door with the damping material and then mount the MDF ring. |
| | #9 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
i would love to see a locally available material that was heavy enough to damp resonances, porus enough to absorb the sound, and resistant enough to withstand humid/hot conditions. to prevent leakage in the MDF I use rubber with a shore hardness between 40-60. this makes the rubber soft enough to make a air tight fit and hard enough so it is not squeezed competely. foam disintegrates after a few years in mumbai. | |
| | #11 (permalink) |
| Newbie Join Date: Jan 2005 Location: Bangalore
| I own a Hyundai Getz GLS. It came with a Sony headunit and four installed speakers as a part of the dealer offer. I had an occasion to examine what kind of speakers they are. The two front ones are Sony X-plod (or atleast Sony X-plod lookalikes one gets these days in car-audio markets, since there is only a sticker with the name "Sony" on the magnet with no other markings). The two rear ones are Pioneer. Both are "three way" types. I am in general dissatisfied with their sound. At home I have separates with components carefully selected, and the sound inside my car simply becomes intolerable sometimes. I may also mention that, 1.) I am not a bass-freak, and do not intend to install an additional amplifier or subwoofer inside my car. 2.) I do not play music loud in my car. 4.) I do not wish to do extensive re-wiring in my car for audio. 5.) If the four speakers alone can not give me very good frequency response in the car, let it be. I feel that it is the inherent drawback of in-car environment, which can not be significantly improved. 6.) But I wish whatever sound my car-speakers produce (within the limitations) should be very clean and distortion-free. So in short, my requirement is only for four very good car-speakers that fit Hyundai Getz, to run with a Sony head-unit. I am willing to spend for this. Any suggestions? |
| | #12 (permalink) |
| For four speakers in a Getz I would suggest the following : 1. 6.5" component speakers in the front door. 2. 6.5" coaxial speakers in the rear door. It will give you a enjoyable clean sound. For best results I will recommend a 4channel amp with the speakers. For full range sound you can add a subwoofer anyday you want to. Not necessarily 12" you can opt for 10" or 8" as per your taste. |
| | #13 (permalink) |
| yeah those 8" bass tubes are light and can be removed even by me. one tube might not turn our car into a discotheque (but oyu dont want that anyway) but will add some beef to the bottom end besides they are really easy to remove. |
| | #15 (permalink) |
| We personally prefer the sealed enclosures for their flat frequency response. The tubes are generally ported to give more output for the price. The drivers and enclosures are not of a very high quality so you barely get flat response |
| Thread Tools | |
Similar Threads | ||||
| Hyundai Getz | toyota | The Indian Car Scene!! | 33 | 22nd March 2007 11:07 |
| New Hyundai Getz | askicode | The Indian Car Scene!! | 23 | 26th January 2007 14:09 |
| My New Install In Getz with Audison Products | viper | Sound Off and Show Off | 79 | 12th September 2006 17:10 |
| Hyundai Getz - Impressions from the TD | normally_crazy | Test-Drives & Initial Ownership Reports | 38 | 3rd April 2006 13:48 |
| Hyundai Getz Pictures | Rehaan | The Indian Car Scene!! | 0 | 29th July 2004 23:01 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
