Go Back   Team-BHP > Buckle Up > Street Experiences
Old 31st January 2013, 13:31   #151
saket77's Avatar
Thanked: 4,685 Times
Default Re: Small but significant damage to City
SG sir is right. It looks quite fixable by spot welding along with some denting. I think Honda guys should do it. In case they ask you to change the door, you may press them a little for repairing it as the expenses will be higher if you go for a change.
Regarding insurance claim, these new 2K paints are expensive and the whole area/panel will probably be repainted (& not just touched up); so you might have to claim the insurance. But decide about it only after getting an estimate for the repair. Keep an additional haircut of say about 15-20% to be on the safer side.
Rest assured, your car will be restored to former glory!
saket77 is offline   Reply With Quote
Old 31st January 2013, 13:47   #152
rajeev k's Avatar
Thanked: 1,736 Times
Originally Posted by scuderiamania View Post
Will this electric spot welding process be carried out by Honda? I am a bit skeptical that they might say that we will have to change the sheet on the door.
Spot repairing is the best method for this damage and in my opinion some cold welding products would do the job here.
rajeev k is offline   Reply With Quote
Old 3rd February 2013, 22:13   #153
naveenroy's Avatar
Thanked: 703 Times
Default After accident advice needed - Ford Figo
Hello guys,
I am having to post this for a friend of mine since his membership hasn't been approved yet here.
Recently, a few weeks back, my friend was driving his Ford Figo to Kanyakumari (his home town) from Bangalore. While he admits that he indeed was going above 100 kmph, he was strapped in and is a careful driver. A goat suddenly jumped onto the road and he slammed the brakes. He says the car skidded though it was equipped with ABS and hit the median. He and his sister were fine since the air-bags deployed and also were wearing seat-belts.
He left the car at the Ford (near Thirruparangundram) ASC and we recently had a look at the car. Pardon my plain english as I might not know most of the technical terms but I will try to explain. His concerns (and mine) are:
* As you can see from the pictures, they have removed the engine and the support for the engine has been completely removed from the chassis. The ASC engineer says that this side was crushed and needed to be changed.
* The ASC says that they have the technical expertise and tools to have this section spot-welded back into position and they will mount the engine after that. Will this really be as strong? Are ASCs really capable of doing such work?
* Anything else that we need to be aware of?
naveenroy is offline   Reply With Quote
Old 3rd February 2013, 22:33   #154
Thanked: 526 Times
Default Re: After accident advice needed - Ford Figo
Very sad to see a car in this state. I struggled hard to find a 'car' in the picture.I won't believe what ASC is saying and would go for a total write off. The entire crumble zone is gone and I am expecting a bill close to the cost of the car.
poloman is offline   (1) Thanks Reply With Quote
Old 3rd February 2013, 22:38   #155
gemithomas's Avatar
Thanked: 137 Times
A Goat Caused that!! Should i really start thinking of changing to another car!!
What is the quote for the repair? Now that he is getting it done. The only option he has is to get it done through the dealer. No other choice.
But there is every possibility that the next goat might just end up in the cabin.
gemithomas is offline   (1) Thanks Reply With Quote
Old 3rd February 2013, 22:41   #156
SS-Traveller's Avatar
Thanked: 11,137 Times
Would be difficult to comment on whether the ASC is really capable of doing the work, unless one knows about the tools and jigs available at the body shop, and their technicians' level of expertise.
Suggestions:
1. Ask the insurer whether they'll cover the cost of a new bodyshell.
2. Send an email to Ford enclosing the photographs, explain the situation and enquire whether Ford engineers will inspect and vouch for the quality of work done in writing, and whether they will guarantee that the quality of work and alignment of the monocoque will be as good as original.
An improperly aligned setup and weld will plague the car with alignment, unusual tyre wear and suspension problems for ever.
A goat didn't cause that, a casual meeting with a concrete median did!
SS-Traveller is offline   (4) Thanks Reply With Quote
Old 3rd February 2013, 22:45   #157
Thanked: 363 Times
As a rule, factory fit is always better than any repair work done afterwards.
However, with the correct equipment and trained staff, the difference will be minimal. Given this, you need to check on the equipment and staff. If they are good, don't really worry about the work that will be done.
pganapathy is offline   (1) Thanks Reply With Quote
Old 4th February 2013, 08:08   #158
hrman's Avatar
Thanked: 383 Times
Very sorry to see the car in this state. Am glad your friend came out safe, thanks to Airbags. As pointed above, its difficult to assess the quality of workmanship of the Service center, unless someone has had experience and posts here.
But in your friend's place, I would contact ford and get an assurance that the repaired car will be as good as a new one, especially with regards to safety.
Else hope the repair workshop quotes an amount higher than 80% of the IDV, so that it can be written off and he can purchase a new one. In any case, even if this is repaired, I would recommend to sell it off and buy a new one, just for peace of mind.
hrman is offline   (1) Thanks Reply With Quote
Old 4th February 2013, 08:44   #159
ghodlur's Avatar
Thanked: 2,254 Times
Red face Re: After accident advice needed - Ford Figo
OMG, the car has taken quite a beating. Glad to know that the occupants are safe.
