Go Back   Team-BHP > Buckle Up > Street Experiences
Old 20th February 2011, 19:19   #76
Gansan's Avatar
Thanked: 883 Times
Default Re: How much more fuel can a car take after Autocut?
^^ Shaking does make a difference of at least 250 ml in my car.
Old 20th February 2011, 19:50   #77
mail4loys's Avatar
I had situations were petrol was filled to the brim and few shakes definitely made a difference and gave space to close the lid.
mail4loys is offline   Reply With Quote
Old 20th February 2011, 21:15   #78
ph03n!x's Avatar
Thanked: 119 Times
My Getz CRDi takes ~8 liters of Diesel to get to brim from auto cut-off. The tank capacity is 45 liters, but I easily fill 45 liters when I already have ~5 - 7 liters in the tank (when the low fuel warning comes up). Incidentally, the auto-cutoff kicks in at ~38 liters, giving a fairly accurate tank capacity (38l for the cutoff + 7 in the tank after low fuel comes up = 45).
ph03n!x is offline   Reply With Quote
Old 22nd February 2011, 19:46   #79
Thanked: 312 Times
How much fuel still goes in depends on how fast the fuel is pumped in. As the air present in the tank rushes out on being filled, the fuel rises with the gases, the sensors in the pump stop it. Rocking the vehicle allows the fuel to settle down as the air is escaped from the tank.
Fuel tank capacity as mentioned by the manufacturer and filling it upto the brim are two different things. Manufacturer mentions only upto a certain level of the tank. Filling it up till the brim includes the hose upto the tank from the fuel lid.
My Bolero's mentioned tank capacity is 55 litres, I can fill 61 litres.
simplyself is offline   Reply With Quote
Old 22nd February 2011, 20:03   #80
mdsaab's Avatar
Thanked: 446 Times
I think auto cut off also depends on the speed of your fill.
So if you fill up faster, the auto cut off will set in earlier.
And if slower you would be able to get more fuel in before auto cut off. I could be wrong though.
mdsaab is offline   Reply With Quote
Old 22nd February 2011, 20:24   #81
Gansan's Avatar
Thanked: 883 Times
The capacity of the Splendor fuel tank is 10 litres, till the bottom of the filler neck. If I fill it at Shell immediately after hitting reserve, it will take exactly 10 litres to reach this mark.Till the brim, it will take ~ 500 ml more.
Whereas most PSU bunks manage to fill in > 11 litres in to the Splendor tank!
Old 22nd February 2011, 23:34   #82
sagarpadaki's Avatar
Thanked: 1,271 Times
Our i20 also takes in nearly 5 litres of diesel after auto cutoff. Also there is no air vent provided beside the fuel nozzle inlet.Maybe this is the reason why so much air will be trapped inside the tank and consequently more fuel intake after cutoff and bit of dhakka!
Old 3rd January 2012, 09:24   #83
_raVan_'s Avatar
Thanked: 486 Times
My FIL's i20 took in 9 litres of petrol after auto cut off! That too twice till today from different petrol pumps (I normally stop after auto cut off). Is the auto cut off triggered when the tip of the nozzle touches the foam created when filling in?
_raVan_ is offline   Reply With Quote
Old 3rd January 2012, 09:59   #84
shankar.balan's Avatar
Thanked: 5,331 Times
My Scorpio used to take in about 2 litres more after cutoff - but then, I never used to over-fill it on account of evaporation loss.
In the Yeti, I simply go by the Auto cut-off itself.
Old 8th January 2012, 22:41   #85
Thanked: 31 Times
My Optra petrol capacity is 60L, gets cut off @ 36 L or so and then goes to gulp 14 to 15 litres more that is 51 L. There is no way Optra will have 60L @ Auto cut off, then every time i fill up till brim, i must be holding 75 to 80 L. But what ever filled i get mileage of 11kmpl from brim to brim calculation.
krish82 is offline   Reply With Quote
Old 9th January 2012, 10:43   #86
guyfrmblr's Avatar
Thanked: 1,920 Times
My i20 diesel takes around 10 litres after the auto cut-off. After filling to the brim,the fuel indicator needle starts moving only after I travel 293 km.
guyfrmblr is offline   Reply With Quote
Old 9th January 2012, 10:55   #87
dinu2506's Avatar
Thanked: 328 Times
My Civic taken in about 1.5 litres after auto cutoff
My Verna takes in about 3.5 litres after auto-cutoff
dinu2506 is offline   Reply With Quote
Old 23rd February 2012, 22:54   #88
Thanked: 249 Times
Anyone onwing i20 CRDI Sportz car here? I am little stunned here with respect to my i20 CRDI
The car's fuel tank capacity mentions 45 ltrs, I came across a surprise, when I fuelled my car FULL TANK to cap's brim levels (TOP UP), and the reading gave out 52 Ltrs. This was at BP Jayanagar in Bangalore.
This was surprising and thought the fuel station might have looted me and I just left with the bill. But, when the time came to fill up diesel full tank, same upto brim level at another BP station, this time in Bannerghatta Rd, Bangalore, again 50+ ltrs....This perplexed me. Since, I was driving down to Hyd, I wanted to check fuel efficiency and was in a hurry.
In Hyd, again when time came, i did full tank in HYD Jubilee Hills BP station (known for prompt fuel quality) again it filled 51+ ltrs upto BRIM level
Hence, I am very much confused.
PS: I do fuel the tank up when its almost empty.
kicksperliter is offline   Reply With Quote
Old 23rd February 2012, 23:10   #89
arun_josie's Avatar
Thanked: 4,334 Times
My Dzire takes in around 1 litre after auto cutoff. Tank capacity is 43litres and the max that I have filled is 42 litres.
arun_josie is online now   Reply With Quote
Old 23rd February 2012, 23:57   #90
StrangeWizard's Avatar
Thanked: 228 Times
Chevrolet has stated the Spark's fuel tank capacity to be 38 litres but yesterday I went to a petrol pump and filled a bit more than 43 litres. Had 1.5-2 litres already in the car.
StrangeWizard is offline   Reply With Quote
How much do you commute every day? And how much time does it take? sbasak Shifting gears 112 26th December 2017 20:14
New Mumbai Experiment:"3 or more in a car can take fast lane" n.devdath Route / Travel Queries 15 16th September 2009 10:58
Indian Motorsport : How can we make it more popular and more fun? GTO Indian Motorsport 45 12th July 2009 13:09
How much torture can a Honda engine take? Shan2nu The International Automotive Scene 8 8th February 2005 17:14
