Thread Tools
Old 20th January 2006, 13:59   #1 (permalink)
Default Suspension overhaul for Zen
Hi everybody,
I have a stock 2001 MPFi Zen (63k). Offlate it's suspension started making noise
and feels very weak compared to other zens and nowhere near a new Alto. So
I had been planning to overhaul it's suspension. Today I took it to a Bosch servicing
center (Fansa Motors) and asked for their opinion and estimate of expenses.
They simply sent a guy to take a test ride of my car. He took the car around a block where road
was not in good condition. He reported that almost entire front suspension
and major parts of rear suspension need to be changed. Then some elder person
showed me diagrams of those parts from Zen Workshop manual.
I asked him, if we could use any 'better than stock' spares
to improve the feel beyond a new Zen. He said that can't be done normally and
he will use 'AC Delco' shocks for front which are better than MGP.
When asked him about the estimate of expenses, he said it could be approximately 10k.
Upon asking for split
Front suspesion setup 'each' side = Rs 2400/-
That would be Rs 5000/-
Rear suspesion setup in total another Rs 2000/-
Labour charges Rs 1500/-
Wheel alignment and balancing - Rs 350/-
Washing and cleaning - Rs 250/-
More as they see any othre parts need to be replaced.
And it would take them 1- 1.5 days for them to finish the job.
Thinking of checking at other places before giving it there, I left from there.
What do you guys think? Are the charges Ok?
Shall I get this job done at my regular garage instead?
Could I do any more to improve it's suspension to be as good as that of a new Alto?
Your comments would be very helpful.
Thanks in advance
skidrock is offline   Reply With Quote
Old 20th January 2006, 14:18   #2 (permalink)
speedsatya's Avatar
wat about teh tie rods ,the lower arms ...also change the stabiliser bar bushes in teh front ...they must have also worn out ...when they are worn you hear the tire rubbing against the body ..
and what about teh rear suspension ????what are you changing ?????
speedsatya is offline   Reply With Quote
Old 21st January 2006, 23:50   #3 (permalink)
If you have the tools and time, do it yourself, as changing suspensions shouldn't be hard just need a bit of patient from my experience. However the tracking leave that to the garage as that needed their special equipment. That way you may save some expenses.
gary_yuen42 is offline   Reply With Quote
Old 22nd January 2006, 00:44   #4 (permalink)
nitrous's Avatar
Dude, u cant just drive around and say what all has gone stale in the suspension.They have to remove the whole setup,then check and replace if necessary has to be done.
__________________
youtube.com/watch?v=FiVicNOA3bY
nitrous is online now   Reply With Quote
Old 22nd January 2006, 07:46   #5 (permalink)
angelfire's Avatar
hey... ask the garage people to first hoist the car on the lift and then check for any damage.....a suspension consists 0f a lot of things actly.....specially the front ones...nd they dont fail unless constantnly used on rough terrains...usually its the bushes that wear out....just get it checked properly...nd replace only if needed....
angelfire is offline   Reply With Quote
Old 23rd January 2006, 09:14   #6 (permalink)
killjoy's Avatar
for zen, if you dont mind a slightly harder ride at low speeds, then ideally, you can stiffen the front stock struts and use zen diesel springs and for the rear, use stiffened gypsy struts with the same springs. really good if you want to do autocross and stuff.
__________________
Profession: IT
Career: Motorsports
killjoy is online now   Reply With Quote
Old 23rd January 2006, 10:34   #7 (permalink)
Thanks for all the replies guys. Busy right now, will get suspension thoroughly checked by my mech.
I don't really want a stiff setup, but my zen's suspension feels too weak/loose.
I just want to bring to the level of new Zen, still better, to that of an Alto, if possible
Old 23rd January 2006, 11:14   #8 (permalink)
nitrous's Avatar
When u rehaul the suspension, she'll be a little tight and will loosen up after a few hundred kms.Its normal. I've done umpteen suspension rehauls on my cars that i've lost count.
__________________
Old 29th August 2006, 16:41   #9 (permalink)
ive done a lot of suspension work on my zen too. punes tough on any car, though i must say the zen starts rattles and squeaks in six months no matter how much hard earned moola or TLC you can sink into it.
vark2551 is offline   Reply With Quote
Old 6th September 2006, 03:25   #10 (permalink)
hellspawn's Avatar
my zen started rattling and squeaking just one week after i got the suspension work done.
@skidrock:also get your steering column checked.if the steering has developed a play in it,it needs to be changed too.it would cost approx. 3000 bucks.
__________________
The trouble with life is there's no background music
hellspawn is offline   Reply With Quote
Thread Tools
Maruti 800 Suspension Overhaul COST!!! jramprakash Technical Stuff 5 15th August 2008 15:54
Suspension Overhaul - Ohc 1.5 narayan Technical Stuff 27 5th May 2008 15:25
zen di engine head overhaul zenopio Technical Stuff 5 22nd February 2008 13:56
Suspension upgrades for Zen. speedsatya Modifications & Accessories 0 30th May 2005 23:05
carb zen suspension options? heavy_foot Technical Stuff 14 15th May 2005 11:59
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
