Go Back   Team-BHP > BHP India > Super-Cars & Imports in India
Old 11th June 2010, 01:00   #61
3.2 litre inline 6 M powerplant, 6 speed gearbox, stiffened chasis and suspension (I've driven a 318!) M badging interior and exterior, dash, gearknob etc, 12" ventilated discs, 17" Mtosport rims, I have a feeling itis an M, but all doubts clear when I put my right foot down or when I'm straightening out a curve at an insane speed , feeling total safe and in control; maybe you're right about the mirrors (I'm no expert), maybe the UK spec 4 door came with the standard mirrors, maybe mine were switched somewhere along the way, but who cares, for me performance is more satisfying than badging and I'm totally in love with this car!! Thanks for your interest
Camraan
Originally Posted by Mpower View Post
That cannot be an M3 by birth. It doesn't have the correct mirrors or the front clip. Is it an m3 transplant on a 318i?
Camraan is offline   Reply With Quote
Old 11th June 2010, 01:06   #62
Thanked: 47 Times
its an m3 alright, you have to drive her to believe it, one of the best cars i've driven even though its over 10 yrs old
adilkhan5 is offline   Reply With Quote
Old 11th June 2010, 09:28   #63
Thanked: 11,075 Times
It is registered as a 1600 cc car as per the Karnataka RTO website
But based on the chassis no, i decoded it was a 318i
Chassis number XXXXXXXXX
Vehicle code CA98
Series E36
Model 318i ( 318i M43 )
Body type saloon
Catalog model ZA
Production date 1995 / 11
Engine M43
Transmission Manual
Steering Right
Catalyzer NONE
Old 11th June 2010, 11:31   #64
Thanked: 47 Times
Don't think its the same car you are refering to
Old 17th June 2010, 11:17   #65
suhaas307's Avatar
Thanked: 6,953 Times
Ajmat,
You're right. That seems to be an E36 BMW 318i with some modifications. I love the paint scheme and the extra bits; but this car deserves a set of BBS RS wheels. That would set it off brilliantly IMO.
Pic for reference:
suhaas307 is offline   Reply With Quote
Old 17th June 2010, 14:20   #66
Adil
Check the reg of the car on BTIS - Bangalore Transport Information System
It provides the chassis no, engine capacity etc
Take the chassis no and check thhe details on any BMW enthusiasts site which explains/ decodes the origin of the car.
You cannot hold out the truth on the web!
Old 12th October 2010, 10:50   #67
Thanked: 159 Times
Here are pictures of the other supercharged M3 e92 ...
Picture 4 - of the white halos, has the intercooler removed and are being tested for brightness on ignition mode 2 to see the difference between having the engine running and ignition mode 2.
Picture 5 - BMW performance seats, they need the ECU to be reflashed so its not advisable unless you are remapping everything all over again. Until then you can move your car.
Picture 12 - the Akrapovic titanium evolution exhaust - de cat. for maximum power.
And the Mustang ...
insideman is offline   (1) Thanks Reply With Quote
Old 12th October 2010, 11:28   #68
Thanked: 159 Times
sorry, its the 11th Picture that is the de-cat exhaust and also its a 1968 Mustang Coupe and not a 66 as written above.
insideman is offline   Reply With Quote
Old 12th October 2010, 11:34   #69
speedy's Avatar
Thanked: 929 Times
I believe the Mustang had suffered some damage so has it been fixed yet?
I also did see the M3 being loaded onto the flatbed so if you dont mind sheding some light on to this? You can feel free to decline answering as my only thing was to know the reason as others might speculate and alot of stories would be created. Thank you.
speedy is offline   Reply With Quote
Old 12th October 2010, 11:34   #70
maximuzz's Avatar
Thanked: 62 Times
Wow The M3 looks like a beast waiting to pounce on its prey. Love the alloys !! This car is becoming very popular these days. If it suits my pocket I just might go for one myself soon Great Pics!!
Last edited by GTO : 13th October 2010 at 10:37. Reason: Strictly no SMS language please. Corrected
maximuzz is offline   Reply With Quote
Old 12th October 2010, 12:18   #71
Thanked: 159 Times
The Mustang was repaired the same week it has the little incident. The bolt threading filed away and the wheel got stuck in the wheel arch and there was no damage really, only a 2 by 1 inch fold in the arch.. its been repaired and is fine.
The M3 was loaded onto the truck and was taken to the workshop for a stage 3 tune.
It now has straight pipes and a full de-cat evolution exhaust saving over 25 kg and alots alot more horses sans cats.
It will also run a smaller pulley, larger intercooler, the new stage 3 ECU flash and larger cold air intake with K'n'N filter. making the car run cooler and quicker.
It was loaded on the truck because:
You cant drive the car with the new ECU flashed to the stage 3 kit without fixing the smaller pulley, larger inter cooler and the exhaust WITH CATS. so it was loaded and taken away. + you save a lot of weight when you change the seats but its an issue as you have to reflash your entire ECU so we decided to map to stage 3 and upgrade. Only thing lacking is stage 3 suspension and the wheels off the new M3 GTS. (staying OEM with the wheels as PS2s are the best, and BMW can provide the wheels.
Old 12th October 2010, 12:20   #72
Thanked: 159 Times
Picture 5 - BMW performance seats, they need the ECU to be reflashed so its not advisable unless you are remapping everything all over again. Until then you CANNOT move your car.
Old 12th October 2010, 12:46   #73
Thanked: 159 Times
Here is the exhaust -
X pipe de-cat and straight pipe de-cat. Both pre-tested and Cats completely removed so there is absolutely no drone.
Oh yes, Also a matte black, rough texture plenum, that is perforated so it runs cooler and keeps the moisture out cause its quite hot here in bombay and its better to run this plenum rather than a gloss black finished plenum like the car was running before.
a car than runs cooler is a quicker car
Old 12th October 2010, 12:47   #74
speedy's Avatar
Thanked: 929 Times
Insideman glad to hear about the mustang being in good health.
I did see the car drive out of its resting place upto the flatbed, so no doubt of something being wrong. I thought as much either she is going in for an upgrade or maybe a service. There are many owners who do not like their cars being driven down to the far off service stations ans rather have it flatbedded off. The other thought that came in was she might be headed to Chennai for the event, but since it was i Sat i said it could not be the case unless she is headed to the airport.
So i see GTS is the object of desire and eventually she is getting there. Nice and i would love to see her ready and yeah she sounds good now so i can just imagine what she would sound like later. All the best and drive safe.
Old 12th October 2010, 13:26   #75
Thanked: 159 Times
GTS isnt the objective. the car must handle like a gts and i like the gts wheels. not dubs(20 inch) and i want them to be mono cast wheels. And have a slight factory look but also slightly modified.
But yes, the handling of the car must be top draw...
2008 Shelby GT500KR - The Most Powerful Mustang EVER! pawan The International Automotive Scene 35 30th March 2010 17:05
2009 Ferrari Scuderia Spider 16M Brabus E V12 The International Automotive Scene 21 6th April 2009 11:48
Ferrari F430 Scuderia (Challenge Stradale) highwayblaze The International Automotive Scene 26 21st November 2008 07:17
Novitec Rosso Ferrari 430 Scuderia Brabus E V12 The International Automotive Scene 9 30th June 2008 10:59
Prancing Steel Horse: custom Scuderia Ferrari chopper danlalan The International Automotive Scene 10 21st February 2007 17:33
