Old 9th May 2011, 18:54   #1
anachronix's Avatar
Thanked: 1,290 Times
Default Exhaust Drone
Folks,
I recently upgraded the end can in my 2 year old Fiesta 1.6S. It was the Evotion EV801 muffler.
Everything was good until I was plagued with this exhaust drone noise. I have searched and tried to read much on google however I couldnt find a straight forward solution to control drone. The drone comes into the cabin between 2500 to 4000RPM which is actually the sweet spot of the exhaust. Sounds good outside, its getting me bad headache if I am inside. Need help to find a solution!
What causes exhaust drone?
- Positioning of the end can?
- Piping issue?
- Any leaks, I hear a mild metal clapping noise when I park the car in my garage which is a closed space and good enough to amplify any noise.
Looking forward to all the help!
anachronix is offline   Reply With Quote
Old 9th May 2011, 19:28   #2
Sankar's Avatar
Thanked: 4,637 Times
Default Re: Exhaust Drone
Is Evo a straight through bassy exhaust? Bassy exhausts are often drone prone. Exhaust positioning will have an effect on how the drone filters into the cabin as well, it may be pronounced in some cars and not very much in others. Maybe you can try some extra damping on the cabin floor above where the muffler sits and it might cut the drone a bit.
Old 9th May 2011, 19:51   #3
anachronix's Avatar
Evotion is bassy, yes!
I did apply some damping inside the wheel right above where the exhaust is positioned with some Noisekill. However, I dint feel any improvement.
BTW, the exhaust was installed in 2 other Fiestas on the same day. Its only my car thats plagued with the drone. The only difference I could note from the other installs to mine is the exhaust tip sticking out more and also the piping from the Resonator is not running parallel to the chassis.
Old 9th May 2011, 20:18   #4
Sankar's Avatar
If possible position it so that the muffler exit opens clear of the body/bumper, that might help a bit.
Sankar is offline   (1) Thanks Reply With Quote
Using a Drone to shoot a Car Commercial at the High Alpine Road, Austria achutank Street Experiences 17 27th June 2016 23:57
The Auto-Follow Drone Photography Thread phamilyman Gadgets, Computers & Software 5 3rd November 2015 06:50
free flow exhaust sanket12 Modifications & Accessories 4 29th June 2004 20:09
K&N Filter and Free flow exhaust gbharani Modifications & Accessories 2 19th April 2004 23:46
