Old 4th May 2011, 23:07   #16
SS-Traveller's Avatar
Thanked: 11,626 Times
Default Re: Urgent help please - Accidently put water in Brake Fluid - Punto Diesel
Originally Posted by jyobeb View Post
I don't think so! I think the usage is perfectly acceptable!
In the medical realm, yes - where to bleed = loss of a liquid from a closed loop, i.e. one's circulatory system. One can bleed to death, but bleeding a hydraulic brake system cannot kill it!
Old 4th May 2011, 23:44   #17
IQBAL VEERJI's Avatar
Thanked: 291 Times
Originally Posted by anujmishra View Post
First time I heard such situation. Anyway, you immediately need to visit to nearest Fiat after sales service and get the brake system bled. It will not take much time.
No dear not only bled but total system flushing out and leaving car without brake oil for few hrs before new fluid is used and bled.
Its not that serious , and can be done in a day,s job.
You may get it done at any garage, but stop using the car, and dont press brake pedal at all till the job is done.Tow the vehicle to the garage and use hand brake during towing .
IQBAL VEERJI is offline   Reply With Quote
Old 6th May 2011, 10:12   #18
Thanked: 655 Times
Sorry but you are way off the mark. I normally would not take something like this any further but your () icon seems quite un-necessary!
bleed - definition of bleed by the Free Online Dictionary, Thesaurus and Encyclopedia.
Bleed Off Line - Oil Gas Glossary
Definition of bleed verb from Cambridge Dictionary Online: Free English Dictionary and Thesaurus
bleed - definition. American English definition of bleed by Macmillan Dictionary
definition of bleed from Oxford Dictionaries Online
jyobeb is offline   Reply With Quote
Old 7th May 2011, 21:14   #19
Thanked: 2,394 Times
Infractions: 0/1 (4)
Coming late to this thread, but commenting because I would have done things differently.
A) Would have siphoned out the contaminated fluid as much as possible from the reservoir, rather than flush it out through the bleeding nipples.
B) Then bled out the rest of the remaining MC fluid from a point as close to the MC as possible.
Idea is to prevent the contaminated fluid coming in contact with elastomer parts, which means seals and hoses, as much as possible.
Lastly, at the service station, would have flushed the system with methylated spirit. (Though this needs to be checked for compatibility with modern fluids and elastomers.)
Sutripta
Sutripta is offline   (1) Thanks Reply With Quote
Old 26th August 2011, 09:21   #20
punto_'s Avatar
Thanked: 24 Times
Default Re: Accidently put water in Brake Fluid - Punto Diesel
Sorry guys, Its a very late reply. Post this I drove very carefully as directed by Fiat and they replaced the Oil. I believe it costed about 500rs. Thank you very much for the inputs! :-)
punto_ is offline   Reply With Quote
Old 26th August 2011, 10:00   #21
james's Avatar
Thanked: 544 Times
Good to hear you got home safley! Im curious to know why you put water into the
[SIZE=3][FONT=Calibri]reservoir in the first place. [/FONT][/SIZE]
james is offline   Reply With Quote
Old 26th August 2011, 10:33   #22
punto_'s Avatar
Thanked: 24 Times
LOL, I was @ Mysore on tour.. and in a rush to fill water for wiper, I put it in the break fluid. Actually the hotel watchman did it! And I immediately stopped him. Luckily, the Fiat showroom was just 2 kms away from the hotel!
Anyone using DOT 5.1 brake fluid?? Shan2nu Technical Stuff 28 11th April 2018 17:21
Brake fluid/Parking Brake Indicator light- Is this a problem? santosh.s Technical Stuff 10 7th June 2017 14:02
Brake Fluid Replacement - IMPORTANT vigsom Technical Stuff 50 1st June 2015 13:13
Accidently drove my car with handbrake on! NK@Hyd Technical Stuff 76 29th March 2015 20:54
Brake fluid leakage- help required! santosh.s Technical Stuff 53 11th March 2009 23:16
