Old 28th April 2011, 14:44   #1
Thanked: 15 Times
Default Corolla Lower arm replacement needed?
Hey guys,
I have a June 2006 H2 Corolla. It has done approximately 53k kms and has been used mostly on Highways or Gurgaon roads.
Recently while driving the front suspension would make a 'clunk' sound whenever I used to drive on bad road, i.e. roads with small pot holes or rocks jutting out. This only happened at a good clip but never at a slow pace.
Following has happened after I noticed these problems
Toyota A.S.S
I took it to Toyota and they said that both front lower arms need to be replaced. The reason was that the rubber joint at the very end had been cut. Attached is a pic of the same in which the joint of the arm is shown together with the 'cut' rubber. They quoted 18k for parts plus labor. I wanted a second opinion since this was a part which I had read is 'over engineered' and hence something unlikely to fail on a sedately driven car.
Trusted garage
I then took it to a trusted Gurgaon shop(Rakesh Automobiles). I just finished talking to him and he has stated that he does not think that the arm needed replacement.
Can you guys help me figure out if this is indeed a problem, and if so is replacing the entire lower arm on both sides is the only solution.
HR
hell_raiser is offline   Reply With Quote
Old 28th April 2011, 16:22   #2
AWD
Thanked: 218 Times
Default Re: Corolla Lower arm replacement needed?
Get it rechecked again, old model Corollas were known to make noise while going over pot holes, broken roads, speed-breakers. I've heard that noise coming out from new Corollas.
Rubber parts, etc. could be changed but parts like lower arm are expensive, so think before changing.
AWD is offline   Reply With Quote
Old 28th April 2011, 19:56   #3
Thanked: 15 Times
Thanks AWD.
Rakesh Automobiles changed the bush in both front and rear and it seems to be working great. Another good thing I came to know is that rubber part can be replaced if needed, no need to change the entire lower arm.
Also they located a screw in the rear suspension which was creating squeaking incessantly on smooth roads. The A.S.S SA had advised to replace entire rear brake components.
I really need to thank Guru Dutt Ji for spreading word about this workshop. Even the young guys are very knowledgeable.
All that remains in the car is the odd alignment. Let me take a couple of pics and get back.
Cheers,
HR
Old 28th April 2011, 22:39   #4
deep_bang's Avatar
Thanked: 343 Times
I had a similar problem with my Indica (50k done). I replaced the ball joints and all is well now.
When you say you replaced the bush, is this the same as the ball joint? I dont know much about suspensions !!
deep_bang is offline   Reply With Quote
Old 29th April 2011, 11:30   #5
Thanked: 15 Times
I dont think so. The ball joint is basically a metal semi sphere with a perpendicular rod(with a ball head) going through it.
From my understanding bush are the rubber joints which help prevent vibrations in connections between various suspension parts.
He replaced another part along with the bush called the Tie Rods for both front wheels. This has definitely reduced the amount of noise to an acceptable level.
Total Cost Rs 1100. Awesome.
Corolla Altis : Brake Pads need replacement frequently geetaj Technical Stuff 29 1st July 2015 09:54
Lower arm broke, wheel came off! jokuji Technical Stuff 47 7th May 2014 00:54
Corolla A/c Evaporator Replacement - Steps and Pics! vigsom Technical Stuff 7 18th May 2012 20:44
Need 2004 Corolla AT replacement - Now what? rhandle Sedans 19 17th December 2009 16:49
