Go Back   Team-BHP > BHP India > Motorbikes > Superbikes & Imports
Old 5th January 2012, 11:06   #16
Thanked: 164 Times
Default Re: Honda to Launch Honda - CBR600F in India
Yes, if the prices don't match with Ninja 650, 600F wont take off.
shamanth is offline   Reply With Quote
Old 5th January 2012, 11:17   #17
gsferrari's Avatar
Thanked: 135 Times
I don't know if you guys are talking from experience or just shooting off from the hip...You can get into a LOT of trouble with the 68 Bhp parallel twin in a 650R. Does 210 kph sound slow to you? That too when the rider weights 120 Kilos and is 6'3" tall and about the same width?
yes...I own a 650R and I think it is a fantastic all-rounder but I can see why someone would want an inline 4. But if you haven't ridden a 650R in anger...don't knock it. Past 6000 rpm this thing screams as well!
gsferrari is offline   Reply With Quote
Old 5th January 2012, 11:29   #18
Thanked: 444 Times
GS -
650R was never a slouch, it is just that the feel of an in line 4 is entirely different. I have been in company of R1's for some time now, would not like to stretch this any further.
Cheers Mate.
Torquedo is offline   (1) Thanks Reply With Quote
Old 5th January 2012, 11:36   #19
gsferrari's Avatar
Thanked: 135 Times
No I agree...but if someone is not buying a 650R (well...you cannot buy one now anyway) when it is within budget...simply because they want an i4 which is NOT in budget, then it doesn't make sense. Heck I want a Hayabusa now and it is an itch I have to fight scratching because I don't want to have that kind of power in hand and not use it (or use it and die).
After buying the 650R...I have come to the conclusion that using a bike is more important than buying something big and keeping it parked away. I use the 650R so much now that my MT01 has been relegated to the garage on a battery tender. I just find it so much more convenient to hop on the 650R and head to the grocery shop and still do 200+ if I want to. It gives me 23 Kpl on the highway at 120 - 150 and it can take me to Ladakh and back. Cheap as chips to fix and with the backing of Bajaj...I really don't have much to worry about.
Ownership cost is something many people forget about by just focusing on the acquisition cost. i4s and larger CC bikes get super pricey to run!
gsferrari is offline   (2) Thanks Reply With Quote
Old 5th January 2012, 11:44   #20
slalom's Avatar
Thanked: 92 Times
The 650 R is a nice bike and given our conditions it is packaged well .
I had an R6 in DXB for quite some time and I'm little acquainted with bigger bikes as well ,and I will go weak in the knees for an Inline four ,they are sweet .
In any case if the CB 600F is going to be priced above 7 lacs I will just pass and fall back on the 650 R .
slalom is offline   (1) Thanks Reply With Quote
Old 5th January 2012, 12:46   #21
aargee's Avatar
Thanked: 2,143 Times
Wow GS!!! Pls share as how a I4 on 600 is expensive to maintain than a twin on 600.
PS - Its a genuine question for learning.
aargee is offline   (1) Thanks Reply With Quote
Old 5th January 2012, 13:04   #22
gsferrari's Avatar
Thanked: 135 Times
More moving parts
Higher revving therefore more wear/tear
Burns oil quicker
Less torque...more clutch slip from standstill
More complex electronics and sensitive fueling
Higher compression ratio than 650R = higher octane fuel needed
The engine also costs more than a twin so if you crash/grenade the engine with irresponsible tuning then you will have to shell out more.
gsferrari is offline   (1) Thanks Reply With Quote
Old 5th January 2012, 13:58   #23
aargee's Avatar
Ok, coming to specifics...
But...how does it fair to long strokes? What I mean is, longer twin stroke should wear out more quicker than shorter 4 cylinders isn't it?
Burns oil quicker
Okay...
Aaha!!! Need to understand this one!!!
But, wouldn't that depend on CR?
Agreed on this front that I'd in my mind initially; but I'm trying to think of possibilities beyond this.
