Go Back   Team-BHP > BHP India > Motorbikes > Superbikes & Imports
Old 20th March 2013, 10:02   #31
yogisays0909's Avatar
Thanked: 156 Times
Default Re: My '93 Honda CBR 600 F2
Originally Posted by manson View Post
I stand corrected! The white mated to the blue graphics with the blue iridium wheels does look rather sexy! I wish you had retained the OEM mirrors though.
Hey bro, i need some help from you.
Will it be easy to find double banjo bolts in Mumbai?
Planning to convert the split brake lines in the front to separate individual brake line feeding each caliper separately.
I found few banjo's over the ner, but i am not sure of the size of the bolt which will fix in to the front master cylinder. here are the 4 sizes available for appx 10 USD. I have a spare F3 master cylinder too on which i wish toc arry out this mod.
Thread Size : M10, P1.0
A : Total Length =34.5mm (1.36inch )
B : Hex 14, thickness =4.29mm (0.17inch )
C : Thread length =30mm (1.18inch )
A : Total Length =42.4mm (1.67inch )
C : Thread length =38mm (1.5inch )
Thread Size : M10, P1.25
A : Total Length =34.3mm (1.35inch )
A : Total Length =43.3mm (1.7inch )
C : Thread length =39mm (1.54inch )
I have also bought complete front forks with the T's of F3 (Amit's F3) and will be dropping the internals and the tubes into my F2 legs, which are a direct bolt on into the F2 legs.
Please help me with the double banjo size and availability.
yogisays0909 is offline   Reply With Quote
Old 20th March 2013, 18:50   #32
manson's Avatar
Thanked: 2,000 Times
In your vicinity, try Navi Mumbai Hardware located in Turbhe Janta market. They usually have everything you would needs in bolts / washers / etc. Other than that walk along the Turbhe naka road towards Turbhe MIDC and you will find atleast a couple of tiny stores who custom make bolts for automtive maintenance.
manson is offline   Reply With Quote
Old 26th March 2013, 00:43   #33
Thanked: 156 Times
My new body armor. Addition to the riding gear
yogisays0909 is offline   (1) Thanks Reply With Quote
Old 3rd April 2013, 12:14   #34
Thanked: 156 Times
Back with some update. Got a very good deal over ebay UK website.
Bought the stuff on Auction sale and delivered to a friends place in Aberdeen.
Items bought for future use.
1)Complete set of cables ie Choke, throttle, clutch, accelerator, speedo
2)Ignition coil set with the leads
3)CDI/ECU
3)Left and right hand switch control along with the throttle tube (my throttle tube is cracked, had noticed while changing the grips)
the switches are with perfect wiring connections along with the throttle cables and choke cable.
Total cost of the above deal was appx Indian rupees 2750. of which shipping charges with Uk were 1200 . So the parts alone costed appx 1500.
Old 3rd April 2013, 13:37   #35
Viju's Avatar
Thanked: 1,592 Times
Wow, that is a fantastic deal, mate. Congratulations. Hope you find more good parts and take the bike to full OE spec.
Viju is offline   Reply With Quote
Old 3rd April 2013, 15:28   #36
n_aditya's Avatar
Thanked: 2,696 Times
That's a really sweet deal considering the exchange rate prevailing now and that shopping in UK is considerably more expensive than in USA.
Old 3rd April 2013, 20:58   #37
Thanked: 156 Times
Hey thanks mate! as of now almost everything is sorted. Sprockets and chain are on the cards, lets see when it materializes
These parts are not required actually, but the price was tempting and could not resist buying them. Over all no damage to the pocket . As itsgoing to be a very very long ownership relation, might be these will be needed not today , tomorrow but may b 10 yrs later.
I will be upgrading the fork tubes too as i get time. K&N needs to be installed. Dynojet is waiting on the shelves to get into the carbs.
Old 6th April 2013, 12:16   #38
Thanked: 156 Times
Got my new Pro-Biker hand gloves. Very cheap deal and thanks to ebay again.
Total damage: rs 475 thru paypal. Don't know if it would attract any customs duty. Body armor posted above costed me appx Rs 1650.
The same gloves are sold locally and on the Indian online sites for 950 to 1500 and the body armor goes for about 2000 to 3000.
Old 5th June 2013, 16:54   #39
Thanked: 156 Times
Back with some updates. The below parts are coming in from UK, USA & HK
UK
1)Set of good used Carbs with the boots.
