Go Back   Team-BHP > BHP India > Motorbikes > Superbikes & Imports
Old 22nd November 2011, 22:10   #241
pranava999's Avatar
Thanked: 19 Times
Default Re: Dreamweaver build-off: HD Fatboy
Whoaa...coming in after a long time!!I remember, the days when you started the thread and were working on the design, and now to see how far you have progressed, is just awesome.Congrats. It's a stunner!
pranava999 is offline   Reply With Quote
Old 23rd November 2011, 12:48   #242
invincible7's Avatar
Thanked: 131 Times
WOW... Congratulations man, she is a beast in a beautiful shell.
Kudos to your hardwork and passion, never seen anyone so focussed towards one bike.
invincible7 is offline   Reply With Quote
Old 23rd November 2011, 16:48   #243
BIG SARAN's Avatar
What a beauty !!!! Heartiest Congratulations Sir. Was waiting for this post for sooo long. Can't wait it see it thundering on the roads.
All the best.
Ride Hard.
BIG SARAN is offline   Reply With Quote
Old 23rd November 2011, 17:11   #244
m3_07's Avatar
Thanked: 181 Times
Lucky 13 .....You Sir have done a wonderful job. I have come across very few people who have had that span of patience you have exhibited. It is really an honour to have a fellow Banglorean/ Indian to have accomplished this feat.
PS: OT, it would be really interesting to know what HD feels about this project, with all their R&D one one side & Your most competent/ ACCOMPLISHED team on the other??
Once again....Congratulations Sir !!
m3_07 is offline   Reply With Quote
Old 23rd November 2011, 18:45   #245
Rennjit's Avatar
Thanked: 77 Times
Thumbs up Re: Dreamweaver build-off: HD Fatboy
luky_13. Building up a frame from scratch that too for a heavy machine, just awesome! we wait for build pics & story..
Rennjit is offline   Reply With Quote
Old 25th November 2011, 07:32   #246
luky_13's Avatar
Thanked: 116 Times
Picking up the story where I last left it - Wiring harness. I quickly realized how intimidating this was and actually making me nervous. Routing the wiring harness was proving to be a challenge, had to make sure none of the wires got pinched while riding. We must have installed and uninstalled the harness around half a dozen times. Some Deutsch connectors had to be crimped, complete headlamp wiring had to be figured out. I actually managed to connect the headlamp to the horn switch, can you beat that! With a lot of help from the Softail Electrical Diagnostic Manual we ultimately got the job done to satisfaction.
Dreamweaver build-off: HD Fatboy-wiring1.jpg
luky_13 is offline   Reply With Quote
Old 2nd December 2011, 07:13   #247
luky_13's Avatar
Thanked: 116 Times
Fixing the carb was quite simple, pushed it into the intake manifold and wired throttle and idler cables. Then connected the fuel pipe and choke cable. We used good quality silicone tubing (locally available) for fuel delivery.
Old 2nd December 2011, 08:37   #248
ramki067's Avatar
Thanked: 25 Times
luky_13,
If HD comes to know about this project by you, they might hire you with a fat compensation!!! Great job there...Kudos to your hard work sir.
Rgrds.
ramki067 is offline   Reply With Quote
Old 4th December 2011, 20:39   #249
Thanked: 448 Times
Wow such neat work.that truly is a job well done.
I guess you are going to beat HD at there own game of build quality.
If you go ahead for the process of registering your bike,plz let me know about it.thanks in advance.
If few more people crop up like you,who would wana build there own ride,India is going to be 'The new USA' as far as bike building goes.
dustom_99 is offline   Reply With Quote
Old 6th December 2011, 11:43   #250
luky_13's Avatar
Thanked: 116 Times
I had thought that fixing the primary drive would be breeze. We started with the primary chain case, installation was pretty simple and neat. Next on, the compensator sprocket and the clutch hub (basket) required a chain locking tool... so we quickly handcrafted one., very rudimentary but does the job.
More pics, compensator installed and torqued
Dreamweaver build-off: HD Fatboy-complock.jpg
Clutch hub, installed.
Dreamweaver build-off: HD Fatboy-clutchlock.jpg
Adjuster nut, tension adjusted and torqued
Dreamweaver build-off: HD Fatboy-adjusternut.jpg
An alignment issue cropped up, taper of > 10mm between the clutch and compensator
Name:  Alignment issue.jpg
Anyway we used a hardened-ground spacer to rectify it and then finally
Dreamweaver build-off: HD Fatboy-finally.jpg
Old 6th December 2011, 11:46   #251
download2live's Avatar
Thanked: 387 Times
Oh My God.
This is awesome.
Seeing activity on this thread after a long time.
Wish to see this on roads. Fast.
You must have spent quite a bit on this I guess.
download2live is offline   Reply With Quote
Old 6th December 2011, 11:57   #252
Thanked: 197 Times
Originally Posted by luky_13 View Post
I have stopped accounting the expenses . Will never think about RTO registration etc, for me the very thought of having a harley parked in my driveway build by me from scratch is overwhelming. I don't mind if its not road worthy or registered.
@luky_13 : Mindboggling is what comes to mind when I read through. Great work in progress I must say !!
Have you another thought about RTO registration yet ?
Ravindra M is offline   Reply With Quote
Old 11th December 2011, 21:36   #253
luky_13's Avatar
Thanked: 116 Times
Default Exhaust setup
Even though we did mock-up the exhaust before sending the frame for powder coating, the exhaust brackets and final install was a bit of a mystery. The unbalanced engine added to some level of Fear-Factor as the exhaust setup I had was meant for the balanced version of TwinCam (lesser vibrations). Uncertainty ruled, didn't know what to expect out of 'this' marriage. But before that we had to get the exhaust mounting bracket dialed in parallel to the floor to finalize the mounting points.
Is it parallel, yes it is...
Drill a hole, 8mm in this case
Tap, M8
Install the allen screws to check again
Verified and installed SS allen screws with a little help from our friend from Loctite
luky_13 is offline   (1) Thanks Reply With Quote
Old 11th December 2011, 21:45   #254
luky_13's Avatar
Thanked: 116 Times
Laid out the complete setup on a work table for easier assembly. Started with the two small brackets that hold the mufflers together
Installed the interconnect gasket and seal
Installed the 2 clamps and 1 mounting bracket
Finally goes where it belongs
luky_13 is offline   (2) Thanks Reply With Quote
Old 12th December 2011, 08:20   #255
luky_13's Avatar
Thanked: 116 Times
Default Kick stand - Ideas
Always thought that the kick stand was no big deal and that we should be able to retrofit a similar sub-assy from an Avenger. As we were approaching completion of the bike the kick stand was becoming a necessity, couldn't get her off the stand without it. So we got one from Bajaj and tried to retrofit, quickly realized that neither it could take the weight of this 700 lb behemoth nor was the banking angle optimal. I had always wanted to use some parts on the bike which held a lot of sentimental value for me, one of them was my old golf putter. I used it for many years when I was young and incidentally my father dropped it over at my place last time he visited.
With the putter in front of me I was getting a lot of ideas for the kick stand. Soon enough I decided that the putter head would form the bottom end of the stand and work started in a jiffy, dismembered the shaft from the head.
Harley Davidson - Fatboy or Crossbones trammway Superbikes & Imports 23 26th October 2016 20:49
The Frankenbike Build: My Honda CBR 600 F3 Build-Off ap10046 Superbikes & Imports 16 16th July 2013 14:26
FatBoy is here! FatBoy Introduce yourself 2 4th May 2012 06:48
Harley Fatboy Sidecar Nat_Bambo Superbikes & Imports 9 15th September 2010 22:28