Old 5th January 2012, 14:03   #24
gsferrari's Avatar
Thanked: 135 Times
Greater piston speeds = more wear and tear. Take bullet for example. But in short-stroke motors like the 650R, this isn't an issue. In this case greater revs result in more wear and tear of the rings and block. I'm not entirely sure how this affects the crank and big-end bearings etc.
Most 600s have their first gear limiter at about 110 Kph and sometimes more. 0-100 in ONE GEAR! It is like starting your CBR in 3rd gear
Not sure what CR is...
I wouldn't get a 600cc inline-4. If you want an i4 then 750cc is where the fun starts. A 600 triple is the best compromise...wait for Triumph to launch the 675 in india...will be expensive though!
These aren't hard-fast rules...
Old 5th January 2012, 14:13   #25
aargee's Avatar
Right, so I4's should work out better isn't it?
Hmm...will get through this
Compression Ratio; Sry
Me too as I love torqy engines; but, I'm under the impression that I4 engine's have long life (comparatively) & when you said I4's are expensive to maintain, I was trying to understand on that front.
You bet!!! GSX750...perfect one
Shoots!!! GS...something is wrong with both of us today!!! You're speaking my mind on all fronts!!! The 675 with 52mm stroke is perfect one (not too short, not too long) with adequate torque & top speed.
But again, the base point still remains - I didn't quite understand how I4's are expensive to maintain (barring the accidental or engine work) on regular maintenance work.
Old 5th January 2012, 14:19   #26
gsferrari's Avatar
Thanked: 135 Times
A 350cc long stroke single cylinder like the bullet needs higher piston speeds at the same RPM than a 600cc 4 cylinder short-stroke. Keeping just this in mind, the 4 cylinder is less stressed and will live longer. However, the 600cc 4 cylinder produces less torque than a 600cc single at the lower rev range and needs to be revved harder.
If you ride a KTM 690 at 3500 rpm you will make more progress than if you ride a CBR 600RR at 3500 rpm. But to match the performance you needs far more revs in the CBR and that does increase the stress on the engine...
Old 5th January 2012, 15:25   #27
djay99's Avatar
Thanked: 491 Times
IMO the sweet exhaust note on CBR600F I4 is because of hell lot of stress on engine
If CBR600F is launched at around 6 Lacs then it's definitely gonna sell like hot cakes.
Many people may not worry about the points you mentioned because they never gonna understand them.
All they want is an I4, good looking, sporty bike in the range of 6 lacs.
I am one of them
djay99 is offline   (1) Thanks Reply With Quote
Old 5th January 2012, 15:33   #28
e46
Thanked: 81 Times
Fellas,
Please keep an eye on the HMSI pavilion, if they launch it
Thanks,
Abhishek
e46 is offline   Reply With Quote
Old 5th January 2012, 15:38   #29
Thanked: 444 Times
Originally Posted by e46 View Post
Fellas,
Thanks,
Abhishek
Abhi -
Ha ha , I have been keeping a close eye since morning, but they are launching is absolute TRASH -
CBR150 - Oh ! who needs it.
Dream Yuga - The name in itself, makes me run away, let alone the bike.
It does not seem likely that they would be announcing it for India in AE 2012, might come in later during the year.
Torquedo is offline   Reply With Quote
Old 5th January 2012, 22:55   #30
Sheel's Avatar
Thanked: 5,647 Times
Isn't an I4 designed in such a way as that it can keep spinning in higher rpm's & still run on stock engine. Posting an example
Any engine which peaks at 14,000 revs (torque), makes power at 17,000 & revs to 19,000 should't have much problem till preventive maintenance is carried out. Should it?
New Altis Launch 16th June !!! New Liva Launch 27th June camchennai The Indian Car Scene 218 24th June 2011 22:31
AUDI to launch R8 in India. EDIT : Launch pics on Pg. 3 SumitBahl The Indian Car Scene 76 23rd March 2011 12:16
Pics : Honda CBR600F in Mumbai v12 Super-Cars & Imports in India 28 23rd August 2008 22:35
GM to launch Aveo-UVA with 1.2 Ltr motor..launch by Nov/Dec'06 ashutoshb The Indian Car Scene 5 12th September 2006 03:36
