Go Back   Team-BHP > Indian Cars > What Car? > SUVs, MUVs & 4x4s
SUVs, MUVs & 4x4s Jeep, Safari, Scorpio, Innova etc.
Thread Tools
Old 31st October 2008, 13:50   #46 (permalink)
Originally Posted by yamaniac View Post
To resist heat Probably we could cover the ingine bay area with foam from letting the heat of the engine entering the cabin? Any Ideas?
High-quality insulation will do the trick. I got a double-layer in the cabin area of my Jeep. Even the floor stays cool from drivetrain heat.
@ TerrainSnooper : Congrats on the buy! I see you are getting an orientation to Jeep ownership with the little niggling problems. Already.
__________________
Work backward from your imagination, not forward from the past!
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 31st October 2008, 18:24   #47 (permalink)
@terrainsnooper- your jeep sounds lovely. kerala to pune in a 2nd hand jeep costing less than 1 lakh? that too on its first drive?
You're not taking it easy on the old lady. good!
__________________
Enjoy your dictatorship! I'm outta here
Old 3rd November 2008, 03:45   #48 (permalink)
akeel's Avatar
@terrainsnooper,
congrats buddy
akeel is offline   Reply With Quote
Old 3rd November 2008, 12:59   #49 (permalink)
whitemm550's Avatar
I am not sure how to recognize the difference between both engines since they are very similar. Maybe some of the experts in the forum can help.
The RC book generally gives the cc of the engine but I am not sure how much you can trust the RC book unless it is the original one and the jeep hasn't been registered in different states etc.
Mahindra did offer 2.5 ltr XDP in 96, but the difference will be in the placement of the air filter, and 2.5 ltr will ideally have servo assisted brakes.
__________________
' A WILL FINDS A WAY '
whitemm550 is offline   Reply With Quote
Old 3rd November 2008, 17:45   #50 (permalink)
Thanks for the info, Whitemm540... however, I was not that lucky...this happens to be a MM540-DP,as per the plate inside the engine bay. Which means that the engine is a 2112cc Puegeot(anyone knows the power output for this engine?)
The engine is in good shape, my uneventful drive back from Manglore to Pune almost non-stop is testimony to this.
My concern is that now when i dip my finger in the radiator, it comes out black... so there is oil in the radiator. I have drained out the water by making it overflow from the top of the radiator so that the floating oil drains out, but after running the engine for a while, the oil traces return. The engine oil in the dip-stick looks good, cannot see any white traces of water in it. The engine does not overheat in peak traffic, neither does the oil pressure go below 4. The exhaust smoke too is a healthy colour. The next step is to drain the engine oil(which has turned completly black by the way and i hope thats normal for diesel engines) and see if there's water in it.
I hope and pray that its only as bad as a leaking head gasket and not a busted water sleeve within the cylinder. Dont have time this week, but will keep you folks updated on my findings.
'Later!
Terrainsnooper is offline   Reply With Quote
Old 4th November 2008, 00:02   #51 (permalink)
4x4addict's Avatar
Infractions: 0/1 (7)
Terrainsnooper:
The Peugot 2.1 liter engine typically needs a top end job at about 80K kms. I have posted elsewhere the symptoms to look for when you know when you need the top end overhauled.
4x4addict is offline   Reply With Quote
Old 4th December 2008, 11:18   #52 (permalink)
svsantosh's Avatar
Akeel,
(this is the right place to post my experience)
Thanks a lot for letting me have a test drive of your MM540. It was fun and truly a eye-opener. After driving a Alto(5yrs) and now a Indigo CS, A JEEP was a whole new world to me. Agreed the controls were hard like a coconut - but a man's toy for sure.
PS - After you dropped me off and drove away in your jeep, my Indigo CS felt so Nimble!!! I was under the impression my foot controls have dropped/sagged by a good 1 FEET!!!
thanks a lot friend
Regds
San
__________________
GOT MY CJ340 SWB JEEP & HOW???
svsantosh is offline   Reply With Quote
Old 15th December 2008, 16:55   #53 (permalink)
akeel's Avatar
Akeel,
thanks a lot friend
Regds
San
Hey santosh,
Sure any time not a problem, its very had to let this jeep of but what to do the other one (MM550) is much better than this one so letting it go :(
Old 16th December 2008, 11:27   #54 (permalink)
yamaniac's Avatar
Originally Posted by Terrainsnooper View Post
Hi Guys,
The only issue is with the 2nd gear, it slips back to Neutral on its own, so you need to hold the gear in position till you shift to 3rd.
Congratulations mate!! Welcome to the club!! I have this same issue with my jeep too. I asked my mechanic about this and he said that Some parts have to be changed inside the gear box. This probably happens due to wear n tear. Otherwise she is fine. Hope to look at the pics soon.
__________________
I am happy that I dont own a "SKODA".. and you should be too... if you aint owning one.
yamaniac is offline   Reply With Quote
Thread Tools
MM540-4WD wish list - what you really want in your MM540-4WD? DHABHAR.BEHRAM 4x4 Vehicles 293 12th November 2009 14:17
Relocating to Hyderabad - Need inputs. snaronikar Shifting gears 10 18th August 2009 15:13
Fiat Adventure - need some inputs lohithrao Technical Stuff 7 1st December 2008 12:34
Buying Safari - Need inputs suncity SUVs, MUVs & 4x4s 69 25th February 2008 20:34
any inputs on afghanistan? panky12345 Shifting gears 7 23rd April 2006 23:22
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
