Go Back   Team-BHP > BHP India > What Car? > SUVs, MUVs & 4x4s
Old 12th August 2009, 16:17   #16
shankar.balan's Avatar
Thanked: 5,336 Times
good you chose the MPFI
much better than carb
Old 9th May 2014, 10:16   #17
Thanked: 94 Times
Default Need help with Gypsy's engine
Hi all,
I need help from all the tech gurus on the forum. I have a Gypsy King which is an mpfi one. It was once driven without engine oil and the crank got bent and it was continously making typical crank noise. So its lying idle for more than 10 months now.
I also have a carb Esteem which is having lot of issues but the engine is intact and is in very good shape.
My question to you all is, Is it possible that I can swap the block of my Esteem with that of Gypsy ? I know the head is different in both the cars. Is there any other difference also like is there any difference in foundations as well ?
nik0502 is offline   Reply With Quote
Old 9th May 2014, 10:43   #18
sudev's Avatar
Thanked: 2,462 Times
Default Re: Need help with Gypsy's engine
Should be possible. Half engine overhaul is just about what you are proposing. Caution do check if carb esteem and mpfi esteem had any change in the block. Not to my knowledge but just do check.
sudev is offline   (1) Thanks Reply With Quote
Old 30th July 2015, 08:14   #19
johy's Avatar
Thanked: 370 Times
Default Re: Gypsy King - Carb or MPFi?
Resurrecting this old thread. Someone is selling an old 91 Carb Gypsy. What should I be looking for in these old carb vehicles? What problems should I be looking for? From the posts, seems like it is better to pick a MPFI vs a carb...guys your inputs please.
johy is offline   Reply With Quote
Old 30th July 2015, 14:35   #20
paras211's Avatar
Thanked: 56 Times
You won't have a place for the crank sensor if there is one
paras211 is offline   Reply With Quote
Gypsy Carb or King MPFI for the RAID married2speed 4x4 Vehicles 26 28th June 2012 14:06
New 99-Gypsy King carb lands in Chennai Prasoon 4x4 Vehicles 15 11th December 2010 20:48
Should I buy ? '99 gypsy king 1.3 carb paras211 4x4 Vehicles 11 21st April 2010 00:01
Gypsy King HT MPFI - 2001 khan_sultan SUVs, MUVs & 4x4s 20 26th August 2009 20:02
