Go Back   Team-BHP > BHP India > Motorbikes > Superbikes & Imports
Old 27th November 2013, 12:00   #691
n_aditya's Avatar
Thanked: 2,748 Times
Default re: Triumph motorcycles to enter India. Edit: Now Launched Pg. 48
Originally Posted by pratap.pratu View Post
Is Daytona 675 indian market's first Official Sports bike ? Also, these days bikes right from 200cc onwards has only auto start. I mean what happens if the battery wears out in middle of traffic signal if a rider would have overlooked battery maintenance ? Can anyone throw light on this pls.
Well these bikes don't breakdown that easily if one maintains them well.
Batteries should last a good 2 years if the bike is running at least once or twice a month. A nice highway blast will ensure proper charging and discharging of the battery. Running the bike for short distances and within city traffic conditions only will reduce the battery life since charge and discharge cycles might not reach optimum levels.
So don't worry much about the battery.
If at all the bike dies due to a bad battery, jump start the bike like jkdas has suggested. Never try starting the bike by pushing it and slotting it in gear as it can cause internal damage to the components in the engine or catcon or the FI system.
n_aditya is offline   (1) Thanks Reply With Quote
Old 27th November 2013, 13:09   #692
Thanked: 90 Times
Hello Folks,
pratap.pratu & jkDas - I will address these concerns as best as I can in, simple steps. Here goes...
With most bikes from standard manufacturers as soon as you turn on the ignition and prior to thumbing the start button, there are a couple of steps that the ECM does prior to energizing the circuit to the starter motor. Think of it as a pre-flight check a pilot does.
It will check the voltage across the battery terminal. Only if the voltage is 12.3 to 12.5V or more will it energize the starter circuit.
Else, you may hear the fuel pump start up but only a click when the starter button is thumbed.
The other reasons for not starting up if battery voltage is correct, could be a failed starter solenoid (bridging will help you get out this situation) and/ or side stand down/ vehicle in gear/ engine trouble as diagnosed by the ECM.
However, since the topic under discussion is low battery voltage, I will limit discussions.
You could push start some bikes, however, if the bike in question has a slipper clutch, then push starting is out of question.
BB
Britishbangers is offline   (2) Thanks Reply With Quote
Old 27th November 2013, 16:40   #693
r_nairtvm's Avatar
Thanked: 1,531 Times
As BB would confirm, we have push statrted the Bonnie and 675 s right ?
Actually the as with many new batteries - the Triumph ones (usually Yuasa) are maintenance free and is sealed. There is noting much to do with it. One thing you can do is during oil change is to just ensure that the terminals are "salt" free and keep the terminals vasilined.
My 1st Battery lasted more than 3.5 years - with long periods of non use of the bike (often more than 45 days at a stretch) as well in between.
I think the same case with BB's Scrambler
Best Regards & Thanks
Ram
r_nairtvm is offline   Reply With Quote
Old 27th November 2013, 17:26   #694
ku69rd's Avatar
Thanked: 1,226 Times
Mate,
Unless the alternator is malfunctioning there is no way a a running battery can run out of charge in midst of riding. Highly unlikely cause if the cells in the battery are bad/weakened then it just cannot afford to start the motorcycle.
Even with a jump start a poor battery will not sustain it once the donor battery's connections are taken off.
ku69rd is offline   (1) Thanks Reply With Quote
Old 27th November 2013, 19:07   #695
Thanked: 90 Times
Hello Folks,
Mr Ram - YES! we have push started the Scrambler, the Thruxton and a 675. All after more than 2.5 years on standard batteries and in the mornings when we were desperate for the adrenalin rush on Friday mornings.
Ku69rd - Yes! you are bang on target about a running bike stalling due to the battery - unless it shorts itself out.
On a lighter vein, I had a 1976 Bullet Deluxe, die out on me due to a short with the battery rack. The charge escaped along with the smoke!
Happy Daze!
Reg,
BB
Britishbangers is offline   Reply With Quote
Old 27th November 2013, 23:02   #696
Thanked: 39 Times
Thanks all for sharing some useful info on this. My point was directed towards, how much important a battery indicator is on a bike just like the one we see in cars. Do we have it by the way ?
