| SUVs, MUVs & 4x4s Jeep, Safari, Scorpio, Innova etc. |
| | Thread Tools |
| | #32 (permalink) | |
| BHPian Join Date: Aug 2008 Location: Mangalore
| Quote:
Say on a steep ghat section while coming down the slope? or while overtaking a vehicle just to find out that there is a bus coming from the opposite direction and your too close to ramming it you want to hit the brakes but nothing works. At this point the mind does not know what to do. Engine braking might slow you down but it wont help stop the vehicle completely.
__________________ I am happy that I dont own a "SKODA".. and you should be too... if you aint owning one. | |
| | #33 (permalink) | |
| Senior - BHPian | Been there and done that. In 1979 while returning from Allahabad to varanasi the accelerator cable of the Amby snapped. Drove 120 Kms with the snapped wire held in hand and operating the throttle. Took 5 hrs to do a journey of about 3 hrs.. ![]() Quote:
__________________ Royal Enfield Bullet 1962 All Black 1998 Safari 4x4 All Black 2004 Scorpio GLx | |
| | #34 (permalink) | |
| Senior - BHPian | Pray to God and jump out of the vehicle.. Quote:
| | #37 (permalink) | |
| BHPian | Quote:
Regarding brake failures - brakes don't snap just like that. They normally give enough advance indication. Careful drivers never ignore those indications and don't get into those situations in the first place. It's never like a fuse, where it is perfectly fine now and gone the next moment. Brakes take time to go 100 per cent soft.
__________________ You gotta know when to hold em, know when to fold em, Know when to walk away and know when to run. | |
| | #39 (permalink) |
| BHPian Join Date: Aug 2008 Location: Hyderabad
| GD, If u are still looking for a Jeep, there is a thread running around right now with regards to an Army Auction happening pretty soon. But how are you going to buy a single Jeep? From what I know of Army auctions, there are Syndicates that exist who buy these Jeeps in lots, sometimes even buying a 100 vehicles , and bid for it. What you can do is to buy a single vehicle from the syndicate. Also the Jeeps that are rid of at these disposals, are generally pretty cannibalised, as the EME corps of the army responsible for the maintenance and upkeep of all vehicles of the Army, strip the vehicles of all working parts, and replace them with worthless parts before sending them away to the Disposal units. There is a place in Delhi called Mayapuri, where you can go select Jeep chassis, engine of your choice (Gypsy, Toyota etc) and get the Jeep built to your satisfaction. Only drawback is that they give you a temp registration number and you will have to get the registration in some other state thru jugaad ![]()
__________________ Life in the 100kph lane. Wrong way. |
| | #40 (permalink) |
| BHPian Join Date: Nov 2007 Location: Chandigarh
| Hi, The jonga has a 6 cyl 4 lieter powerplant producing 145hp and 32.5kgm torque(with the hitarchi carb) and 135hp and 30 kgm(with solex carb). The diesel version produced 110hp on a hino 4 cyl. If you are talking about relaiblity, the Jonga is more relaible than the Jeep petrol(hurricane motor), but as far as diesel is concerned, the Di Jeep is much more reliable.Leaving that aside, the jonga has a much more tough and relaible drivetrain than what the mahindra stable can ever produce(even the modern ones). Reliablity issues are more to do with maintainence, when you dont retighten things when you are supposed to,, like when both the high low and 4x4 engagement levers fell off my moving Willys. I am currently inbetween my project of a heavily modified jonga,with a thicker axle shaft to run 33 boggers and a cummins 6bt 250hp motor, a four speed low ratio (7.13)gearbox with a pto winch and a lot more stuff. And whenever i went looking for parts, i never ever found new parts(except seals and stuff). The only place you can find parts is mayapuri, where you'll get army hand me downs ,but you need to have an eagles eyes to get something worthwhile coz most good parts that could be reused have been degraded just coz they have been lying around for so long that rust eats them right through the grease layer. If you want a good vehicle, my advise would be to stay off the jonga ,even though it is a much better option, coz you wont find parts. And even though you can change the entire drive-train and put dana axles and stuff, the body parts are still difficult to locate(but that i think goes for the jeep too, i just cannot find stock front mudgaurds anymore, not the classic ones but the originals). The jeep petrol parts too are difficult to locate, but