Old 12th May 2011, 20:22   #1
Question Smell of Petrol from the engine: Octavia VRS
Hi Guys,
I have been getting a very strong smell of petrol from the engine of my Octavia VRS. Here's a background on the problem.
After driving 30-40 KMS during the day, when I stop my car and step out. I get a very strong smell of petrol from the engine. Also, after this smell starts to come, the car stops every 2-3 minutes no matter what speed I am driving at.
I took the car to Skoda, they identified the Fuel Pump was the reason for the frequent stopping. Got it changed. However, the smell of fuel still persists.
I would appreciate if someone could help me with the reason this might be happening... its driving me nuts....
Maybe someone who has experienced a similar thing.
Thanks in advance
Kunal
VRS_Junky is offline   Reply With Quote
Old 12th May 2011, 21:04   #2
Thanked: 11,037 Times
Default Re: Smell of Petrol from the engine: Octavia VRS
Sounds like your engine is running rich and also you are getting a fuel lock.
It could be something as simple as your air filter is blocked. Start there. Your MAF sensor might be misreading. Disconnect and see any difference on default settings.
Did the dealer do a scan and come up with a fault code?
ajmat is offline   (2) Thanks Reply With Quote
Old 13th May 2011, 00:05   #3
Viraat13's Avatar
Thanked: 130 Times
Used to happen in my Corsa too. There used to be a build up of gas in the fuel tank and then the smell of fuel would seep into the cabin and the car would shudder a little. It still happens when I get stuck in bumper to bumper traffic. I just stop and open the fuel filler and let the air out and then it goes back to normal.
Viraat13 is offline   Reply With Quote
Old 13th May 2011, 03:04   #4
dhanushs's Avatar
Thanked: 4,504 Times
Originally Posted by VRS_Junky View Post
.... I have been getting a very strong smell of petrol from the engine of my Octavia VRS.....
.... the car stops every 2-3 minutes no matter what speed I am driving at....
Looks like you are running a rich A/F ratio. Like Ajmat mentiond, check if intake is clogged. Also, regarding the error codes, try resetting the ECM - Disconnect the battery and re-connect it after about 15-20 minutes. AFAIK, it should clear any error codes, and the ECM can start fresh.
Originally Posted by Viraat13 View Post
... build up of gas in the fuel tank...
... I just stop and open the fuel filler and let the air out...
Hey Viraat, this shouldn't be happening. There is a passage to let air out, and yours seem to be clogged. Please get it checked.
Old 13th May 2011, 07:02   #5
Smile Re: Smell of Petrol from the engine: Octavia VRS
Thanks Dude.. I did get a scan done. The Mass Air Flow sensor was malfunctioning. I got it reset and rescanned after running the car for a few KMS. There was no error code this time. Do you think it could be something to do with the mass air flow sensor. I am taking the car to Performance Auto today considering the fact that even Skoda technicians would not be well versed with RS. Will keep you posted on what Performance Auto has to say.
Thanks for your help.
Old 13th May 2011, 08:11   #6
moralfibre's Avatar
Thanked: 6,532 Times
The last time I smelt fuel in my car, it was a clogged fuel filter that cracked and leaked fuel. Never realized until I went under the car. Check that as well in addition to above.
Old 16th May 2011, 16:08   #7
Exclamation Re: Smell of Petrol from the engine: Octavia VRS
Ajmat, I got the scan. The MAF is functioning fine. I believe there is some problem with the charcoal canister. Because every time I get the smell it originates from near the Charcoal Canister. I checked the N80 / Purge Valve just to see if that may not have malfunctioned. But when I put my finger to it while the engine is running, it goes "tick-Tock" which means its functioning fine. Also, the engine scan does not return any fault codes. In fact I even got the charcoal canister dismounted to see if there is any crack or leaks...but there are none. Do you think these Charcoal Canisters have a life and need to be changed after some time when the charcoal inside stops to adsorb the fumes?
I would really appreciate if this problem could be sorted out with your help. Its very disheartening to get this smell from such a beautiful machine and not being able to put a finger on the problem....
Thanks in advance
Kunal
Old 2nd April 2012, 07:48   #8
Motoringlover's Avatar
Thanked: 179 Times
Thanks in advance
Kunal
Mate thanks for sharing this problem - even I am experiencing a similar issue - could you please share what was the end solution to this problem - appreciate your response. In my case the petrol smell comes after driving for some time say 30-40 Km's.
Motoringlover is offline   Reply With Quote
Old 2nd April 2012, 08:01   #9
1self's Avatar
Thanked: 270 Times
The charcoal canister goes for a toss if you overfuel the car (continue filling fuel after the first click of the fuel bowser). The charcoal canister is there to absorb fumes, not liquid fuel. DO NOT fill fuel beyond the first stop click of the fuel bowser. Otherwise such problems will occur/recur.
1self is offline   Reply With Quote
Old 2nd April 2012, 08:11   #10
Thanked: 179 Times
Mate thanks a ton for you help, I just got myself a pre-worshipped rs, I did get a full talk as my first fill, is that what is causing this ?
Old 2nd April 2012, 16:23   #11
1self's Avatar
Thanked: 270 Times
Get your charcoal canister checked/ replaced.
1self is offline   (1) Thanks Reply With Quote
Old 4th April 2012, 15:10   #12
Thanked: 179 Times
Mate thanks a ton for the Advice - I guess the trick is to never fill it to the brink, did the second fill till the cut off - no smell.
Best - Motoringlover.
Old 5th April 2012, 09:07   #13
yogeshnagpal's Avatar
Thanked: 81 Times
Do you see excess build up of soot / oil in the exhaust tail. Probably unburnt fuel due to rich mixture could be the cause.
As many have pointed out, get the filter checked. Also, get the Vacuum Hose checked.
Please keep us posted on what was the issue.
Thanks,
Yogesh.
yogeshnagpal is offline   Reply With Quote
Old 5th April 2012, 11:45   #14
Thanked: 1,172 Times
Really?
I have been fueling to the brim - way beyond the first auto-cutoff for last 7 years (5 years on the Honda city and last couple of years on my Laura TSi). Do these cars have the charcoal canister? How many years/kilometers before it is damaged if regularly filled to the brim???
Was it only smell and no drop in FE?
anandpadhye is offline   Reply With Quote
Old 5th April 2012, 11:58   #15
Thanked: 179 Times
Originally Posted by anandpadhye
Really?
It is a little too soon for me to confirm on the FE, its only my second week of ownership, there has been no smell for now. I did check out briskoda, the general advice on this subject has been to avoid filling to the brink and doubts pointing towards the the charcoal canister or the purge valve.
Also with regards to filling regularly past the first cut off - over a period time leads to a damage to the charcoal canister. My car is a per worshipped buy with 60k on the ODO.
Petrol smell in the car abhibh Technical Stuff 73 25th May 2017 15:10
Heavily modified Skoda Octavia vRS - Fuel for Petrol Heads PowerFool Modifications & Accessories 18 3rd August 2012 12:17
No response from engine after 4K RPM..Octavia vRS ashish22 Technical Stuff 35 14th April 2009 10:24
Petrol smell when starting Ikon Flair shalini_g Technical Stuff 0 18th August 2008 13:39
NEW Swift Petrol Burning Smell cyneverdie Technical Stuff 3 11th February 2008 20:30