@kU69rd: I understood what u told mate, but what I meant was, if the driver switches off engine during at at traffic signal and to this issue crops up.anyways thanks for your thoughts on this.
pratap.pratu is offline   Reply With Quote
Old 28th November 2013, 10:27   #697
rshanker's Avatar
Thanked: 283 Times
Today is the day! The launch is being telecast live at the following link
http://triumphmotorcycles.in/news-an...h-india-launch
Starts at 11:30 hrs.
rshanker is offline   (4) Thanks Reply With Quote
Old 28th November 2013, 10:59   #698
ku69rd's Avatar
Am pretty sure anyone with the right frame of mind would not shut down the engine at traffic signal especially when the battery is dying.
If's and but's does make our lives interesting though
ku69rd is offline   Reply With Quote
Old 28th November 2013, 11:45   #699
rm_arjuna's Avatar
Thanked: 55 Times
Hyd's Triumph dealership located at Banjara Hills Rd # 10 - Rebel motorcycles Pvt ltd. time to hit the dealership for test ride
rm_arjuna is offline   (1) Thanks Reply With Quote
Old 28th November 2013, 12:05   #700
rshanker's Avatar
Thanked: 283 Times
The Bonneville starts at 5.75L~ Great Pricing?
rshanker is offline   Reply With Quote
Old 28th November 2013, 12:06   #701
dkaile's Avatar
Thanked: 4,055 Times
Bonney priced at 5.7L; T100 6.6L; Street Triple 7.5L
dkaile is online now   (2) Thanks Reply With Quote
Old 28th November 2013, 12:10   #702
Thanked: 44 Times
i Just got goose bumps looking at the street triple!
Ex-showroom price announced for street triple is 7.5 lacs
hsub is offline   (1) Thanks Reply With Quote
Old 28th November 2013, 12:26   #703
Shubz's Avatar
Thanked: 985 Times
Bonneville
5.7L ex Showroom
Thruxton
6.7L ex Showroom
Street Triple
7.5L ex Showroom (Am glad I made a certain decision)
Speed Triple
10.4L ex Showroom
Thunderbird Storm
17L ex showroom
Rocket III
20L Ex Showroom
Tiger 800
XC - 12L Ex Showroom
Explorer - 17.9 L Ex Showroom
Daytona 675
11.4 L Ex Showroom
Shubz is offline   (2) Thanks Reply With Quote
Old 28th November 2013, 12:26   #704
ku69rd's Avatar
Wow what a sloppy show put up by Vimal. Strongly think he has to learn some basic presentation skills and not afford to goof up things.
Suppose the whole affair was shoddy and accompanied by a ramp walk. Never got the idea of riding the bike onto the stage rather than simply unfurling it.
Anyways here are the prices.
Bonnie --> 575 X Showroom
T 100 --> 660 X Showroom
Thruxton --> 670 X Showroom
Street Triple --> 750 X Showroom
Speed Triple --> 10.4 X Showroom
Thunderbird Storm --> 13 X Showroom
Rocket --> 20 X Showroom
Tiger 800 XC --> 12 X Showroom
Tiger 1250 --> 17.9 X Showroom
Daytona --> 11.4 X Showroom
All the best Triumph and a big welcome to India
Yipee Bangy going live by end of december along with Hyderabad.
ku69rd is offline   (3) Thanks Reply With Quote
Old 28th November 2013, 12:33   #705
rshanker's Avatar
Thanked: 283 Times
Has production already started?
rshanker is offline   (1) Thanks Reply With Quote
Triumph Bonneville - My New Ride in Dubai. EDIT - Now in Bangalore, India. r_nairtvm Superbikes & Imports 203 16th November 2017 19:41
Regal Raptor & other suspect motorcycle manufacturers in India Tushar Motorbikes 26 19th June 2017 11:30
VW to enter the used car market. EDIT "Das WeltAuto" Launched libranof1987 The Indian Car Scene 22 17th December 2012 15:09
Vespa Set To Re-enter India. EDIT: Now Launched @ Rs.66,661/- ex-showroom Maharashtra Car-Agey Motorbikes 42 26th April 2012 18:02
Triumph Motorcycles @ Auto Expo 2012 parrys Superbikes & Imports 77 24th February 2012 18:47
