Go Back   Team-BHP > BHP India > Super-Cars & Imports in India
Old 21st March 2013, 13:28   #31
vinair's Avatar
Thanked: 890 Times
Default Re: Profusion Typhoon : 145 BHP, 630 kg weight @ Rs. 55 Lakh
Originally Posted by Chris C View Post
The car is not made of sheet metal it would weigh a lot more than 600kg if it was and have visibale riveted seams all the way along it too.
Look closely at the interiors buddy, the sheet metal is easily visible (also the rivets!!! ) Its not made using any other new material (unknown!!) for sure!!
vinair is offline   Reply With Quote
Old 21st March 2013, 14:05   #32
Harrie's Avatar
Thanked: 20 Times
Body is probably made from reinforced fibreglass. Only the dash is sheet metal.
Harrie is offline   Reply With Quote
Old 22nd March 2013, 15:41   #33
Chris C's Avatar
Thanked: 15 Times
The Interior is as you can see clad in aluminium sheets. I was talking in reference to the body material which is GRP not metal. The Interior is clad in aluminum to keep it cool in the sun and make it easy to clean and waterproof it, if we used GRP inside also it would get damaged too easily. If you look closer the things you think are rivets are in fact stainless button socket bolts. We only use rivets on the cars undertray which cant be seen.
The car body panels are made of GRP mouldings. The dash is also made of two pieces of bonded GRP.
Originally Posted by Maky View Post
The price mentioned is CBU yes? Is it possible for you to bring this in as CKD? If so, How much cheaper would that be?
Also, Could you tell me make of the engine? I think Caterham uses Ford ones...
This is the tentative assembled in India ( we havent released offcial India pricing yet) If it was CBU then the prices would be nearly twice, so over 1 crore, mainly due to the recent duty increases.
We use ford derived units also. Mainly when talking about 4 cylinder engines the industry uses either ford or vauxhall units in various states of tune. Main difference is that most of the industry uses the engine front mounted in longitudinal configuration driving the back wheels, we use it mid mounted and transverse mounted driving the back wheels.
Originally Posted by AdiSinghV12 View Post
Hi Chris! Good to see someone from the company itself on T-BHP. By bigger exhaust, I meant something like the one found on the LP-640. I know the two are totally different cars but it'd make this one look much more aggressive and desirable. The straight top one would be interesting. Bring it onn!
We can change the exhaust tip to be a little larger its already 4 inches across but only within limits as the chassis rails may get in the way if its too big. This is a easy personaisation. We originally played with a twin exit exhaust however dropped it due to the extra weight.
Chris C is offline   Reply With Quote
Old 9th October 2014, 20:14   #34
Thanked: 10,642 Times
Well two years on, nothing has happened, I understand the car came and went. No claims were proven on how good the car was
Meanwhile the ex Caterham guys are building a new car
www.zenoscars.com
They have pulled out all the stops to build a superior car which will be much superior. Read some reviews, looks good!
Renault's new two-cylinder, two-stroke 730cc diesel with 67 BHP & 145 Nm torque RavenAvi The International Automotive Scene 5 24th December 2014 07:39
EP-630 or any other good earphones? DCEite Gadgets, Computers & Software 17 29th October 2012 10:48
*Rumour* : GM to introduce the Baojun 630 sedan in India Aiel The Indian Car Scene 31 21st March 2011 17:37
Vandenbrink Design unveils special coachbuilt Ferrari GTO(599 & 630)... AyAn! The International Automotive Scene 5 23rd March 2009 23:40