the diesel parts are easily found. Not that the jeep unit is pretty sound too, the DI/inter motor sits too low on the chassis, keeping it in constant danger of damaging the chamber in rocky offroad conditions(happened to me twice). The 3 speed gearbox, though good enough,prohibits you to use a high ratio final drive, and if you assemble it with a turbo Di, you are more likely to have broken parts ever now and then(cannot handle the torque of a turbo dI).The 4 speeder is better, but you should overhaul it with new bearing coz its the only problem it has(besides having thin gears, but that would only trouble you if you have an engine that produces more than 28kgm torque). Axles and brakes should do fine enough if you upgrade to a Brake Booster with dual master cylinder, and classic's disc brakes. If you go with a full-floating rear axle, than you can even shoehorn rear disc brakes to it. And yes, whoever said that you can use engine brakes in a diesel motor is wrong, coz unlike petrol motors, which control the air quantity entering the engine to produce more power and speed, a diesel motor has a constant supply of air flow and it controls power by the amount of fuel injected in it. A petrol motor can retard engine speed down a hill by just lifting your foot from the accelerator pedel, coz it closes the bullerfly/slide valve restricting the amout of air entering the engine, henve creating a sort of vaccum inside the cylinders, therefore slowing the motor, whereas in the diesel motor, the air entering the motor is not controlled(remember its controlled my fuel amout ,not air) ,so going downhill will only speed up the engine. That why heavy duty diesel motors have a exhaust brakes, to slow the vehicle when going downhill. An exhaust brake is nothing but aa butterfly valve, but used in the exhaust manifold. Closeing that valve restricts the amount to air exiting the cylinder and creating backpressure, hence having the same effect as in a petrol motor. ![]() Regards, Bikram |
| | #41 (permalink) |
| BHPian Join Date: Feb 2006 Location: Hyderabad
| Wow brutus that was extremely informative. It would definitely help someone looking for a jonga. I would love to see the pics of your jonga.
__________________ I never thought it was humanly possible, but this both sucks and blows. - Bart Simpson |
| | #43 (permalink) |
| BHPian Join Date: Dec 2008 Location: the world's my playground
| And yes, whoever said that you can use engine brakes in a diesel motor is wrong, coz unlike petrol motors, which control the air quantity entering the engine to produce more power and speed, a diesel motor has a constant supply of air flow and it controls power by the amount of fuel injected in it. A petrol motor can retard engine speed down a hill by just lifting your foot from the accelerator pedel, coz it closes the bullerfly/slide valve restricting the amout of air entering the engine, henve creating a sort of vaccum inside the cylinders, therefore slowing the motor, whereas in the diesel motor, the air entering the motor is not controlled(remember its controlled my fuel amout ,not air) ,so going downhill will only speed up the engine. That why heavy duty diesel motors have a exhaust brakes, to slow the vehicle when going downhill. An exhaust brake is nothing but aa butterfly valve, but used in the exhaust manifold. Closeing that valve restricts the amount to air exiting the cylinder and creating backpressure, hence having the same effect as in a petrol motor. ![]() Regards, Bikram[/quote] not really true... yes, a diesel motor does have a constant air-flow. What it also has though, is a 'governor'. A governor is a spring-loaded device that's fixed to the diesel-pump, and reduces the amount of fuel being pumped. That is what provides the engine braking in a diesel. Try it out for yourself on a slope, or just take your foot of the throttle on a straight stretch. If you have experience with diesel engined jeeps then i'm sure you know how good the engine-braking is.. |
| Thread Tools | |
Similar Threads | ||||
| Mahindra Major 4x4 jeep- A/C & Power Steering, Diff. locks, Snorkel | amit kumar | Accessory/Part Reviews | 3 | 10th November 2009 21:09 |
| Amma... look what I found... a 4x4 JEEP !!! | Sabareesh | 4x4 Vehicles | 190 | 9th September 2009 11:24 |
| Ford World War II Jeep 4X4 in Bangy!! | reachmash | Pre-1950 | 14 | 6th November 2008 14:00 |
| ford gpw jeep 4x4 .... in the wall | sat | Shifting gears | 28 | 16th September 2008 00:57 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
*!GULP!* oh man! Thats the worse thing that can happen to anybody.
