Old 5th April 2012, 17:40   #16
1self's Avatar
Thanked: 270 Times
Default Re: Smell of Petrol from the engine: Octavia VRS
Originally Posted by anandpadhye View Post
Really?
Do these cars have the charcoal canister? How many years/kilometers before it is damaged if regularly filled to the brim???
Was it only smell and no drop in FE?
ALL fuel injected car are supposed to be carrying the charcoal canister to avoid venting petrol fumes to atmosphere, as required by regulation. This also helps in FE as the fumes trapped by the charcoal canister is purged & fed back to the engine under acceleration.
1self is offline   (1) Thanks Reply With Quote
Old 5th April 2012, 17:54   #17
Thanked: 1,172 Times
Great.
Thanks.
So the charcoal canister seems to be able to sustain overfilling abuse for 5 years/75000KM at least - going by my experience?
And if overfilling were skipped on some occasions in between, would that help revive the canister?
Also, how about diesels? I have been overfilling my Tucson as well, for last 3 years!!! Tucson takes 15 liters of diesel after auto cut-off - consistently, every time.
anandpadhye is offline   Reply With Quote
Old 5th April 2012, 18:12   #18
1self's Avatar
Thanked: 270 Times
Great.
Thanks.
In the older vehicles, the charcoal canister could withstand a lot of abuse. The the newer vehicles, in line with stricter regulations, you will immediately get a 'Check Engine' light!
Diesels do not have any kind of charcoal canister as diesel - as a fuel - does not evaporate freely at ambient temperatures.
Petrol smell in the car abhibh Technical Stuff 73 25th May 2017 15:10
Heavily modified Skoda Octavia vRS - Fuel for Petrol Heads PowerFool Modifications & Accessories 18 3rd August 2012 12:17
No response from engine after 4K RPM..Octavia vRS ashish22 Technical Stuff 35 14th April 2009 10:24
Petrol smell when starting Ikon Flair shalini_g Technical Stuff 0 18th August 2008 13:39
NEW Swift Petrol Burning Smell cyneverdie Technical Stuff 3 11th February 2008 20:30
