Go Back   Team-BHP > Buckle Up > Street Experiences
Old 24th March 2008, 20:38   #1
gopinathann's Avatar
Thanked: 20 Times
Default Doing a handbrake turn to avoid an accident in an ABS vehicle?
I wanted to know how do we handle a situation when we don't have enough time to stop with an ABS fitted car, identifying an sudden object coming in front of us, say a lorry comes and stops in the middle of the road. Is it possible to drift the car to 180 to reduce the speed and stop it(when both the sides are empty).
Please throw your thoughts on this.
gopinathann is offline   Reply With Quote
Old 24th March 2008, 21:10   #2
revvedup's Avatar
Wrong section mods please move this to the appropiate section. BTW,What you are talking about is actually a handbrake turn and not a drift although there is something called a handbarke drift, but anways here you go from the master Tiff Needell himself. Although be careful doing this on a car with a high C of G at too high a speed can make your car go turtle.
For more extreme driving techniques refer to this thread
http://www.team-bhp.com/forum/collec...e-driving.html
revvedup is offline   Reply With Quote
Old 25th March 2008, 12:36   #3
Rehaan's Avatar
Thanked: 25,038 Times
Yikes!! Terrible idea!!!!
Ill tell you why i think so :
1. ABS is designed to let you STEER so you can avoid obstacles during hard braking if you have the chance to steer around them / change lanes etc.
>> if you are going sideways - its useless.
2. Crumple zones are designed to decelerate the car as gradually as possible to reduce the impact on the passengers as much as possible.
>> you wont get to use these if you are going sideways. Not to mention that there is about 3" between you and the object you are about to hit when you are going sideways, instead of 3-4feet!
3. Seatbelts.....
>> ...wont help you if you crash into a lorry sideways
4. Front airbags....
5. Curtain airbags (if you are lucky enough to have them) will provide some protection...
>>.... but nowhere as much as a seatbelt + front airbag
6. Going sideways is not going to slow the car down any faster than locking your brakes and going striaght IMO - so then why even bring ABS into the equation.
cya
R
Old 25th March 2008, 12:54   #4
RPMPKDMFF's Avatar
Thanked: 27 Times
Brake as much as possible, then turn the steering enough to go around and continue on your way... that is why you have ABS, it is there so that you will not get you brakes locked, which you will end up doing if you go into the handbrake turn.
RPMPKDMFF is offline   Reply With Quote
Old 25th March 2008, 13:17   #5
headers's Avatar
Thanked: 464 Times
Have not tried as none of my cars have ABS..someone pls lend an ABS car to try Handbrake turns!!
Old 26th March 2008, 10:55   #6
Thanked: 245 Times
Thats what the ABS is meant for, steer away, why would you want to use the handbrake and IMO you wont have the reflexes to do it in time too.
But assuming you manage to...
- A SUV will definitely topple
- Side impact beams will give you some protection (if your vehicle has those) apart from what Rehaan posted.
Old 26th March 2008, 10:59   #7
Thanked: 152 Times
Double Yikes!!
Sound like you are trying to get a part in the New Fast and Furious movie??
Anyways people above have already explained the Advantages of ABS so i need not say anything more.
Cyrus43 is offline   Reply With Quote
Old 3rd April 2008, 16:32   #8
simplythebest's Avatar
CArs with ABS have a normal handbrake. Atleeast my skoda does.
I can do a normal handbrake turn just like my old esteem.
Overcoming the 205 tyres and better balance of the car to do it on tarmac is another story. Easy enough on a wet road or sand.
OT: while driving the skoda car on the track, I tried a bit of handbrake to help bring the back around. It didn't snap like an esteem at all. I could hear the wheels locking, but very little oversteer.
simplythebest is offline   Reply With Quote
Old 7th April 2008, 01:08   #9
Thanked: 660 Times
With handbrake if you are in great speed there is a great chance that you will topple your car.
Cut maro yaar!!!
Old 7th April 2008, 01:30   #10
It seems to be interesting topic as I never knew how ABS worked .
Actually person using ABS should be educated about it to use it effectively as in Case of ABS you have apply constant Pressure on Brakes for best results Instead of Pumping brakes on conventional braking system( non ABS)
There is very good ABS education article FAQ here if some body want to read
ABS Frequently Asked Questions
drkhalsa is offline   Reply With Quote
Should lack of ABS & Airbags be good reasons enough to turn our heads away? leonerd Technical Stuff 59 30th September 2009 18:56
Bill of materials for a handbrake assembly? ag501 Technical Stuff 0 29th November 2007 22:35
Performance Boosters for vehicle behind you - Your TURN INDICATORS rkbharat Street Experiences 7 17th October 2007 17:17
High Speed Accident: Scorpio meets Ashok Leyland on a turn! Gordon Street Experiences 31 23rd June 2007 12:15
No right turn, but how about a U turn? adya33 Street Experiences 14 28th September 2006 20:10
