Go Back   Team-BHP > Buckle Up > Street Experiences
Old 26th March 2010, 20:02   #46
ulhas.ahirrao's Avatar
Thanked: 33 Times
Angry Strange experience with roadside puncturewalas
Hello fellow bhpians,
I had this strange experience 3/4 times. I went to get air filled in my i-10 tyres at a roadside puncturewala (different each time). First tyre was filled and then at the second/third tyre he started struggling to fill the air. But the the tyre just didn't show any sign of air getting filled. Then the puncturewala told me that the tyre is punctured.
I was surprised at this started arguing, he said the valve may be loose. I asked him to tighten it and then it was fine. The car was parked at office for 7-8 hours, so if the valve would have been leak the tyre would have been flat there itself. But tyre started loosing pressure only at the puncture shop. Is there some cheating these guys are doing? anybody with similar experience. How to tackle this?
ulhas.ahirrao is offline   Reply With Quote
Old 26th March 2010, 20:26   #47
abdriver2000's Avatar
Thanked: 24 Times
I would stick to my trusted petrol pump to get air filled. Digital gauges are usually good.
abdriver2000 is offline   Reply With Quote
Old 27th March 2010, 10:35   #48
You are inviting trouble upon yourself buddy. Why not fill air along with petrol at your regular petrol pump. Hope you have a trusted pump, if not you should be taking better care of your ride.
bullinb is offline   Reply With Quote
Old 27th March 2010, 12:01   #49
sachinj12's Avatar
Thanked: 161 Times
Rule No 1- Always do it at a petrol bunk
Rule No 2- Always follow rule no 1
Why go to local guys when the petrol bunk does the job? Better be safe than sorry.
sachinj12 is offline   Reply With Quote
Old 27th March 2010, 16:56   #50
Something similar.
After fixing puncture, they will show as if they are checking tyre from inside for foreign objects , nails etc and try to cut inside surface of tyre lining using some pointed tool.
They will show you those cutting and will ask you to fix it with TYRE PATCH , which will cost you anywhere between 100-250 depending upon intricate location of puncturewala
It happened with me once.
idea1979 is offline   Reply With Quote
Old 27th March 2010, 21:02   #51
para_7k's Avatar
Thanked: 63 Times
Does he actually know the i10 has tubeless tyres and the valves don't get loose as easily as in tyre tube ones ?
To me, this looks like a clear hoax to extract money. Ask him if he can fix tubeless punctures.
para_7k is offline   Reply With Quote
Old 28th March 2010, 10:35   #52
Thanked: 555 Times
I had similar experience in Paud Road locality in pune.
Find a reliable tyre repair vendor/person in your locality or better find a tyre shop. Most of tyre pressure gauges are not well calibrated/maintained at fuel pumps.
I shifted to using a battery operated portable air compressor sometime back when my daily drive route changed & couldn't find a reliable person on that route.
sukiwa is offline   Reply With Quote
Old 5th April 2010, 20:04   #53
Thanked: 11 Times
Yes, I had similar experiences twice,in karve road area, for my M800.Now that I have new set of tyres with nitrogen,Iam relieved from such type of 'punctures'.
auto-one is offline   Reply With Quote
Old 5th April 2010, 20:26   #54
Sheel's Avatar
Thanked: 4,985 Times
spend Rs~400 and get yourself a foot pump,
handy while punctures happen at un earthy places/hours
and tires should be filled in once they are cool
Old 16th April 2010, 22:25   #55
iamback's Avatar
Anyone used Slime Tyre care products ? BTW here is their website SLIME - Worldwide Leader in Tire Care - NEW Slime Quick Spair & Slime Shield
iamback is offline   Reply With Quote
Old 17th September 2010, 03:04   #56
johnruben's Avatar
Thanked: 73 Times
I am very much frustrated with these puncture shops, they loot us in the day time openly. I have spent around 2k+ only on tubes in just 3 months which lasts not more than 300-500km. These tubes they put are 100% Duplicate, some brands which they have put on my tyres are: DUELOP, JIK, CEET ....
I happened to pay 450 for tube thinking getting a brand one, later came to know it was no JK, it was JIK, i didnt know as it was dark. As many have suggested, it is always good to carry Tube along with spare tyres always, nowadays it doesnt really matter its highway or city traffic, both places...specially bangalore roads are puncture prone.
johnruben is offline   Reply With Quote
Old 17th September 2010, 12:04   #57
Rahulkool's Avatar
Thanked: 571 Times
I also usually fill air from petrol pump then use my pressure valve also to double check the pressure. Its mostly correct. Few days back i had a punture but the tyre was not completely flat, went to nearby punture shop to get the air filled and later get it repaired somewhere else. He filled air in all four and after that car felt very unbalanced and steering was also very light. Just to be sure after driving 4-5 kms i used my pressure valve and every tyre had 52psi. when i had seen him filling till 30psi.
Rahulkool is offline   Reply With Quote
Old 21st September 2010, 00:38   #58
airguitar's Avatar
Thanked: 116 Times
I've noticed this a lot on the Doddaballapur -> Dobbaspet stretch. Pieces of wood that act as sturdy holders to the upward pointing nail : strewn at various intervals. I've not seen a puncture shaap close by anywhere, but I've seen a lot of 2-wheelers/cabs with flats on the road.
airguitar is offline   Reply With Quote
Old 21st September 2010, 13:18   #59
Googleman's Avatar
Thanked: 48 Times
Last month to my trip to Pondicherry. One of my TUBELESS tyres suddenly got a puncture and got a deep cut by the reflectors places on the road acting as dividers.
I was shocked to see how could tubeless get flat after seconds of it being punctured. I couldn't find a nail or anything in the tyre. It just got a deep cut and can not be used any more. I was not surprised to see a puncture shop just beside the place I stopped.
Was it a plan of the Puncture guys? If yes, How did they do it?
Googleman is offline   Reply With Quote
Old 19th March 2015, 10:55   #60
Thanked: 78 Times
Default Nails intentionally put on roads in Bangalore
A network of puncture shops in the outer ring road, Bangalore is intentionally putting nails on the roads.
A facebook group has been created to create awareness about this issue:
https://www.facebook.com/MyRoadMyResponsibility
Some photos:
Tricks Puncture/Tyre shops play: "Beware of nails on roads" and other experiences-152707.jpg
Tricks Puncture/Tyre shops play: "Beware of nails on roads" and other experiences-152708.jpg
Mods, there were multiple threads related to nails on roads. Please merge wherever is appropriate.
Note from mod : Please do not link to externally hosted images, attach them to the post itself
psankar is offline   (5) Thanks Reply With Quote
Puncture (tubed tyre) and tyre type/age rex_varghese Tyre & Alloy wheel Section 2 13th November 2007 20:19
Man survives six nails driven into head S350L-E240 Shifting gears 8 10th May 2004 23:35