SHouldnt this be considered for a total loss even though Ford enginers have accepted that they can repair the chasis. Dont know if the structural integrity of the crumble zone will hold up after spot welding. The weak spot will remain IMO.
One question - are the roads your friend travelled worth for a 100kmph run?
ghodlur is offline   (1) Thanks Reply With Quote
Old 4th February 2013, 10:10   #160
dhanushs's Avatar
Thanked: 4,142 Times
Apron damage usually needs very high precision of work. Or else, the vehicle is surely bound to have alignment issues.
IMO, (its possible in Kerala) talk to the insurance guys, and ask for a total loss. They might not agree, but, if you can sell the car in as is condition, the insurance might refund you the remaining cost of the insured value. Considering, the repairs will be higher than that.
However, since the work has already started, not sure if its practical, but still worth a try as I mentioned, if work is not upto the mark, you will have problems in future.
If the above mentioned is not possible, then, please send Ford an email, like SST suggested. Make Sure, the work will be done properly.
dhanushs is offline   (2) Thanks Reply With Quote
Old 4th February 2013, 10:44   #161
Awaiting Email Confirmation
Thanked: 350 Times
Post deleted by the Team-BHP Support : Please do NOT post one-liners that add little or no informational value to the thread. We need your co-operation to maintain the overall quality of this forum.
Please read our rules before proceeding any further.
gemi_kk is offline   Reply With Quote Received Infraction
Old 4th February 2013, 18:52   #162
naveenroy's Avatar
Thanked: 703 Times
The quote he has been given is around 1.2L for parts etc and around 40K for labour.
Yes, this is what I was worried about as soon as I saw the state it was in.
Yes, glad he made it out alive without any injury to him or anyone else. The safety devices and the crumple zone actually did their jobs. Yes, they have quoted around 1.6L for the whole job. Would that be 80% higher than IDV?
Well, to be honest - the car looks worse than it was after the accident. There was no actual damage to the front side panel even. It looks a lot more scarier since they have removed the apron and the engine and car looks naked.
And about 100 kmph - it was on the NH7 - and I know how careful a driver he is.
Yes, but friend tells me that the work has already started - he has paid an amount upfront too. Not sure if we can ask insurance guys to write it off now. Only option left would be to contact Ford and see how they can provide us an assurance that there will be no worries in future due to any shoddy work or even good work.
I appreciate all your inputs and my friend is actually following this thread. Thanks for that and can any of you also provide some details of someone to contact in Ford - someone higher up the ladder. Friend tried calling customer service and they gave the usual "everything will be fine" line. I would really like someone to be able to assure him in words - an email.
Old 5th February 2013, 17:50   #163
.sourov's Avatar
Thanked: 26 Times
Default Re: Need advice after Accident
I had an accident in Krishnagiri last year and today when i reach home i received a letter from civil court of Krishnagiri that a petition is filed is against my name and the injured person is demanding 10 lac of Rupees as compensation. I observed that in the letter my name is at no.1 and the insurance company at no.2 and there is court session regarding this on 12th of Feb.
When i called up the insurance company and they informed that i need not worry about this and they will take care of it as they need to fight this case from their end and i need only come to court on day if they send me "summon" to explain what happened.
During the accident i was booked with a FIR under 279 and 337 and the hearing for it is still pending (already 4 months over) and now i get this. I am confused what to do now as i don't trust the insurance company because if they are not present at that day then i might get in trouble or this is the thing to be taken care by the insurance company only.
Can you guys please throw some light regarding this matter?
.sourov
.sourov is online now   Reply With Quote
Old 5th February 2013, 18:30   #164
Warwithwheels's Avatar
Thanked: 1,014 Times
Originally Posted by .sourov View Post
..Can you guys please throw some light regarding this matter?
Please engage a experienced lawyer ASAP. Let the lawyer deal with the other parties.
Warwithwheels is offline   Reply With Quote
Old 5th February 2013, 18:50   #165
speedmiester's Avatar
Thanked: 838 Times
.sourov
If you have not reached an agreement with the other party after the accident and the other party has filed a case, then this is standard procedure.
You need not worry much. As suggested by your insurance company, this is a case they will fight. You will only be required to visit the court if they send you a summons.
Your insurance company will take care of the compensation claim and you need not pay a single paisa towards it. The compensation claim case may take more than 5 or 6 years to settle. You will not be required to attend the court for the compensation settlement.
speedmiester is offline   (2) Thanks Reply With Quote
Need advice after an accident ajitjt Street Experiences 9 19th October 2011 15:58
A car accident, a life lost - need some advice Radha Shelat Street Experiences 32 18th March 2011 07:28
Need good advice/lawyer related to Motor vehicle accident - DELHI alpha1 Shifting gears 12 22nd July 2010 22:57
Got into an accident with my SX4 - Need advice on the repairs bkbkr1212 Street Experiences 10 30th June 2010 19:31
