Go Back   Team-BHP > Buckle Up > Street Experiences
Old 20th September 2009, 23:02   #1
tintin82's Avatar
Default Oil Sump cleaner in Shell OMR
I wanted to change the engine oil in my Pulsar today and went to the Shell outlet in OMR near Big Bazaar in Bangalore. Since i asked for fully synthetic, I wanted to flush the engine with normal new oil before filling up Helix. So I asked the manager if he could do that. He then took my bike near a machine which which he said will clean the innards of the engine well and is better than flushing. It resembled a ventilator machine with a big tank on top, a motor and few assemblies on the bottom and flanked by clear glass jars on both sides with a lot of tubes springing out of them.
He hooked up a tube to the oil drain outlet in my pulsar and started the machine. Apparently, the machine has to build pressure first before it can be operated and IIRC it was about 600 bars (not sure if the unit was bars). Once the pressure has built up, it just sucks the sump dry and extracts all leftover oil. A lot of goo came out too. It apparently only sucks whatever is left there. He claimed that this is better than flushing and a sticker on the machine remarked that the machine was patented. Seems that this outlet is the first to get that machine and they're doing trial run on bikes first and plan to introduce that for cars by next month.
Has anybody else come across this machine anywhere? If you happen to drop into the shell bunk and just as luck would have it, if you wanted to change the engine oil, ask for this machine.
But personally, I was a little disappointed with Helix ultra. I felt absolutely no difference in the ride, rev or sound so far. I'll observe for a few more days.
tintin82 is offline   Reply With Quote
Old 21st September 2009, 11:10   #2
gd1418's Avatar
Thanked: 656 Times
This sounds very interesting. I have heard about it for the first time. For cars the pressure required may be more. I shall try to find out here at major Shell outlets. Seems like some oil vaccum cleaner
Oil Leak & Sump Damage 599gto Technical Stuff 15 2nd March 2017 22:13
Civic Oil Sump crack. How effective is Brazing? Speed Pujari Technical Stuff 26 8th November 2013 13:59
4 day old Enfield Thunderbird. Oil sump damaged. EDIT: RE refunds entire amount! shailu Motorbikes 62 5th April 2012 12:14
Oil Sump In Optra Magnum-Design Flaw andrewdsouza72 Technical Stuff 33 3rd September 2009 15:13
Plastic Stick inside the Oil Sump via the dipstick tj123 Motorbikes 17 20th March 2009 18:28
