Go Back   Team-BHP > Buckle Up > Street Experiences
Old 27th May 2011, 15:33   #1
Thanked: 23 Times
Default Holes punched on the tubeless tyres of my vehicle
I parked my car in the shared ground floor parking space of my apartment on last Tuesday. On thursday morning, we noticed that one of the front tubeless tyre was deflated. As I could not locate any visible objects (e.g. nails, wires etc) on the tyre and also my car did not move out of the garage since tuesday, I suspected some mischief and took the tyre to the nearest fuel station for fixing it.
The mechanic located five small holes that were punched through the tyre. The holes were very close to each other. The Goodyear tyre was almost new.
Now, keeping my anger apart, I would like to know whether it is safe to go on a long drive with the spare tyre with five holes. I was planning a long drive of around 500 kms tomorrow with my wife and 23 month son as company. The mechanic at the garage, however checked the tyre several times after fixing and indicated that there are no more holes.
black_panther is offline   Reply With Quote
Old 27th May 2011, 15:51   #2
Thanked: 113 Times
Default Re: Holes punched on the tubeless tyres of my vehicle
What is the diameter of the holes? How were they plugged? Are they close enough to merge into a larger hole with wear and tear?
--Ragul
Ragul is offline   Reply With Quote
Old 27th May 2011, 16:00   #3
Thanked: 23 Times
--Ragul
Holes were very small (~ 1 sq mm), probably punched with a sharp object. The holes were invisible with naked eye but caused very prominent air bubbles in water.
The holes were plugged with the standard kit.
All 5 holes were within a rectangle of 2 inch by 3 inch. The closest two holes are approximately 1 cm apart.
Old 27th May 2011, 16:29   #4
Thanked: 4,140 Times
Are these on side walls or on treads ? should not be an issue if these are on treads .
Turbanator is online now   Reply With Quote
Old 27th May 2011, 16:32   #5
Thanked: 113 Times
I am no expert, but me thinks that's a fairly large area and it shouldn't blow. You have a spare 5th wheel dont you? Keep this bad tyre for emergency and use the stepni as your regular tyre. But you will have to worry about it when it is time to rotate tyres. Or you can rotate only the 4 good wheels.
--Ragul
Old 27th May 2011, 16:40   #6
unoczar's Avatar
Thanked: 82 Times
That's exactly his worry. He doesn't want to carry a spare wheel with holes in it.
@Panther, did you ask the puncture fellow as to how this could have happened? What about the security guy? If the holes are in the treads, you should be able to do a good 100 kms on that tyre, just in case. But still, it is very dangerous given that you have a young fellow with you.
Sensible suggestion: sell the tyre, buy a new one. Have a night watchman if you don't.
unoczar is offline   Reply With Quote
Old 27th May 2011, 17:07   #7
Thanked: 23 Times
Holes are mostly on the treads but on the lateral side. Also these are on the thinner section of the tread (less rubber).
The current watchman is rather newly appointed and is an old fellow (Now, don't ask me why). I have seen him falling asleep during the late evening.
@unoczar : I won't be able to sell and buy a new tyre tonight as I plan to go out tomorrow very early in the morning. Would it be sensible to take the bad tyre as a spare one tomorrow, specially with a kid on board?
Old 27th May 2011, 17:12   #8
Thanked: 23 Times
The puncture fellow was preety sure that it was done intentionally. Remember, holes are on the lateral exposed side, on the tread and on the sections in between thick rubber.
I am not ruling out the mischief by a driver who is knows about tyres.
Old 27th May 2011, 17:15   #9
If you check your ODO reading & number of times you have got the tires punctured you will find the odds of getting puncture , in addition to this you have a spare tire so should not worry much , most of the time air deflates from Tubeless ones slowly unless there is a big puncture , in 2 of my cars , i don't have even a spare tire courtesy RFTs and till date have never been struck . However its a good idea to keep a small Air pump which comes handy and you can pick this from any of shops -
Old 27th May 2011, 17:43   #10
Thanked: 23 Times
The car had run 8000 kms in 2009 mostly on highways and only had a single puncture when a small piece of wire got stuck from a construction site near my house. I was in US since then, and got the car serviced last week after coming back.
Old 27th May 2011, 18:09   #11
selfdrive's Avatar
Thanked: 2,492 Times
Well, this is quite unfortunate and if you want to find whodunit then you could try to recall if you had any argument or discussion with anyone in the vicinity recently. It could also purely be out of jealousy for one or the other reason.
While this could be used as a spare for your drive today, I would also recommend that you replace/ buy another tyre to ensure your safety. Also see if you can ensure that the security is more aware of who is entering the parking premises if this is not already being monitored
selfdrive is offline   Reply With Quote
Old 27th May 2011, 19:26   #12
Thanked: 23 Times
I believe, I am kind of a "no one" in the locality. I had a word with the security guard and the drivers of other cars in the premises. They indicated that sometimes they have frictions with drivers from neighborhood and there has been incidents of vandalism on other cars.
Usually I drive both our cars, but a driver in the premises takes care of them (washing, parking, taking for service/repairs, ocasionally driving my parents).
Jealousy is unfortunate, but that do happen in Kolkata.
Yes. I am determined to drive out tomorrow, whatever comes in the way.
Wish me luck!
I was thinking of upgrading to Bridgestone as Goodyear is noisy on the highways taking the positive from the incident.
Old 27th May 2011, 19:43   #13
selfdrive's Avatar
Everywhere my friend; unfortunately
The Michelin XM1s also come highly recommended for noise reduction; you may want to check those out too.
I wish you well for your trip; let us know how it went and come back with lots of pics for us!
Old 27th May 2011, 21:09   #14
Thanked: 23 Times
Thanks. I'll consider Michelin and go through the t-bhp threads before taking the final decision.
I had one more inspection of the less fortunate tyre. 4 of the 5 holes are on treads at the edge inclined towards the lateral side and 1 exclusively on the lateral side.
Thanks all of you for your help and support. This will be my first trip in India after the 12k + miles at the US, therefore lacking a bit on confidence, but really excited to drive my black panther after a long time which is smooth and silent as ever.
Old 28th May 2011, 08:44   #15
unoczar's Avatar
Thanked: 82 Times
I can say with confidence that you take almighty's name and go with 4 good tyres. Where are you going? If you stay on good roads, there shouldn't be any cause for worry. All the best!
Remote controlled Auxiliary Lights: No splices, no wires, no holes triedeverything Modifications & Accessories 18 7th April 2016 10:09
Impact of Making holes for ICE on structural integrity greenhorn Technical Stuff 14 10th May 2011 10:40
Performance of Indian cars Post Monsoons on Indian Pot Holes Tech The Indian Car Scene 38 2nd August 2010 08:47
Punched in longest jump on a motorcycle aargee Motorbikes 1 8th March 2010 13:56
My Indica punched by a Truck rkbharat Street Experiences 35 18th July 2009 11:30
