Go Back   Team-BHP > Buckle Up > Street Experiences
Old 15th October 2008, 12:40   #1
amitpunjani's Avatar
Thanked: 101 Times
Default U-Turn Indicator
Hi People
Just a very simple question Why don't we have U turn indicator? We have signals to inform the rear driver about cars turning left or right then why not for U turns? IMHO it would be very useful specially on Indian roads.
Your comments will be appreciated
Amit
amitpunjani is offline   Reply With Quote
Old 15th October 2008, 13:12   #2
discobiscuit's Avatar
Thanked: 121 Times
U-turn is a right turn.
Case closed
discobiscuit is offline   (1) Thanks Reply With Quote
Old 15th October 2008, 13:26   #3
four_tire's Avatar
Thanked: 21 Times
are you talking about left-Uturn or right-uturn indicator?? -)
four_tire is offline   Reply With Quote
Old 15th October 2008, 13:42   #4
Thanked: 101 Times
Hi
Good question, infact for both.
amit
Old 15th October 2008, 14:20   #5
A.R
A.R's Avatar
U turn is indicated using right indicator on your vehicle plus your right hand signalling the U turn (remember the RTO lessons dueing DL test). At night the right indicator itself will do.
A.R is offline   Reply With Quote
Old 15th October 2008, 14:21   #6
deadguy25's Avatar
Thanked: 42 Times
Maybe an amber coloured indicator on both the tail lamps??
deadguy25 is offline   Reply With Quote
Old 15th October 2008, 15:28   #7
navin's Avatar
Thanked: 4,262 Times
I would assume that the best option be an alternate flashing of the brake light and right/left indicator according to which U turn one was taking.
navin is online now   Reply With Quote
Old 15th October 2008, 15:36   #8
absynthguzzler's Avatar
Thanked: 224 Times
This is an amazing concept and will integrate into the conti. Same as the flashing red lights on an F1 car during rains. It makes more sense than just a continuous glow.
absynthguzzler is offline   Reply With Quote
Old 15th October 2008, 15:36   #9
Surprise's Avatar
Thanked: 268 Times
Write the word "O" in air while taking right U turn.
Left 'U' turn
EDIT: Clock wise if its right U turn and anti-clockwise if its left U turn (restrictions he he)
Surprise is offline   Reply With Quote
Old 15th October 2008, 15:37   #10
team suzuki's Avatar
How about a u shaped indicator.........,just kidding
team suzuki is offline   Reply With Quote
Old 15th October 2008, 15:42   #11
Thanked: 101 Times
exactly, i was thinking on the similar lines. But it is quite strange why till now this has not been incorporated by OEM's?
Amit
Old 15th October 2008, 15:47   #12
Thanked: 235 Times
Case closed
U-turn is NOT a simple right turn. Its better to have a U-turn signal. But, considering the way we use signals, i'm afraid it'll be rarely used.
U-turning traffic is slower than right turning traffic, if you've noticed.
So if you're taking a right turn and the vehicle in front takes a u-turn you might have to slow down further.
Torqy is offline   Reply With Quote
Old 15th October 2008, 15:53   #13
viper_711's Avatar
Thanked: 55 Times
And to add further to what you said - very often on slightly narrow roads cars with large turning radius and larger vehicles need to move to the left before beginning the U turn. I've seen this often confuses vehicles coming from behind and this ends up creating a dangerous situation.
Some form of indication for a U turn would be welcome!
viper_711 is offline   Reply With Quote
Old 15th October 2008, 15:58   #14
Amit
I guess its not being incorporated by OEM's because people have never demanded it and it may affect the looks of the car,but yeah thats not a big issue because if fitted sensibly it should not affect the looks.Cheers
Old 15th October 2008, 16:00   #15
Thanked: 101 Times
Hi viper
I cent per cent agree with, this is quite often suffered specially in narrow roads when a vehicle like Tavera indicates signal for right turn but actually takes a U turn.
In case there is a U-turn indicator, the rear vehicle would be able to keep appropiate distance between the two vehicles.
Amit
How to fit the turn indicator buzzer ? rohitkadam Motorbikes 6 15th July 2012 21:47
Turn Indicator light does not cut off automatically Shashank.A Technical Stuff 19 16th November 2008 08:47
No right turn, but how about a U turn? adya33 Street Experiences 14 28th September 2006 20:10
Nissan Tilda. Now its Nissans turn to copy. v12 The International Automotive Scene 6 4th May 2004 00:29
