Old 9th June 2013, 22:02   #16
Thanked: 660 Times
Default Re: 2007 Indica Xeta: Engine losing power all of a sudden and regaining power after m
here are the check list, not necessarily in that order.
1. petrol filter
2. air filter and its sensor
3. spark plugs and related electric system, ht coil etc. (Most likely this)
Old 10th June 2013, 10:40   #17
Thanked: 434 Times
Originally Posted by mohandas View Post
When the problem occurs, it feels like an anemic engine which is not getting the fuel to burn. In all cases, this problem stays for 15-30 sec and then automatically recovers and regains all the lost power.
A friend of mine had the same problem, and it turned out that the accelerator cable 'casing' was not fixed properly to the car. When the accelerator was being pressed, the cable cover was also moving sideways, creating this problem.
This may not be your case, but still a reminder to keep in mind how small issues are blown up.
jinojohnt is offline   (1) Thanks Reply With Quote
Old 3rd May 2016, 07:37   #18
arun_josie's Avatar
Thanked: 4,949 Times
My friend is facing the same issue as mentioned in the OP, his is a 2006 Indica Xeta with the ODO @ little less than 30K Kms.
Any suggestion to fix this issue? He has already tried the suggestions mentioned in this thread.
arun_josie is offline   Reply With Quote
Tata Indica e-xeta petrol with 17.1 kmpl and e-xeta LPG sidindica The Indian Car Scene 7 9th July 2011 12:39
Engine losing power in Vista MJD akhilesh51 Technical Stuff 41 28th December 2009 12:07
Wobbling and Losing Pickup after a accident-indica vista hdi_pro Technical Stuff 12 6th November 2009 18:12
Indica Xeta - First Experience-How Xeta won the race nirmalkumar Test-Drives & Initial Ownership Reports 12 20th April 2008 16:41
