Go Back   Team-BHP > BHP India > What Car? > SUVs, MUVs & 4x4s
Old 8th June 2007, 23:47   #16
hehe send it to pimp my ride...
zenopio is offline   Reply With Quote
Old 9th June 2007, 11:58   #17
Thanked: 53 Times
Streetlife.. if you really want to do this the cost for engine work would come upto 25 to 30 grand another 5 grand for drive line prices vary on what you want to do if it's complete redone, by replacing most of the parts and by removing the engine out of the bay then it'll cost you lil more, body work depends on what you want and where you do it, it can cost anything from 20grand at your local paint shop to 60 grand at a good place.
that is why buy a cheap Sierra in the first place, cos most of them are done up to be sold so the work is just superficial.
You will have to spend on maintenances more than other vehicles as TATA vehicles usually demand more of it.
But if you do the work properly it'll be fun to own one.
dinar is offline   Reply With Quote
Old 10th June 2007, 20:01   #18
streetlife's Avatar
Thanked: 11 Times
dinar sure the sierra would be a cool ride to own if overhauled properly...
streetlife is offline   Reply With Quote
Old 9th April 2008, 10:59   #19
sirius1845's Avatar
Thanked: 13 Times
Smile
Originally Posted by streetlife View Post
What if someone rebuilts the whole vehicle. For eg. Redone engine and drive line, chasis stiffning, bodywork.. Will is still give problems? And what can be the approx. costs involved..
I am A Sierra Fan BTW
same here. i own a 94 model. redoing the engine costs around 25-30k, (depending on work) minor stuff like changing piston rings wiil be under 10k. cylinder head costs 35k (not always necessary to replace, can be ground in a lathe)dreive line is 8.5- 10k for the transmission shaft, clutch & pressure plate assembly will be 3.5k. gear box usually not required to rework unless in really bad shape. suspension overhaul with replacement of bushes and shocks will come under 15 k. chassis stiffening not required as it is a sturdy vehicle, however if it had a crash maybe worth doing.
sirius1845 is offline   Reply With Quote
Old 9th April 2008, 17:55   #20
rider60's Avatar
Thanked: 47 Times
i say go ahead with sierra if you love it very much and would not mind changing every thing except the chassis, you might even end up doing some major chassis repair if there are any rusted parts and paint it too.
all in all if have like 2.5-3L apart from the vehicle's cost to completely rebuild it then go ahead. other wise just forget it.
rider60 is offline   Reply With Quote
My 99 Sierra Turbo 2nd hand my first review sag_kv Test-Drives & Initial Ownership Reports 47 16th May 2014 22:54
Left Hand Drive Tata Sierra..(sorry no pics) SRK Modifications & Accessories 19 31st January 2009 01:17
Buy an assembled jeep or a 2nd hand one? Ab3d 4x4 Vehicles 6 31st August 2008 06:51
2nd hand Tata Sierra? Advice needed. govigov SUVs, MUVs & 4x4s 21 14th January 2008 17:59