2)Fairing stay bracket
USA
1)Cam Chain, Cam chain guide & Slider for safety, as i would be installing the manual CCT
2)Fuse box cover which was missing since the day one
3)Used front discs almost new factory specs is 5.2MM these are 5.1MM
4)Front Brake lines as a spare, seems mine will be worn out within couple of years
5)Wavy rear brake disc
HK
1)New brake and clutch levers, long adjustable ones, red anodized.
Total Damage for all of the above: 10.5K and free shipping as these will be brought in by my friends to Iraq.
Old 5th June 2013, 18:23   #40
Viju's Avatar
Again, some nice shopping you have done there. Glad to see that you have long-term plans for this bike.
Just did not understand the point about 'Wavy rear brake disc'. What do you mean by this?
Cheers!
Old 5th June 2013, 21:21   #41
Thanked: 156 Times
Cheers!
Here you go with the pics for the parts. Wavy discs are not just round like the stock ones. My stock discs at the rear are completely gone and i can see small cracks too in some of the drills
Yogisays09's 2011 Suzuki Bandit GSF1250S and 2007 Honda CBR 1000RR-cam-chain.jpg
Old 7th June 2013, 23:58   #42
Thanked: 156 Times
Here is the pic of the F3 forks and rear set which i had got few months back.
F3 fork internals will be dropped into my F2 fork legs and will sell of the F3 legs. F3 forks are way better than F2 forks.
Yogisays09's 2011 Suzuki Bandit GSF1250S and 2007 Honda CBR 1000RR-img_20130227_195417.jpg
Old 14th June 2013, 19:52   #43
manson's Avatar
Great updates Yogi. Having the fireblade around for almost five years, I can totally relate to having these inexpensive spares handy. I myself use ebay for almost all of my bike related shopping.
Adi, shipping from UK to India is usually cheaper and even relatively faster than havin stuff shipped from the US.
manson is offline   (1) Thanks Reply With Quote
Old 20th June 2013, 01:20   #44
Thanked: 156 Times
Yaah man. Its better to keep such spares handy. You never know!!! And at the time of need we end up paying 10times higher for such spares. Just for example i got the spare CDI for appx 500 rupees and if do a search for buy it now and shipping to India,it show minimum 12 to 14 thousand rupees.
There are times when the ebay deals are tempting and specially no reserve auctions.
Shipping from US to India. Forget about the parcel if its coming by usps ordinary mail. I have recently lost a parcel which was shipped on 18 March and never reached me!!!!
Old 27th June 2013, 09:53   #45
Thanked: 156 Times
Default Pics of the spares
Hey guys here are the pics of some of the spares, at this moment these are all in the UK with a friend and will be coming in parts to me as he would be bring these one by one to Iraq every month for me.
Yogisays09's 2011 Suzuki Bandit GSF1250S and 2007 Honda CBR 1000RR-img20130626wa0009.jpg
Yogisays09's 2011 Suzuki Bandit GSF1250S and 2007 Honda CBR 1000RR-img20130626wa0010.jpg
Yogisays09's 2011 Suzuki Bandit GSF1250S and 2007 Honda CBR 1000RR-img20130626wa0011.jpg
Yogisays09's 2011 Suzuki Bandit GSF1250S and 2007 Honda CBR 1000RR-img20130626wa0012.jpg
Yogisays09's 2011 Suzuki Bandit GSF1250S and 2007 Honda CBR 1000RR-img20130626wa0014.jpg
Yogisays09's 2011 Suzuki Bandit GSF1250S and 2007 Honda CBR 1000RR-img20130626wa0015.jpg
Yogisays09's 2011 Suzuki Bandit GSF1250S and 2007 Honda CBR 1000RR-img20130626wa0019.jpg
Yogisays09's 2011 Suzuki Bandit GSF1250S and 2007 Honda CBR 1000RR-img20130626wa0016.jpg
2012 Honda CBR 1000RR Fireblade - Revealed! Scorcher Superbikes & Imports 9 22nd August 2011 16:36
CBR 1000rr for sale sandeep6181 Shifting gears 0 26th July 2007 16:01
Pics : 2005 Repsol Honda CBR 1000RR fireblade in Chennai! nitrous Super-Cars & Imports in India 25 5th December 2005 21:26
SPOTTED :2 mini motos , 1 Kawasaki Vulkan , 2005 CBR 1000RR n 2005 ZX10R varun_patra Super-Cars & Imports in India 1 31st October 2005 12:45
