Go Back   Team-BHP > Buckle Up > Street Experiences
Old 17th July 2007, 17:29   #46
fash_1's Avatar
Thanked: 54 Times
Even oil/diesel spillage could be the culprit in this case.
fash_1 is offline   Reply With Quote
Old 18th July 2007, 06:17   #47
mithun's Avatar
Thanked: 49 Times
I think that the situation can be avoided(to some extent) if the Swift was equipped with ABS.
Old 18th July 2007, 10:10   #48
WhiteKnight's Avatar
Thanked: 74 Times
Not really. micraft's car side stepped probably due to the sudden turn he took. ABS helps ONLY when you apply brake.
WhiteKnight is offline   Reply With Quote
Old 19th July 2007, 00:56   #49
Awaiting Email Confirmation
Thanked: 318 Times
Default Standing water and aquaplaning.
I am pretty sure that standing water( by which I gather you mean more than 2 mm) is not a prerequisite for aquaplaning.
Even a very thin film of water and speeds above 70kmph will suffice to bring about aquaplaning based on various other contributory factors which you can gather from the links. If standing water was a prerequisite for aquaplaning which is not there on race tracks then Schumi would not be wasting time in the pits to change tires from slick to rain tires (Wet weather extensively ribbed tires).
Any thickness of water layer on the road is standing water so in that sense you would be right but standing water does not mean that it should be more than a particular thickness.
Bye and wear your seat belts.
Aquaplaning - The Hidden Danger of Driving In the Wet
Aquaplaning@Everything2.com
Rubber: directional tyres
Car Bibles : The Wheel and Tyre Bible
drpullockaran is offline   Reply With Quote
Old 19th July 2007, 04:38   #50
Thad E Ginathom's Avatar
Thanked: 7,460 Times
You don't aquaplane on a wet road, you skid! I suspect that some people who have skidded on a wet road may think that it was aquaplaning, but there is quite a difference.
I don't think anyone mentioned a minimum... maybe 1mm is enough, i don't know but more than a film of water is required.
Also a certain minimum speed is required --- that first link explains it pretty well.
Last edited by Thad E Ginathom : 19th July 2007 at 04:52. Reason: now checked out the links
Old 19th July 2007, 10:55   #51
Jaggu's Avatar
Thanked: 7,676 Times
I think Thad has a point, this must be a skid scene rather than aquaplane. He mentions it was a turn and usually they are notorious for diesel spills from heavy vehicle, along with water this is a deadly combo for skid/spin.
Again let me tell you, i drive a Vxi with stock tyres also (quite often) and its a dangerous car (with those tyres).
Old 22nd July 2007, 17:59   #52
Thanked: 318 Times
I guess those who have seen the first five minutes of the Grand Prix today and heard the commentators would have understood that standing water can be there even on a grand prix circuit and that even miniscule amounts of water on the track is enough to initiate Aquaplaning. With the right set of tires and speed you could bring about aquaplaning by even spitting on the tracks in front of the tires. Aquaplaning just means that there is thin layer of fluid between the tire tread and the road when traction is lost.The finest film of water is sufficient to bring about aquaplaning. A skid is when traction is lost with the absence of any intermediary fluid layer between the tire tread and the road.
Old 22nd July 2007, 18:32   #53
vnabhi's Avatar
Thanked: 1,240 Times
Hmm, Micraft, thank your stars you have got through unhurt, and without causing hurt to anyone else.
I must thank you for posting this, as it educates us on how not to drive,especially on steep curves. It is foolish to overtake before any blind curve.
Reminds me of an experience in mid 70s (when I was a school kid), when I was travelling from Cal to Bhubaneswar in an chauffeur driven Ambassador, in heavy rain. The driver suddenly veered to avoid a pothole, and the car turned 180 degrees in 2 seconds flat! There were no seatbelts in those days ! Luckily there was no traffic.
With that in mind, I never take risks, especially on wet roads.
Drive safe !
vnabhi is online now   Reply With Quote
Old 22nd July 2007, 20:00   #54
drpullockaran No... please check out the links that another member posted a page or two ago on aquaplaning.
You could maybe skid if someone with a very big mouth spat in front of your wheel, but a thin film (ie wet) road will not get you aquaplaning. There really has to be water there, not just wet.
It is a very similar feeling to being on ice, though I have, I'm glad to say, never driven on ice at the speeds necessary for aquaplaning!
A skid can be on ice, oil, wet surface --- even gravel. The wheels do not loose contact, but do loose grip.
Aquaplaning --- you're floating.
Believe me, you'll know if it happens to you!
(Here's wishing you a long life of not finding out )
Old 18th November 2009, 10:53   #55
Thanked: 25 Times
Lucky Guy.
I have Aquaplaned a lot. It is reallay dangerous situation where you have no control on the vehicle for a few seconds.
I have also skidded. I own RWD cars only.
I had a question and wish someone could answer me by PM.
My one Front Tyre had worn out. The Other Front Tyre has been worn very slightly. I have just bought One New Tyre as there was only One New Tyre with the Same Tread for sale. What should I do ?
Should I keep the New Tyre & Slightly Scrubbed Tyre in the Front & keep the rears as before ?
I drive a RWD Car.
Thank You for the inputs.
supercars is offline   Reply With Quote
Old 18th November 2009, 16:08   #56
Rehaan's Avatar
Thanked: 23,091 Times
Supercars, i'm not sure if this answers your question, but take a look : http://www.team-bhp.com/forum/tyre-a...ront-back.html (Purchasing two new tyres should i install it in front or back)
Its fairly relevant to this thread as well.
cya
R
Old 18th November 2009, 16:29   #57
clevermax's Avatar
Thanked: 419 Times
You should really get 185s in your Swift. It does change the road grip a lot. Try to get tires which can handle wet roads in a bit more better way, like the XM1s. The 165s we get with those button like tread patterns aren't any good. They have terrible road noise also.
I know that road very well, and as per your writeup, a car like Swift loosing control at speeds like 70s in that road is not very likely unless it was raining and the road was wet. I remember taking on curves in that road at speeds above 80 with 185 Michelins of my car effortlessly.
clevermax is offline   Reply With Quote
Swift Remote Key Lost! please help Kiyon Technical Stuff 23 25th January 2015 20:59
A Device that can control all my gadgets / Universal Remote Control a4_attitude Gadgets, Computers & Software 28 24th August 2011 11:10
Lost Pioneer Remote Control garry.brant In-Car Entertainment 1 11th October 2010 20:15
Lost my dear friends to road accident zaks Street Experiences 31 16th January 2010 23:25
doctor lost life in a swift crash-negligence ram_hyundai Shifting gears 75 12th January 2008 09:51
