| LinkBack | Thread Tools | Search this Thread |
| | #166 | |
| BHPian | Quote:
| | #167 |
| BHPian | Next, we mate the gear set assy and trap door with the tranny housing. The mainshaft goes through the drive gear and bearing, the countershaft seats in the needle bearing housing, making sure the gears don't bind and rotate freely. ![]() We then install the shifter paw. This locks the shifter drum into place, while changing gears. ![]() Tighten the bolts to the required torque spec. ![]() Install the shifter dogs, making sure they seat in their respective grooves. ![]() ![]() Next, install the shifter drum (not shown in pics) and as always, 'close the lid'. Install the speed sensor. Job done! ![]() Note: The gear set assy was assembled onto the trap door earlier on, its a very elaborate process which I decided to skip on this thread. |
| | #168 |
| Senior - BHPian | Simply mind blowing buddy. Your hard work& attention to detail shows in your work. Waiting to see the bike! |
| | #169 | |
| Senior - BHPian Join Date: Jan 2010 Location: Chennai
Thanked: 382 Times
| The parts looks so much in quality; the hard work that has undergone is clearly visible!!! I couldn't understand this part & the necessity of it; some details is appreciated. Tks. Quote:
PS - I'll be waiting to hear from you on the clutch assembly, primary & main gear drives ![]() Edit - BTW, how does this part of metal looks black? Is it powder coating or something? Last edited by aargee : 15th November 2010 at 20:19. | |
| | #170 |
| Senior - BHPian Join Date: Dec 2005 Location: Ridin earth now
Thanked: 106 Times
| I have a question , are these parts ,transmission (gears ),head , bore ,you guys built in house ? .Or where they bought separately(imported) and assembled here? I love the tools you guys have .Could you tell me the size and make of this ratchet(http://www.team-bhp.com/forum/attach...fatboy-g_6.jpg) .I have bigger 1 foot one , Need to get smaller one like this for smaller places . Good work ,please post plenty of pics . Last edited by black12rr : 15th November 2010 at 20:44. |
| | #171 | |||
| BHPian | Quote:
The tranny housing is powder coated, Black Wrinkle finish. Quote:
Thanks for all the appreciation, this is my FUEL. | |||
| | #172 |
| Newbie Join Date: Sep 2010 Location: Bangalore
| I guess, we have already established what a great project this is and how great your pictorial chronicling of the assembly is. I'd like to compliment you for your wit and and the spirit with which you are approaching this task! Bravo! We continue to follow you virtually and derive vicarious pleasure from your milestones. |
| | #173 | ||
| BHPian | Quote:
Disclaimer - The stunts performed on this thread have been done under the close supervision of a bunch of lunatics, please do not try them at home. But even if you want to you are most welcome, but be warned that they are emotionally draining and make sure you are not married. Last edited by luky_13 : 16th November 2010 at 10:55. | ||
| | (3)
| | #174 |
| BHPian | With the tranny and motor out of the way, time to focus on the frame. Parts that needed welding: 1. Front motor mount 2. Top motor mount 3. Forwards control (LHS & RHS) bracket 4. Gussets 5. Oil tank bracket 6. Shock absorber bracket This is where we left the frame last. ![]() Had to seat the motor to get the position of the motor mounts. I adjusted the forward controls to suit them to my comfort zone. The oil tank was seated to get the position of the battery, electricals and wiring harness correct. This is the full list![]() Welding was split into two parts, tack and final weld. We wanted to check out some dimensions before the final welding. Started with tacking the Top and Front motor mounts. ![]() Then once motor mount references were available, we removed them and tacked the forward control brackets and all other parts. ![]() Once all the tacking was over the frame was removed from the jig and flipped to weld under. ![]() Finishing the weld on the front mount ![]() Here shown the neck area with all the gussets etc. ![]() And finally, the oil tank bracket ![]() There was welding, welding and more welding. We welded the lefts the rights the tops and the bottoms, literally. Exhausted and exasperated we went back home and the next day morning, my eyes wouldn't open. I had been watching all the welding through the side of my eyes. More later. |
| | #175 | ||
Thanked: 382 Times
| Quote:
![]() Quote:
Yes, I can understand. How do you make a quality finish? Some finished outcome & their methods with pics is highly appreciated. Tks. | ||
| | #176 | |
| BHPian | Quote:
| | #177 |
| BHPian | This is how the frame was designed to look like... ![]() ...and this is how it eventually turned out to be. ![]() Some differences between the design and development: 1. The down-tube angle was changed from 101 deg. to 104 deg. This was done to accommodate the excessive vibrations that the unbalanced twin cam engine produces at lower rpm's (mostly at idling). 101 deg was getting too close to the engine head, so we moved it further by 3 deg for safety. 2. The point where the forward controls get mounted was changed from a uniform arc to steps. This was done to simplify the front motor mounting. The forward control bracket were also modified for better driving comfort. 3. The drawing does not show the rear struts, the development does. |
| | #178 | ||
Thanked: 382 Times
| Quote:
![]() I remember you telling this somewhere in the previous pages & also quoted that you made this mistake & imagine how HD makes 1000's of these precisely at their factory everyday. Isn't this same as that one or something different? How's this frame different from stock frame? Didn't the 88cu engines come in 2 variants? Regular 88 & 88B? I'm little confused. Quote:
Err...is this the self motor or something different? Also, I find the drawing's rake angle wider than the actual output of the frame or is it just my assumption? | ||
| | #179 | ||||||
| BHPian | Quote:
| | #180 |
| BHPian Join Date: Dec 2009 Location: Patiala
Thanked: 16 Times
Similar Threads | ||||
| Harley Davidson - Fatboy or Crossbones | trammway | Superbikes & Imports | 15 | 23rd September 2012 06:15 |
| FatBoy is here! | FatBoy | Introduce yourself | 2 | 4th May 2012 06:48 |
| Harley Fatboy Sidecar | Nat_Bambo | Superbikes & Imports | 9 | 15th September 2010 22:28 |
