Go Back   Team-BHP > Buckle Up > Street and Travel Experiences > Street Experiences
Street Experiences Experiences on the road. NO STREET RACING
Thread Tools
Old 5th June 2009, 19:06   #1 (permalink)
Default High speed stupidity
Was coming back home in my car yesterday evening. The car was doing around 70-80kmph and the road was pretty deserted and it was drizzling. I was driving pretty close to the divider.Was approaching a pretty sharp curve(to the left) and braked a little. The car was still going where I intended it to. Midway through the curve, the car was still doing a serious pace. I dont exactly remember if I had pressed the throttle again.
But I clearly remember the car beginning to lose traction. Tyres squealing.The rear started giving out and I tried to correct it to the right with the steering. But it was an overdose as the car was again off the intended line, but now to the right. Then again to the left. The fourth time, the car got it right and went straight.
I dont remember doing anything voluntarily to control the car. It was all instinct and it all happened in a flash. But it was definitely a heart in mouth experience, and after some time, was grinning that I could manage to drift a Getz 1.1.
cheers
ZedMae is offline   Reply With Quote
Old 5th June 2009, 19:18   #2 (permalink)
kutlee's Avatar
drizzling, if the first one, after a loong time, will lead to oil being loosened and cause the car to loose traction. Especially at bends because that's where all the heavy vehichles spill diesel. you also notice that since the diesel dissolver tar, road surface will be bad on highways near bents.
__________________
Rocket Science?? what is it?
In theory, there is no difference between theory and practice. But in practice, there is.
kutlee is offline   Reply With Quote
Old 5th June 2009, 19:25   #3 (permalink)
mnhegde's Avatar
That was quite dangerous, seems control was lost for a moment . What tyres you have on your vehicle (tyre squealing)? Never drive too close to the dividers.
DRIVE SAFE.
+ 1 Kutlee. Its better to avoid cornering near dividers while driving in rains .
__________________
We all have possibilities we don't know about. We can do things we don't even dream we can do.
- Dale Carnegie.
mnhegde is offline   Reply With Quote
Old 5th June 2009, 20:39   #4 (permalink)
Rehaan's Avatar
Originally Posted by ZedMae View Post
.....The rear started giving out and I tried to correct it to the right with the steering. But it was an overdose as the car was again off the intended line, but now to the right. Then again to the left. The fourth time, the car got it right and went straight.....
Known as fishtailing.
A fair deal of luck that you got out of it okay - so probably not best to try it again
cya
R
__________________
The memory of you will ride by our side forever.
Rehaan is online now   Reply With Quote
Old 5th June 2009, 21:11   #5 (permalink)
IronWolf's Avatar
Lucky you got out of that one without a scratch.
+1 to fishtailing, not drifting. Dont try this on your FWD again
Also thats insightful about the drizzle loosening the Oil.
__________________
You'll have mud in places you didn't know you HAD.
- Sarge's take on Offroading.
IronWolf is offline   Reply With Quote
Old 5th June 2009, 21:30   #6 (permalink)
Nitin's Avatar
If you had lost complete control of the car for mroe than 1 sec,you probably would have gone off the road and hit the divider. Good for you that you avoided a crash.
No matter how good your tires are, once it starts drizzling its definitely a good idea to slow down along curves.
Nitin is offline   Reply With Quote
Old 7th June 2009, 13:59   #7 (permalink)
Thanks guys for the replies. Yes, will definitely be a bit more careful in the future. And yeah it was fishtailing ( more than the tail, it was the nose which was going all over the place ) and not drifting.
cheers
Old 7th June 2009, 15:52   #8 (permalink)
MileCruncher's Avatar
@ Zed , you are lucky that you got out of this without a scratch. Please take extra care in the future.
I once had a 180 deg unintentional spin at 20 MPH on a slippery U turn in my Office compound. And that too with good tyres. Once needs to be very careful on the wet.
Drive Safe!
MileCruncher is offline   Reply With Quote
Old 7th June 2009, 16:04   #9 (permalink)
The first rain dissolves all sorts of deposits on the road including oil and mud and makes it a very slippery past. Forget driving, you should be careful while walking. Many people have falls during this first rain.
pedrolourenco is offline   Reply With Quote
Old 7th June 2009, 17:20   #10 (permalink)
cooldude1988765's Avatar
Reminds me of my first fishtailing experience about 6 years back in an accent crdi was doing a speedo indicated 140-150. I had only a couple of years driving experience that time. I was damn lucky to come out alive after that; missed the divider by a couple of inches. Luckily i dint slam the brakes, eased of the throttle shifted to fourth and turned gently away from the divider. My hands were shaking for a minute after the fishtailing.
For hyderabadis: It happened on necklace road on the curve just before eat street (while driving from sanjeeviah park to prasads)
__________________
I never thought it was humanly possible, but this both sucks and blows.
- Bart Simpson
cooldude1988765 is offline   Reply With Quote
Old 9th June 2009, 16:05   #11 (permalink)
greenhorn's Avatar
I've had my front turn inwards in the spiral ramp of my parking lot, once in the up ramp, and once in the down ramp. The dudes at the end of the up ramp, on the road side were laughing as I came up onto the road tokyo drift ishtyle, sideways
PS: yes I was scared!
__________________
'07 Indica DLG - Almost a DLX
greenhorn is online now   Reply With Quote
Thread Tools
Is it possible to shift into reverse at a high speed? Surprise Technical Stuff 79 14th October 2009 12:11
WagonR - High Starting Speed Neeraj Dabake Technical Stuff 20 3rd April 2008 22:10
Vibrations at high speed DCEite Technical Stuff 15 12th June 2007 17:43
High speed stability of NHC Floyd de Souza The Indian Car Scene 23 13th January 2006 11:36
High Speed Course at Driversskill.com ajmat Street Experiences 21 3rd July 2005 12:39
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
